Thumbnail URL
• Page 1 of 1
Hi how do you use the Thumbnail URL in the Online Sources?
Re: Thumbnail URL
Google Image, find jpeg image path according to the online source name you are looking for, paste the result on Thumbnail URL.
Re: Thumbnail URL
an example here; http://www.serviio.org/index.php?option ... icle&id=42
Petr
Help translate Serviio
Re: Thumbnail URL
Re: Thumbnail URL
Is it possible to use a local file? If so, what is the syntax? I've tried file://, localhost/path/filename, etc to no avail. Thanks!
Re: Thumbnail URL
No they must be on a web url. I use google sites for the live stream library tv station icons and hahasports flags thumbs.
Re: Thumbnail URL
All the media resources on serviidb.com have the capability to have Thumbnails and are linkable
• Page 1 of 1
