Samsung D40UE5000 and divx
Marco
Post Fri Jan 06, 2012 6:45 pm
i have some divx movies, but when i want to watch them with serviio on my tv, i get the message unsupported file format".
When i'm playing the movies from an usb stick, they play correctly.
Does serviio support divx files, or have i to transcode them?
Post Fri Jan 06, 2012 7:47 pm
Re: Samsung D40UE5000
Marco wrote:Hi,
please provide information on the file that will not play: viewtopic.php?f=5&t=1123
Post Fri Jan 06, 2012 9:46 pm
Some files will not play for whatever reason via DLNA. Normally divx files play natively, it's just the odd ones here and there.
Marco
Post Sat Jan 07, 2012 12:04 pm
Ok,
here are the file informations :
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[mpeg4 @ 003d8a00] Invalid and inefficient vfw-avi packed B frames detected
[mpeg4 @ 003d8a00] hmm, seems the headers are not complete, trying to guess time
_increment_bits
[mpeg4 @ 003d8a00] my guess is 9 bits ;)
_increment_bits
[mpeg4 @ 003d8a00] my guess is 3 bits ;)
[mpeg4 @ 003d8a00] Error, header damaged or not MPEG4 header (f_code=0)
_increment_bits
[mpeg4 @ 003d8a00] my guess is 7 bits ;)
_increment_bits
[mpeg4 @ 003d8a00] my guess is 4 bits ;)
Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (300
00/1) -> 25.00 (25/1)
Input #0, avi, from 'E:\Filme\Hangover 2.divx':
  Duration: 01:37:34.52, start: 0.000000, bitrate: 1644 kb/s
    Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 720x400 [SAR 1:1 DAR
 9:5], 25 fps, 25 tbr, 25 tbn, 30k tbc
      title           : Video
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 128 kb
/s
      title           : Audio
and here from another file that is not playing
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
[mpeg4 @ 013f8a20] Invalid and inefficient vfw-avi packed B frames detected
Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (30000/1) -> 25.00 (25/1)
Input #0, avi, from 'E:\Filme\The Mechanic HD.divx':
  Duration: 01:28:29.60, start: 0.000000, bitrate: 3142 kb/s
    Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 25 tbn, 30k tbc
      title           : Video
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 128 kb/s
      title           : Audio
Post Sat Jan 07, 2012 5:49 pm
Re: Samsung D40UE5000 and divx
yep broken file, try and find another copy of it or remux it with mkvmerge
Marco
Post Sat Jan 07, 2012 6:21 pm
Hmm,
its not broken. Its a movie i have bought and downloaded. Playes well with divx plus player.
But i will try to download it again.
Can you give me some hints about remuxing with mkvmerge?
I don't have so much knowlegde about these movie stuff.
Post Sat Jan 07, 2012 7:00 pm
Looks like files with this message:
are hardly ever playable. It might be playable in your software player, but the TV has probably different implementation of the decoding module (codec) thus failing to play that.
Also if you bought the file it might have some DRM in it preventing playback, although I don't think it's the case here.
Post Sat Jan 07, 2012 7:01 pm
Marco wrote:Hmm,
mkv merge is easy.
1. install
2. open mmg.exe (mkvmerge gui)
3. add file in top box
4. click remux
5. enjoy :)
Marco
Post Sun Jan 08, 2012 9:52 am
@zip: Ok the files are DRM protected, but i thought that when i can play these files from usb, than they should be played over serviio also. so its my fault.
@cerberus: I have installed mkvmerge gui but when i try to add files, there is no chance to add divx files. The fileextension is not listed.
Post Sun Jan 08, 2012 3:29 pm
Marco wrote:@zip: Ok the files are DRM protected, but i thought that when i can play these files from usb, than they should be played over serviio also. so its my fault.
rename the file .avi
Marco
Post Sun Jan 08, 2012 5:12 pm
Ok, as avi file i can add them.
remuxing time only 15 seconds. No errors, no warnings, but the mkv file now is not playable anymore.
In no player.
It seems that the DRM protection is the problem?
Users browsing this forum: Google [Bot] and 29 guests
