Toshiba transcoding (was:HOWTO: Serviio on DNS-320 & DNS-325
Lukas718
Post Sat Jan 07, 2012 6:40 pm
wow Im going crazy with my other TV (Toshiba 55WX800U)
I hit folers and lists all files and times. When I click on it it work with major choppy effect (sound/video) or it displays "media error playback"
I can find a patter to it - why does it play sometimes and some other times it doesnt
also mkv and mp4 files are no go.
it has to be something with dns-325 version 5 of serviio since I know on my htpc i had v6 and played normally
Post Sat Jan 07, 2012 7:07 pm
Re: HOWTO: Serviio on DNS-320 & DNS-325
Lukas718 wrote:wow Im going crazy with my other TV (Toshiba 55WX800U)
viewtopic.php?f=26&t=4623
Lukas718
Post Sun Jan 08, 2012 2:48 am
Dude Im lost
I have no idea how to do that. I read you wiki link and downloaded that soft but dont know anything else. Can you point me into right direction please.
One way is to send me the Sink protocol information of your device.
Install Intel UPnP tools <------------ did that
run Device Spy <------------where/what is that ?
It should list all your UPnP device and among them yout device (eg TV, console, etc)
Expand the device's tree and find service: urn:upnp-org:serviceId:ConnectionManager:1
Expand that and double click on GetProtocolInfo(…).
Click on Invoke and send me (or attach a file) the result in field Sink. If you feel like it you can as well add it to our database.
Alternatively, if your device doesn't appear in DeviceSpy, search for it's supported features via DLNA Product Search.
Post Sun Jan 08, 2012 3:01 am
no problem i dont mind talking you through it. :)
1. Expand the device's tree and find service: urn:upnp-org:serviceId:ConnectionManager:1
2. Expand that and double click on GetProtocolInfo(…). (Red Box)
3. Click on Invoke. (Yellow Box)
4. Copy information to motepad and save as txt file. (Green Box)
5. Attach the txt file here so that it can be looked at by the mods/admin here and a profile made up.
Lukas718
Post Sun Jan 08, 2012 3:10 am
got it but do i have to run my TOSHIBA with a movie or TV doesnt even have to be on ?
Cerberus wrote:no problem i dont mind talking you through it. :)
Post Sun Jan 08, 2012 3:28 am
tv has to be turned on and connected to network thats all.
Lukas718
Post Sun Jan 08, 2012 3:39 am
Ok I had my samsung listed then I went to turn on toshiba but it didnt show up in spy so I did refresh the network option and it still didnt come up. I restared my pc and now none of my tvs show up
UPDATE
I got Samsung TV-60C6300 (3 lines) to show up but Toshiba doesnt want. I tried to access nas-325 and Im albe to log in from toshiba and folders/are visible but spy cant see it
UPDATE 2
I was able to get it done. Let me know if thats ok. I dont get it it kept going on and off the network - I hate toshiba!
Toshiba 55WX800U.rtf
(1.59 KiB) Downloaded 1070 times
jsviverette
Post Sun Jan 08, 2012 8:40 am
are you guys using transcoding? If so is it working well?
I have kinda given up on this unless the transcoding is working.
Lukas718
Post Sun Jan 08, 2012 3:16 pm
Bro my Samsung works great with transcoding - onlt Toshiba is giving me headaches. Might be that your tv has similar issues as my toshiba ?
Post Sun Jan 08, 2012 3:38 pm
Lukas718 wrote:Ok I had my samsung listed then I went to turn on toshiba but it didnt show up in spy so I did refresh the network option and it still didnt come up. I restared my pc and now none of my tvs show up
UPDATE
UPDATE 2
ok thanks will look at it when i get a sec.
Post Sun Jan 08, 2012 3:46 pm
try changing the toshiba profile to this
   <Profile id="13" name="Toshiba REGZA" extendsProfileId="1">
         <Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="mp4" />
            <Matches container="avi" />
            <Matches container="mpegts" />
            <Matches container="mpegvideo" />
            <Matches container="asf" />
            <Matches container="ogg" />
            <Matches container="flv" />
            <Matches container="3gp" />
            <!-- if audio different to ac3, must be transcoded -->
            <Matches container="mpeg" aCodec="aac" />
            <Matches container="mpeg" aCodec="mp3" />
            <Matches container="mpeg" aCodec="dca" />
         <Audio targetContainer="mp3">
                     <Matches container="flac" />
               </Audio>
      <OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3">
      </OnlineTranscoding>
in profiles.xml file and then restart serviio pc and try your MKV files again. make sure u have selected this profile for your device as unlike Samsung its not auto assigned for you.
Lukas718
Post Sun Jan 08, 2012 9:12 pm
Re: Toshiba transcoding (was:HOWTO: Serviio on DNS-320 & DNS
I found that files but when Im trying to modify with wordpad or notepad give me access denied. Is there a specific way to modify it ?
Lukas718
Post Sun Jan 08, 2012 11:18 pm
I tried to modify/edt that with xml copy editor, notepad, wordpad and none of them work.
Now my profile.xml is broken.
Can you please edit that on your end and post the whole profiles.xml file ?
my serviio is not even working now prolly because I damaged that file trying to edit it.
Thank You for all you help and time
UPDATE
I have tried few other ways to update that profile.
1.) stop serviio in webUI - didnt allowed me to save proflies.xml (it says that other app is using it)
2.) rename files and accessed telnet then manually replace file with the one that i have edited in notepad++ ( I did copy, past Toshiba profile) . I did replace the file but serviio didnt recognized that profile. then I replaced that with backup proflies.xml and started to work again.
I tired to edit this file with notepad, notepad++, xml notepad and xml copy editor. They all replaced existing profile for toshiba but at the end didnt work in serviio.
At this point Im stuck - I tried all options I could come out with and searched for all possible ones.
Please help ?
Post Mon Jan 09, 2012 5:49 am
profiles.xml
(56.59 KiB) Downloaded 1300 times
Lukas718
Post Mon Jan 09, 2012 2:02 pm
Great thanks
What would be the best way to replace that file ? Or do I have to disable ssh and use telnet to overwrite file in that folder ?
Sorry for so many noob questions but I'm new to nas and Linux
Post Mon Jan 09, 2012 2:15 pm
Lukas718 wrote:Great thanks
to allow access you have to stop serviio service on the nas, then FTP to the nas and copy the file over and over right the existing file.
Lukas718
Post Mon Jan 09, 2012 2:42 pm
By stopping it u mean to log into serviio webUI and hit stop button ?
If so last time I did that it stooped serviio but I still coulndt overwrite the file because of access denided
Post Mon Jan 09, 2012 2:44 pm
Lukas718 wrote:By stopping it u mean to log into serviio webUI and hit stop button ?
no ud have to ssh in and actualy kill the serviio process.
Lukas718
Post Mon Jan 09, 2012 3:02 pm
Sorry but can u tell me what would be that command in ssh to stop it and start it after I'm done ?
Thank you
UPDATE 2
I tried to find it myself so II did fallowing
to shut down serviio
/opt/serviio/serviio-0.5.2/bin/serviio.sh stop
then I logged into dlink sharecenter and used ther web file service to accesses all files - went to folder /opt/serviio/serviio-0.5.2/config/ and deleted profiles.xml
next step I did was to upload new profiles.xml into that folder using the same build in app from sharecenter.
-then I did /opt/serviio/serviio-0.5.2/bin/serviio.sh start
-all looked fine - time stamp on file i replaced changed
- restarted box
-now serviio is not detected by TVs. And when I tried to log into webUI I see red circle with X in it.
Required Serviio 0.5.2, but found ''
Cannot connect to Serviio server, it does not seem to be running. Exiting..
I just replaced it with backup file I had and now it works ?? (old file)
Do you think there is something wrong with that file you gave me ?
I use the same steps to replace it with backup profiles.xml i had and went back to original
that file you uploaded for some reason doesnt want to work with my serviio - unless im missing something on how it has to be replaced/activated ?
can you please look into that
Thank you
Post Tue Jan 10, 2012 1:51 pm
use a proper ftp program (filezilla) as clearly the built in one is corrupting the profile.xml file. I have also reuploaded the profiles.xml file above just in case my work network corrupted it when I originaly did it.
Return to Toshiba
