Usability Features
Kalem
Post Sat Jan 07, 2012 10:35 pm
Usability Features
Hi serviio team,
first of all thank you very much for the application! I like it very much!
I have few wishes / feature extensions.
1. warning message
Serviio Console > [Library] > [Shared Folders]
Serviio Console > [Library] > [Online Resources]
If user clicks on "Remove" button, user get a warning message with "ok" | "cancel" button.
2. re-order button
Add 2 buttons ↑ ↓ to re-order the source names.
3. Manually Edit Library
(Where are the source names stored?)
Ability for user to modify an xml file which contains these values like "Source URL", "Source name" ...
If you want to modify several values, it is easier via notepad.
4. flash stream
There are several Online TVs that are based on flash (I think these are rtmp protocoll ?) .
Are flash stream possible to stream via serviio?
5. Log File
Serviio Console > [Library] > [Console Settings]
Is it possible to have a "Log File" button in here,
so if user clicks on it, the log file is opened (notepad) or at least windows explorer pops up with the log folder.
6. Export / Import Feature
Ability to export everything what you setup on computer 1 like "Ip Address", [Library] tab, [Presentation] tab, ...
Ability to import everything on another computer.
The export could also be used as backup feature e.g. if you do de-install on comupter 1 serviio, incl. delete serviio installation folders.
7. Live Stream > Thumbnai URL
I added urls to jpg, gif and png files on internet, it does not work.
Could you please give me an example?
What file extension, what size / resolution is the image file for the Thumbnai URL?
The feature example I would like to submit here is, that the URL could also be a local path, so not only a real website link.
8. Online RSS
I have several youtube clip URLs, I would like to make an own RSS and put the xml file on my either local computer or on my person website.
a) Is referencing to an xml file on person website possible?
b) Could you please give an short example for this rss file? I tried, it didn't work.
Thanks, Kalem
Post Sat Jan 07, 2012 10:57 pm
Re: Usability Features
so just a few than :roll:
Return to Feature requests
