wtv file on Samsung UE 37C6000
I cannot see the .wtv files on my Samsung UE 37C6000 LED Full HD 100Hz: format not supported!
This solution viewtopic.php?f=7&t=3986&p=26267&hilit=wtv#p26267 doesn't work
Any ideas?
2012-01-06 10:42:56,100 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.0.3, Profile=Samsung TV / player (C/D-series)'
2012-01-06 10:42:56,100 DEBUG [MediaItemDAOImpl] Getting file of media item 636
2012-01-06 10:42:56,100 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: C:\Users\Public\Recorded TV\test.wtv
2012-01-06 10:42:56,100 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Users\Public\Recorded TV\test.wtv -y -async 1 -vcodec copy -acodec copy -map 0:2 -map 0:0 -sn -f mpegts C:\Users\Nicoletta\Temp\Serviio\transcoding-temp-636-MPEG2TS.stf
2012-01-06 10:42:56,300 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-01-06 10:42:56,300 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-01-06 10:42:56,480 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:00
2012-01-06 10:42:56,600 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:129)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:96)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
2012-01-06 10:42:59,990 DEBUG [WebServer] Incoming connection from /192.168.0.3:50482
2012-01-06 10:42:59,990 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.3:
2012-01-06 10:42:59,990 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.3
2012-01-06 10:43:00,000 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "C:\Users\Public\Recorded TV\te
st.wtv" -y -async 1 -vcodec copy -acodec copy -map 0:2 -map 0:0 -sn -f mpegts C:
\Users\Nicoletta\Temp\Serviio\transcoding-temp.stf
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
[mp2 @ 02c66c80] Header missing
[mpeg2video @ 0151d3e0] mpeg_decode_postinit() failure
Last message repeated 1 times
Input #0, wtv, from 'C:\Users\Public\Recorded TV\test.wtv':
WM/MediaClassPrimaryID: db9830bd-3ab3-4fab-8a371a995f7ff74
WM/MediaClassSecondaryID: ba7f258a-62f7-47a9-b21f4651c42a000
Title : 61┬░ Festival della Canzone Italiana
WM/SubTitleDescription: Show. 61┬░ Festival della Canzone Italiana
WM/OriginalReleaseTime: 0
WM/MediaCredits : ;;;
service_provider: Rai 1
service_name : Rai 1
WM/MediaNetworkAffiliation: Rai 1
WM/MediaOriginalChannel: 1
WM/MediaOriginalChannelSubNumber: 0
WM/MediaOriginalBroadcastDateTime: 0001-01-01T00:00:00Z
WM/MediaOriginalRunTime: 77947064980
WM/MediaIsStereo: false
WM/MediaIsRepeat: false
WM/MediaIsLive : false
WM/MediaIsTape : false
WM/MediaIsDelay : false
WM/MediaIsSubtitled: false
WM/MediaIsMovie : false
WM/MediaIsPremiere: false
WM/MediaIsFinale: false
WM/MediaIsSAP : false
WM/MediaIsSport : false
WM/Provider : MediaCenterDefault
WM/VideoClosedCaptioning: false
WM/WMRVEncodeTime: 2011-02-17 21:38:04
WM/WMRVSeriesUID: !GenericSeries!61┬░ Festival della Canzone Italiana
WM/WMRVServiceID: !Generated!14dc1c53c7c74dce9765aecd26a61323
WM/WMRVProgramID: !Loaders!Glid!Programs!318:1:3401!51534
WM/WMRVRequestID: 0
WM/WMRVScheduleItemID: 0
WM/WMRVQuality : 3
WM/WMRVOriginalSoftPrePadding: 7802
WM/WMRVOriginalSoftPostPadding: 180
WM/WMRVHardPrePadding: -7682
WM/WMRVHardPostPadding: 0
WM/WMRVATSCContent: false
WM/WMRVDTVContent: true
WM/WMRVHDContent: false
Duration : 30898961230
WM/WMRVEndTime : 2011-02-17 22:29:34
WM/WMRVBitrate : 5.611597
WM/WMRVKeepUntil: -1
WM/WMRVActualSoftPrePadding: 2398
WM/WMRVActualSoftPostPadding: -4524
WM/WMRVContentProtected: false
WM/WMRVContentProtectedPercent: 0
WM/WMRVExpirationSpan: 9223372036854775807
WM/WMRVInBandRatingSystem: 255
WM/WMRVInBandRatingLevel: 255
WM/WMRVInBandRatingAttributes: 0
WM/WMRVWatched : false
WM/MediaThumbType: 2
Duration: 00:51:28.70, start: 7472.735911, bitrate: 5613 kb/s
Stream #0:0[0x1f](ita): Audio: mp2 (P[0][0][0] / 0x0050), 48000 Hz, stereo,
s16, 192 kb/s
Stream #0:1[0x20](oth): Audio: mp2 (P[0][0][0] / 0x0050), 48000 Hz, mono, s1
6, 64 kb/s
Stream #0:2[0x21]: Video: mpeg2video (Main), yuv420p, 720x576 [SAR 64:45 DAR
16:9], 10000 kb/s, 26.25 fps, 25 tbr, 10000k tbn, 50 tbc
Stream #0:3[0x22](ita): Subtitle: dvb_teletext
Stream #0:4[0x0]: Attachment: mjpeg
title : TV Thumbnail
[mpegts @ 02ced340] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every
40 pkts
Output #0, mpegts, to 'C:\Users\Nicoletta\Temp\Serviio\transcoding-temp.stf':
WM/WMRVRequestID: 0
WM/WMRVQuality : 3
encoder : Lavf53.24.0
Stream #0:0: Video: mpeg2video, yuv420p, 720x576 [SAR 64:45 DAR 16:9], q=2-3
1, 10000 kb/s, 26.25 fps, 90k tbn, 25 tbc
Stream #0:1(ita): Audio: mp2 (P[0][0][0] / 0x0050), 48000 Hz, stereo, 192 kb
/s
Stream mapping:
Stream #0:2 -> #0:0 (copy)
Stream #0:0 -> #0:1 (copy)
[mpegts @ 02ced340] first pts value must set
av_interleaved_write_frame(): Operation not permitted
Users browsing this forum: Baidu [Spider] and 8 guests
