Cant see Files
• Page 1 of 3 • 1, 2, 3
I install Serviio two days ago I could see it on my xbox 360 i see the folder but i cant see the video that is in the folder the folder I am trying to get to work is on a nas I tried everything to get it to work from going to the logon on windows an the \\server\file but I still cant see it could you help me to get this to work
Re: Cant see Files
there is a million topics regarding this, as well as an entry in the FAQ on the website. It's the access rights.
Petr
Help translate Serviio
Re: Cant see Files
I looked at the million of topics regarding this and I also looked at the FAQ I did the whole access thought windows and I am not still seeing nothing.
Re: Cant see Files
Can you enable detailed logging (see signature) and post your serviio.log file.
What NAS are you using? What Operating system is on it.
Re: Cant see Files
I am using freenas 8 but I put serviio on my window 7 desktop I dont really know how to get the serviio log
Re: Cant see Files
Look under c:\program files\serviio\log for the log file.
Configuration file is c:\program files\serviio\config
ok How do you access the files on the freenas now? Do you have the drive mapped to a drive letter? ie "h:\"
If that is the case you cannot use the "h:\" you must use the server name and the path on the server.
ie \\freenas\home\videos
Re: Cant see Files
he is my serviio log
2012-01-07 05:21:51,080 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 05:21:51,082 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-07 05:21:51,082 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-07 05:21:51,082 INFO [MediaServer] http://www.serviio.org
2012-01-07 05:21:51,083 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-07 05:21:51,083 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-07 05:21:51,083 INFO [MediaServer] File encoding: windows-1252
2012-01-07 05:21:51,083 INFO [MediaServer] Headless mode enabled: true
2012-01-07 05:21:51,084 INFO [MediaServer] User home dir: C:\Windows\System32\config\systemprofile
2012-01-07 05:21:51,084 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-07 05:21:51,084 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 05:21:51,325 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-07 05:21:51,411 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-07 05:21:58,187 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-01-07 05:22:07,304 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-07 05:22:07,972 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-07 05:22:08,423 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-07 05:22:08,698 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-07 05:22:08,962 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-07 05:22:09,188 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-07 05:22:09,345 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-07 05:22:10,032 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-07 05:22:10,089 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-07 05:22:10,778 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-07 05:22:11,838 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-07 05:22:12,297 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-07 05:22:12,747 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-07 05:22:12,971 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-07 05:22:13,026 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-07 05:22:13,221 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-07 05:22:13,311 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-07 05:22:13,622 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-07 05:22:13,787 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-07 05:22:14,172 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-07 05:22:14,414 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-07 05:22:20,726 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-07 05:22:20,727 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-01-07 05:22:20,780 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-07 05:22:20,803 INFO [PluginCompilerThread] Started looking for plugins
2012-01-07 05:22:21,485 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 05:22:21,586 INFO [WebServer] WebServer starting on port 8895
2012-01-07 05:22:21,594 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-07 05:22:21,715 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-07 05:22:21,716 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-07 05:22:21,717 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-07 05:22:21,717 INFO [EventDispatcher] Starting EventDispatcher
2012-01-07 05:22:21,957 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-07 05:22:28,426 INFO [RendererManager] Stored a new renderer: uuid='ebf73852-e22c-44d9-b279-8ea293017284', name = 'Unrecognized device', ipAddress='192.168.1.2', profile = '1'
2012-01-07 05:22:29,042 INFO [RendererManager] Stored a new renderer: uuid='e38bf438-06f2-4eb3-a2c4-70bb2e85f008', name = 'Playstation 3', ipAddress='192.168.1.5', profile = '4'
2012-01-07 05:22:29,557 INFO [RendererManager] Stored a new renderer: uuid='21915738-2505-2000-0000-001dd8601d85', name = 'Xbox 360', ipAddress='192.168.1.7', profile = '3'
2012-01-07 05:22:30,301 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-07 05:22:31,028 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-07 05:22:50,075 INFO [ServiioConsole] Starting Serviio Console
2012-01-07 05:22:50,283 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-01-07 05:22:51,511 INFO [Messages] Loaded console message bundle for locale: en
2012-01-07 05:22:51,528 INFO [UpdateChecker] Checking if a new version is available
2012-01-07 05:22:55,038 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-07 05:22:55,039 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 05:22:55,040 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 05:34:24,004 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 05:34:24,104 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 05:34:24,212 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 05:34:24,213 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 05:35:40,879 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 05:35:40,979 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 05:35:41,097 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 05:35:41,102 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 05:36:06,494 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-07 05:36:06,495 INFO [WebServer] WebServer shutting down
2012-01-07 05:36:06,498 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-07 05:36:06,498 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-07 05:36:06,735 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-07 05:36:12,142 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-07 05:36:13,778 INFO [WebServer] WebServer starting on port 8895
2012-01-07 05:36:13,779 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-07 05:36:13,780 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-07 05:36:13,786 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-07 05:36:13,786 INFO [EventDispatcher] Starting EventDispatcher
2012-01-07 05:36:13,964 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-07 05:36:57,065 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 05:36:57,165 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 05:36:57,265 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 05:36:57,270 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 05:37:32,573 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 05:37:32,673 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 05:37:32,779 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 05:37:32,782 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 05:37:35,966 INFO [LibraryAdditionsCheckerThread] Added file '01.Chest.Back.avi' (title: P90X - Chest & Back) to Library
2012-01-07 05:37:37,457 INFO [LibraryAdditionsCheckerThread] Added file '02.Plyometrics.avi' (title: P90X - Plyometrics) to Library
2012-01-07 05:37:39,096 INFO [LibraryAdditionsCheckerThread] Added file '03.Shoulders.Arms.avi' (title: P90X - Shoulders & Arms) to Library
2012-01-07 05:37:41,479 INFO [LibraryAdditionsCheckerThread] Added file '04.Yoga.avi' (title: P90X - Yoga X) to Library
2012-01-07 05:37:43,022 INFO [LibraryAdditionsCheckerThread] Added file '05.Legs.Back.avi' (title: P90X - Legs & Back) to Library
2012-01-07 05:37:44,412 INFO [LibraryAdditionsCheckerThread] Added file '06.Kenpo.X.avi' (title: P90X - Kenpo X) to Library
2012-01-07 05:37:46,172 INFO [LibraryAdditionsCheckerThread] Added file '07.X.Stretch.avi' (title: P90X - X Stretch) to Library
2012-01-07 05:37:47,661 INFO [LibraryAdditionsCheckerThread] Added file '08.Core.Synergistics.avi' (title: P90X - Core Synergistics) to Library
2012-01-07 05:37:49,390 INFO [LibraryAdditionsCheckerThread] Added file '09.Chest.Shoulders.Triceps.avi' (title: P90X - Chest, Shoulders & Triceps) to Library
2012-01-07 05:37:51,680 INFO [LibraryAdditionsCheckerThread] Added file '10.Back.Biceps.avi' (title: P90X - Back & Biceps) to Library
2012-01-07 05:37:54,568 INFO [LibraryAdditionsCheckerThread] Added file '11.Cardio.X.avi' (title: P90X - Cardio X) to Library
2012-01-07 05:37:55,581 INFO [LibraryAdditionsCheckerThread] Added file '12.Ripper.X.avi' (title: P90X - Ab Ripper X) to Library
2012-01-07 05:37:57,879 INFO [LibraryAdditionsCheckerThread] Added file 'How.Do.You.Know.2010-Rip.avi' (title: How Do You Know) to Library
2012-01-07 05:39:24,635 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 05:39:24,694 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 05:39:24,799 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 05:39:24,803 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 05:40:46,171 INFO [LibraryAdditionsCheckerThread] Added file 'Tangled.2010.480p.BRRip.XviD.AC3-ViSiON.avi' (title: Tangled) to Library
2012-01-07 05:40:49,125 INFO [LibraryAdditionsCheckerThread] Added file 'The Fighter.avi' (title: The Fighter) to Library
2012-01-07 05:40:51,262 INFO [LibraryAdditionsCheckerThread] Added file 'The.Mechanic.2011.R5.LiNE-MCK.avi' (title: The Mechanic) to Library
2012-01-07 05:40:53,705 INFO [LibraryAdditionsCheckerThread] Added file 'The.Next.Three.Days.2010.PPVRIP-IFLIX.avi' (title: The Next Three Days) to Library
2012-01-07 05:40:56,648 INFO [LibraryAdditionsCheckerThread] Added file 'TRON.Legacy.2010.PPV.XViD-T0XiCiNK.avi' (title: TRON: Legacy) to Library
2012-01-07 05:45:26,417 INFO [RendererManager] Stored a new renderer: uuid='c3fc56b3-b2d4-497d-9273-85bfb48d8002', name = 'Unrecognized device', ipAddress='192.168.1.9', profile = '1'
2012-01-07 06:04:30,727 INFO [RendererManager] Stored a new renderer: uuid='ee0be1e3-4a8d-45a1-96e1-d2189c34827e', name = 'Unrecognized device', ipAddress='192.168.1.3', profile = '1'
2012-01-07 06:51:13,550 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-07 06:51:13,552 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-07 06:51:13,563 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 06:51:13,651 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 06:51:13,753 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-07 06:51:13,852 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-07 06:51:13,954 INFO [WebServer] WebServer shutting down
2012-01-07 06:51:13,954 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-07 06:51:13,955 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-07 06:51:13,956 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-07 06:51:17,513 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-07 06:51:19,489 INFO [DatabaseManager] Shutting down database
2012-01-07 06:51:20,432 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 06:51:23,238 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 06:51:23,239 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-07 06:51:23,240 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-07 06:51:23,240 INFO [MediaServer] http://www.serviio.org
2012-01-07 06:51:23,240 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-07 06:51:23,240 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-07 06:51:23,240 INFO [MediaServer] File encoding: windows-1252
2012-01-07 06:51:23,241 INFO [MediaServer] Headless mode enabled: true
2012-01-07 06:51:23,241 INFO [MediaServer] User home dir: C:\Users\Marsha
2012-01-07 06:51:23,241 INFO [MediaServer] Temp dir: C:\Users\Marsha\AppData\Local\Temp\
2012-01-07 06:51:23,241 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 06:51:23,477 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-07 06:51:23,570 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-07 06:51:25,684 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-07 06:51:26,433 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-07 06:51:26,945 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-07 06:51:27,255 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-07 06:51:27,530 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-07 06:51:27,764 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-07 06:51:27,918 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-07 06:51:28,681 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-07 06:51:28,732 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-07 06:51:29,467 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-07 06:51:29,708 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-07 06:51:29,711 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-01-07 06:51:30,745 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-07 06:51:31,196 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-07 06:51:31,602 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-07 06:51:31,842 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-07 06:51:31,885 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-07 06:51:32,081 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-07 06:51:32,169 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-07 06:51:32,485 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-07 06:51:32,638 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-07 06:51:33,020 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-07 06:51:33,265 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-07 06:51:33,334 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-07 06:51:33,335 INFO [PluginCompilerThread] Started looking for plugins
2012-01-07 06:51:33,453 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 06:51:33,502 INFO [WebServer] WebServer starting on port 8895
2012-01-07 06:51:33,523 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-07 06:51:33,524 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-07 06:51:33,532 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-07 06:51:33,533 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-07 06:51:33,533 INFO [EventDispatcher] Starting EventDispatcher
2012-01-07 06:51:33,694 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-07 06:51:49,838 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-07 06:51:50,698 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-07 06:52:06,608 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-07 06:52:06,608 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 06:52:06,624 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 06:53:32,632 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 06:53:32,732 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 06:53:32,936 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 06:53:32,937 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 06:54:41,016 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-07 06:54:41,017 INFO [WebServer] WebServer shutting down
2012-01-07 06:54:41,017 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-07 06:54:41,017 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-07 06:54:43,535 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-07 06:54:46,709 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-07 06:54:48,130 INFO [WebServer] WebServer starting on port 8895
2012-01-07 06:54:48,131 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-07 06:54:48,131 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-07 06:54:48,134 INFO [EventDispatcher] Starting EventDispatcher
2012-01-07 06:54:48,134 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-07 06:54:48,356 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-07 06:55:46,516 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 06:55:46,616 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 06:55:46,716 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 06:55:46,722 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 06:57:03,309 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 06:57:03,409 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 06:57:03,539 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 06:57:03,543 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 07:07:50,625 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-07 07:07:50,627 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 07:07:50,627 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-07 07:07:50,727 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 07:07:50,827 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-07 07:07:50,927 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-07 07:07:51,030 INFO [WebServer] WebServer shutting down
2012-01-07 07:07:51,030 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-07 07:07:51,030 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-07 07:07:51,031 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-07 07:07:56,616 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-07 07:07:56,621 INFO [DatabaseManager] Shutting down database
2012-01-07 07:07:56,709 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 07:07:58,288 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 07:07:58,290 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-07 07:07:58,290 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-07 07:07:58,290 INFO [MediaServer] http://www.serviio.org
2012-01-07 07:07:58,290 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-07 07:07:58,290 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-07 07:07:58,290 INFO [MediaServer] File encoding: windows-1252
2012-01-07 07:07:58,291 INFO [MediaServer] Headless mode enabled: true
2012-01-07 07:07:58,291 INFO [MediaServer] User home dir: C:\Windows\System32\config\systemprofile
2012-01-07 07:07:58,291 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-07 07:07:58,291 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 07:07:58,480 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-07 07:07:58,565 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-07 07:08:00,625 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-07 07:08:01,411 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-07 07:08:01,949 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-07 07:08:02,260 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-07 07:08:02,570 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-07 07:08:02,795 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-07 07:08:02,942 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-07 07:08:03,690 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-07 07:08:03,739 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-07 07:08:04,375 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-07 07:08:04,376 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-01-07 07:08:04,424 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-07 07:08:05,664 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-07 07:08:06,111 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-07 07:08:06,517 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-07 07:08:06,743 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-07 07:08:06,797 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-07 07:08:06,991 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-07 07:08:07,079 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-07 07:08:07,396 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-07 07:08:07,551 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-07 07:08:07,934 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-07 07:08:08,179 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-07 07:08:08,223 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-07 07:08:08,224 INFO [PluginCompilerThread] Started looking for plugins
2012-01-07 07:08:08,360 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 07:08:08,398 INFO [WebServer] WebServer starting on port 8895
2012-01-07 07:08:08,407 INFO [EventDispatcher] Starting EventDispatcher
2012-01-07 07:08:08,413 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-07 07:08:08,414 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-07 07:08:08,416 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-07 07:08:08,417 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-07 07:08:08,573 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-07 07:08:18,541 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-07 07:08:19,246 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-07 07:08:40,770 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-07 07:08:40,774 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 07:08:40,787 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 07:21:44,168 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-07 07:21:44,169 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 07:21:44,173 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-07 07:21:44,268 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 07:21:44,368 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-07 07:21:44,468 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-07 07:21:44,568 INFO [WebServer] WebServer shutting down
2012-01-07 07:21:44,571 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-07 07:21:44,571 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-07 07:21:44,572 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-07 07:21:48,554 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-07 07:21:50,173 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-07 07:21:50,177 INFO [DatabaseManager] Shutting down database
2012-01-07 07:21:50,227 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 07:21:51,712 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 07:21:51,713 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-07 07:21:51,713 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-07 07:21:51,714 INFO [MediaServer] http://www.serviio.org
2012-01-07 07:21:51,714 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-07 07:21:51,714 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-07 07:21:51,714 INFO [MediaServer] File encoding: windows-1252
2012-01-07 07:21:51,715 INFO [MediaServer] Headless mode enabled: true
2012-01-07 07:21:51,715 INFO [MediaServer] User home dir: C:\Users\Marsha
2012-01-07 07:21:51,715 INFO [MediaServer] Temp dir: C:\Users\Marsha\AppData\Local\Temp\
2012-01-07 07:21:51,715 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 07:21:51,907 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-07 07:21:51,992 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-07 07:21:54,097 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-07 07:21:55,021 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-07 07:21:55,655 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-07 07:21:56,009 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-07 07:21:56,325 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-07 07:21:56,603 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-07 07:21:56,760 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-07 07:21:57,555 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-07 07:21:57,614 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-07 07:21:58,423 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-07 07:21:58,501 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-07 07:21:58,501 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-01-07 07:21:59,675 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-07 07:22:00,166 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-07 07:22:00,609 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-07 07:22:00,830 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-07 07:22:00,884 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-07 07:22:01,183 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-07 07:22:01,310 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-07 07:22:01,800 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-07 07:22:01,982 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-07 07:22:02,193 INFO [ServiioConsole] Leaving Serviio Console
2012-01-07 07:22:02,616 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-07 07:22:02,940 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-07 07:22:02,987 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-07 07:22:03,330 INFO [PluginCompilerThread] Started looking for plugins
2012-01-07 07:22:03,432 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 07:22:03,497 INFO [WebServer] WebServer starting on port 8895
2012-01-07 07:22:03,500 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-07 07:22:03,511 INFO [EventDispatcher] Starting EventDispatcher
2012-01-07 07:22:03,511 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-07 07:22:03,513 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-07 07:22:03,513 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-07 07:22:03,692 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-07 07:22:37,817 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-07 07:22:37,817 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 07:22:37,864 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 07:22:41,873 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-07 07:22:41,873 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-07 07:22:41,889 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 07:22:41,983 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 07:22:42,092 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-07 07:22:42,201 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-07 07:22:42,310 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-07 07:22:42,310 INFO [WebServer] WebServer shutting down
2012-01-07 07:22:42,310 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-07 07:22:42,357 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-07 07:22:43,589 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-07 07:22:47,426 INFO [DatabaseManager] Shutting down database
2012-01-07 07:22:53,321 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 07:24:25,227 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 07:24:25,320 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-07 07:24:25,320 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-07 07:24:25,320 INFO [MediaServer] http://www.serviio.org
2012-01-07 07:24:25,320 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-07 07:24:25,320 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-07 07:24:25,320 INFO [MediaServer] File encoding: windows-1252
2012-01-07 07:24:25,320 INFO [MediaServer] Headless mode enabled: true
2012-01-07 07:24:25,320 INFO [MediaServer] User home dir: C:\Users\Marsha
2012-01-07 07:24:25,320 INFO [MediaServer] Temp dir: C:\Users\Marsha\AppData\Local\Temp\
2012-01-07 07:24:25,320 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 07:24:27,795 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-07 07:24:28,372 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-07 07:24:42,662 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-07 07:24:43,644 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-07 07:24:44,409 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-07 07:24:44,783 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-07 07:24:45,095 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-07 07:24:45,329 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-07 07:24:45,485 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-07 07:24:46,136 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-07 07:24:46,193 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-07 07:24:47,078 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-07 07:24:48,397 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-07 07:24:49,091 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-07 07:24:49,735 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-07 07:24:50,070 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-07 07:24:50,127 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-07 07:24:50,361 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-07 07:24:50,445 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-07 07:24:50,791 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-07 07:24:50,945 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-07 07:24:51,380 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-07 07:24:51,623 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-07 07:24:57,404 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-07 07:24:57,432 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-01-07 07:24:57,849 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-07 07:24:57,850 INFO [PluginCompilerThread] Started looking for plugins
2012-01-07 07:25:07,576 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 07:25:07,978 INFO [WebServer] WebServer starting on port 8895
2012-01-07 07:25:08,055 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-07 07:25:08,056 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-07 07:25:08,063 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-07 07:25:08,066 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-07 07:25:08,098 INFO [EventDispatcher] Starting EventDispatcher
2012-01-07 07:25:08,376 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-07 07:25:41,781 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-07 07:25:41,782 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 07:25:41,874 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 07:25:43,780 INFO [ServiioConsole] Starting Serviio Console
2012-01-07 07:25:52,005 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-07 07:25:52,890 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-07 07:25:55,017 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-01-07 07:25:56,812 INFO [Messages] Loaded console message bundle for locale: en
2012-01-07 07:25:56,855 INFO [UpdateChecker] Checking if a new version is available
2012-01-07 07:26:52,882 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 07:26:52,972 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 07:26:53,067 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 07:26:53,091 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 07:26:54,579 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 07:26:54,711 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 07:26:54,846 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 07:26:55,424 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 07:26:55,803 WARN [LibraryAdditionsCheckerThread] Cannot add file 10.Back.Biceps.avi because of an unexpected error. Message: Cannot check if media item exists: 10.Back.Biceps.avi
org.serviio.db.dao.PersistenceException: Cannot check if media item exists: 10.Back.Biceps.avi
at org.serviio.library.dao.MediaItemDAOImpl.isMediaItemPresent(MediaItemDAOImpl.java:89)
at org.serviio.library.local.service.MediaService.isMediaPresentInLibrary(MediaService.java:37)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:142)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:78)
Caused by: java.sql.SQLNonTransientConnectionException: Connection closed by unknown interrupt.
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeQuery(Unknown Source)
at org.serviio.library.dao.MediaItemDAOImpl.isMediaItemPresent(MediaItemDAOImpl.java:68)
... 3 more
Caused by: java.sql.SQLException: Connection closed by unknown interrupt.
... 13 more
Caused by: ERROR 08000: Connection closed by unknown interrupt.
at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
at org.apache.derby.impl.sql.execute.BulkTableScanResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.IndexRowToBaseRowResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.JoinResultSet.openCore(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.openCore(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.open(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
... 7 more
2012-01-07 07:26:55,906 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 2 as scanned
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:159)
at org.serviio.library.local.service.RepositoryService.markRepositoryAsScanned(RepositoryService.java:108)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:79)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:157)
... 2 more
... 12 more
at org.apache.derby.impl.sql.execute.TableScanResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.NormalizeResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.collectAffectedRows(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.open(Unknown Source)
... 6 more
2012-01-07 07:26:55,907 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 07:26:55,994 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 07:26:56,168 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 07:26:56,192 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 10:59:03,154 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-07 10:59:03,157 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-07 10:59:03,158 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-07 10:59:03,257 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-07 10:59:03,358 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-07 10:59:03,457 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-07 10:59:03,560 INFO [WebServer] WebServer shutting down
2012-01-07 10:59:03,560 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-07 10:59:03,560 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-07 10:59:03,561 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-07 10:59:06,115 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-07 10:59:08,792 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-07 10:59:08,792 INFO [DatabaseManager] Shutting down database
2012-01-07 10:59:08,839 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 10:59:10,729 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 10:59:10,730 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-07 10:59:10,730 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-07 10:59:10,730 INFO [MediaServer] http://www.serviio.org
2012-01-07 10:59:10,730 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-07 10:59:10,730 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-07 10:59:10,731 INFO [MediaServer] File encoding: windows-1252
2012-01-07 10:59:10,731 INFO [MediaServer] Headless mode enabled: true
2012-01-07 10:59:10,731 INFO [MediaServer] User home dir: C:\Users\Marsha
2012-01-07 10:59:10,731 INFO [MediaServer] Temp dir: C:\Users\Marsha\AppData\Local\Temp\
2012-01-07 10:59:10,732 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-07 10:59:10,910 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-07 10:59:11,021 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-07 10:59:12,980 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-07 10:59:13,821 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-07 10:59:14,396 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-07 10:59:14,731 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-07 10:59:15,027 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-07 10:59:15,249 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-07 10:59:15,399 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-07 10:59:16,054 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-07 10:59:16,112 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-07 10:59:16,348 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-07 10:59:16,348 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-01-07 10:59:16,968 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-07 10:59:17,968 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-07 10:59:18,394 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-07 10:59:18,789 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-07 10:59:19,038 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-07 10:59:19,089 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-07 10:59:19,280 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-07 10:59:19,367 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-07 10:59:19,674 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-07 10:59:19,823 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-07 10:59:20,206 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-07 10:59:20,454 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-07 10:59:20,497 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-07 10:59:20,498 INFO [PluginCompilerThread] Started looking for plugins
2012-01-07 10:59:20,673 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-07 10:59:20,709 INFO [WebServer] WebServer starting on port 8895
2012-01-07 10:59:20,719 INFO [EventDispatcher] Starting EventDispatcher
2012-01-07 10:59:20,726 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-07 10:59:20,729 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-07 10:59:20,729 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-07 10:59:20,730 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-07 10:59:20,904 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-07 10:59:50,322 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-07 10:59:51,192 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-07 10:59:52,780 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-07 10:59:52,789 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-07 10:59:52,791 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-07 12:21:30,041 WARN [EventDispatcher] Couldn't send event message for subscription e0cf9bbc-a33b-468d-a6c2-0accfb9f91e7, will keep trying until subscription expires
2012-01-07 12:49:41,693 WARN [EventDispatcher] Couldn't send event message for subscription 0232a6a1-405e-424f-86cd-f8723179a61c, will keep trying until subscription expires
... 3 more
... 13 more
... 7 more
... 2 more
... 12 more
... 6 more
Re: Cant see Files
corrupted Database, you need to start from scratch again,
1. completely unistall serviio
2. reinstall serviio
3. add UNC paths to nas/media serviio console
4. wait till it finishs indexing your files ( DO NOT TURN OFF PC till finished)
5. libaray tab check status and make sure both balls are RED
6. confirm your renderers have correct profiles selected
7. Put the IP of pc running serviio in bound Ip field
8. restart pc running serviio
9. test on devices/renderers
Re: Cant see Files
how do you know when its finishs indexing your files and SHOULD I GO TO THE LOGON SCREEN AND TAKE IT OFF OF LOCAL or SHOULD I LEAVE IT WHERE IT IS AT
Re: Cant see Files
After it gets done indexing you should let it continue to run.
what do you mean???
daffyduck wrote:how do you know when its finishs indexing your files and SHOULD I GO TO THE LOGON SCREEN AND TAKE IT OFF OF LOCAL or SHOULD I LEAVE IT WHERE IT IS AT
what do you mean???
Re: Cant see Files
on some of the faq it said to go to the sevice window in windows and got to the tab that says logon and change that from local user to where you have to add you window user name and password at
Re: Cant see Files
step 5 told you the answer to that. No only do what I have told you to do NOTHING else.
Re: Cant see Files
I did everything you said and I still dont see any videos in the folder I see that folder and that is it
Re: Cant see Files
Depending on how many files you have it can take a while to index your files.
Re: Cant see Files
so what to do now just wait because I only have one file in there that I used as a test file and I already restarted my computer
Re: Cant see Files
daffyduck wrote:so what to do now just wait because I only have one file in there that I used as a test file and I already restarted my computer
if u have restarted already u didnt follow my steps, post an image of library tab and your log file.
Re: Cant see Files
dont know how to post a imag on here but here is my serviio log
2012-01-08 01:54:16,592 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-08 01:54:16,596 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-08 01:54:16,596 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-08 01:54:16,596 INFO [MediaServer] http://www.serviio.org
2012-01-08 01:54:16,596 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-08 01:54:16,597 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-08 01:54:16,597 INFO [MediaServer] File encoding: windows-1252
2012-01-08 01:54:16,598 INFO [MediaServer] Headless mode enabled: true
2012-01-08 01:54:16,598 INFO [MediaServer] User home dir: C:\Windows\System32\config\systemprofile
2012-01-08 01:54:16,598 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-08 01:54:16,598 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-08 01:54:16,811 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-08 01:54:17,095 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-08 01:54:21,073 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-01-08 01:54:24,561 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-08 01:54:25,255 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-08 01:54:25,700 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-08 01:54:25,979 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-08 01:54:26,277 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-08 01:54:26,501 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-08 01:54:26,659 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-08 01:54:27,287 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-08 01:54:27,337 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-08 01:54:27,957 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-08 01:54:28,914 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-08 01:54:29,372 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-08 01:54:29,757 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-08 01:54:29,979 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-08 01:54:30,030 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-08 01:54:30,225 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-08 01:54:30,311 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-08 01:54:30,617 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-08 01:54:30,766 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-08 01:54:31,140 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-08 01:54:31,374 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-08 01:54:37,307 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-08 01:54:37,313 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-01-08 01:54:37,355 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-08 01:54:37,356 INFO [PluginCompilerThread] Started looking for plugins
2012-01-08 01:54:37,904 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-08 01:54:37,963 INFO [WebServer] WebServer starting on port 8895
2012-01-08 01:54:37,971 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-08 01:54:37,972 INFO [EventDispatcher] Starting EventDispatcher
2012-01-08 01:54:37,973 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-08 01:54:37,982 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-08 01:54:37,984 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-08 01:54:38,131 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-08 01:54:43,546 INFO [RendererManager] Stored a new renderer: uuid='7ae5e3e1-1fef-45b2-844b-5719b73beec6', name = 'Unrecognized device', ipAddress='192.168.1.9', profile = '1'
2012-01-08 01:54:44,164 INFO [RendererManager] Stored a new renderer: uuid='1c98f916-a572-4c86-8532-86534e7a9ee1', name = 'Unrecognized device', ipAddress='192.168.1.2', profile = '1'
2012-01-08 01:54:44,899 INFO [RendererManager] Stored a new renderer: uuid='b6432181-b698-498c-81ab-0391c5b04b9d', name = 'Unrecognized device', ipAddress='192.168.1.7', profile = '1'
2012-01-08 01:54:45,736 INFO [RendererManager] Stored a new renderer: uuid='21915738-2505-2000-0000-001dd8601d85', name = 'Xbox 360', ipAddress='192.168.1.7', profile = '3'
2012-01-08 01:55:10,741 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-08 01:55:10,749 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-08 01:55:10,768 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-08 01:55:14,048 INFO [ServiioConsole] Starting Serviio Console
2012-01-08 01:55:14,270 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-01-08 01:55:15,353 INFO [Messages] Loaded console message bundle for locale: en
2012-01-08 01:55:15,369 INFO [UpdateChecker] Checking if a new version is available
2012-01-08 01:55:18,000 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-08 01:55:18,701 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-08 02:37:56,825 INFO [RendererManager] Stored a new renderer: uuid='3756a35d-84fe-413c-a36b-0c86c0a76fbf', name = 'Unrecognized device', ipAddress='192.168.1.1', profile = '1'
2012-01-08 02:42:14,319 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-08 02:42:14,419 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-08 02:42:14,528 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-08 02:42:14,530 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-08 02:42:20,441 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-08 02:42:20,446 INFO [WebServer] WebServer shutting down
2012-01-08 02:42:20,447 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-08 02:42:20,449 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-08 02:42:23,095 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-08 02:42:25,881 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-08 02:42:25,885 INFO [Device] Updated bound IP address of Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-01-08 02:42:25,886 INFO [WebServer] WebServer starting on port 8895
2012-01-08 02:42:25,887 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-08 02:42:25,888 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-08 02:42:25,890 INFO [EventDispatcher] Starting EventDispatcher
2012-01-08 02:42:25,893 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-08 02:42:26,056 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-08 02:42:31,890 INFO [RendererManager] Stored a new renderer: uuid='4f0fc84e-4d7b-47b8-9f81-6bcdd9d6a5a5', name = 'Unrecognized device', ipAddress='192.168.1.9', profile = '1'
2012-01-08 02:42:31,892 INFO [RendererManager] Stored a new renderer: uuid='7d32be9a-7691-412c-bf9c-89c36348d1ec', name = 'Unrecognized device', ipAddress='192.168.1.1', profile = '1'
2012-01-08 02:42:32,942 INFO [RendererManager] Stored a new renderer: uuid='bbe5725f-b3b3-4446-a5d8-b6cc368a63cb', name = 'Unrecognized device', ipAddress='192.168.1.2', profile = '1'
2012-01-08 02:56:12,772 INFO [ServiioConsole] Leaving Serviio Console
2012-01-08 02:56:54,059 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-08 02:56:54,060 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-08 02:56:55,093 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-08 02:56:55,566 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-08 02:56:55,628 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-08 02:56:55,737 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-08 02:56:55,846 INFO [WebServer] WebServer shutting down
2012-01-08 02:56:55,846 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-08 02:56:55,846 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-08 02:57:00,651 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-08 02:57:02,352 INFO [DatabaseManager] Shutting down database
2012-01-08 02:57:09,840 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-08 02:58:45,146 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-08 02:58:45,161 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-08 02:58:45,161 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-08 02:58:45,161 INFO [MediaServer] http://www.serviio.org
2012-01-08 02:58:45,161 INFO [MediaServer] Java 1.6.0_30-Sun Microsystems Inc.
2012-01-08 02:58:45,161 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-08 02:58:45,161 INFO [MediaServer] File encoding: windows-1252
2012-01-08 02:58:45,161 INFO [MediaServer] Headless mode enabled: true
2012-01-08 02:58:45,161 INFO [MediaServer] User home dir: C:\Windows\System32\config\systemprofile
2012-01-08 02:58:45,161 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-08 02:58:45,161 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-08 02:58:46,191 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-08 02:58:46,456 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-08 02:59:00,621 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-08 02:59:02,718 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-08 02:59:03,709 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-08 02:59:04,473 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-08 02:59:05,004 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-08 02:59:05,316 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-08 02:59:05,565 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-08 02:59:07,079 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-08 02:59:07,125 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-08 02:59:08,514 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-08 02:59:10,682 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-08 02:59:11,244 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-08 02:59:11,805 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-08 02:59:12,086 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-08 02:59:12,195 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-08 02:59:12,476 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-08 02:59:12,601 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-08 02:59:13,085 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-08 02:59:13,303 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-08 02:59:13,771 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-08 02:59:14,021 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-08 02:59:14,645 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-08 02:59:14,660 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-01-08 02:59:14,832 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-08 02:59:14,847 INFO [PluginCompilerThread] Started looking for plugins
2012-01-08 02:59:18,903 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-08 02:59:19,247 INFO [WebServer] WebServer starting on port 8895
2012-01-08 02:59:19,247 INFO [EventDispatcher] Starting EventDispatcher
2012-01-08 02:59:19,247 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-08 02:59:19,247 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-08 02:59:19,247 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-08 02:59:19,262 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-08 02:59:19,575 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
2012-01-08 02:59:45,799 INFO [ServiioConsole] Starting Serviio Console
2012-01-08 02:59:48,529 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-01-08 02:59:55,642 INFO [Messages] Loaded console message bundle for locale: en
2012-01-08 02:59:56,017 INFO [UpdateChecker] Checking if a new version is available
2012-01-08 03:00:01,680 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-08 03:00:01,726 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-08 03:00:01,758 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-08 03:00:13,574 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-08 03:00:15,341 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
Re: Cant see Files
Can you enable detailed logging. See signature on how to enable it. And post a new log
Re: Cant see Files
HERE IS THE LOG
2012-01-08 04:14:20,116 INFO [WebServer] WebServer shutting down
2012-01-08 04:14:20,116 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-08 04:14:20,132 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-08 04:14:20,132 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-08 04:14:20,272 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-08 04:14:23,002 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-08 04:14:27,424 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-08 04:14:27,424 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-08 04:14:27,455 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-08 04:14:27,455 INFO [EventDispatcher] Starting EventDispatcher
2012-01-08 04:14:27,455 INFO [WebServer] WebServer starting on port 8895
2012-01-08 04:14:27,568 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (RangeMax Wireless-N USB Adapter WN111v2) and address 192.168.1.9, timeout = 0
Re: Cant see Files
- Code:
Welcome to the Serviio Wiki. This space is intended to store community knowledge about Serviio and it's various setups. You can post and update working installation tutorials, startup scripts and similar.
You can enable DEBUG level for the logger to see detailed logs. Edit file log4j.xml in config folder and change this:
<category name="org.serviio">
<priority value="INFO"/>
</category>to:
<priority value="DEBUG"/>
</category>Restart Serviio server (if on Windows restart Serviio Windows service)
Read the result in serviio.log in log folder inside Serviio installation directory (Mac users have to 'browse contents' of Serviio.app). Make sure to revert the change back later otherwise your log file will be huge.
If the file is too huge and your problem is not related to library updates, you can filter those out.
• Page 1 of 3 • 1, 2, 3
Users browsing this forum: No registered users and 62 guests
