Re: Android Console
OK ill fix that. For now you can turn the notification off under preferences. It is because everything is destroyed and recreated on rotate.
moleculezz wrote:Hi again,
I took some time to look at the tabs, and thought I might share some of my experience.
My first thought was to have all the tabs in view, so that you don't need to swipe many times to get to the other tabs. The Twitter app seem to be doing this nicely. But I think in this case, space might be an issue. I did find some nice icon fonts that you might be able to use to change the tabs into icons instead of using text. But these are just some thoughts to help out with the UI.
If you wanna keep the current setup of the tabs maybe adding some borders to the tabs and some extra space would make them feel more like buttons. Take a look at the Google Music app. They seem to have the same idea as what you are trying to accomplish.
Xmantium wrote:Im loving the new beta 8!![]()
Finding serviio server works amazing! Brilliant job!
Ive noticed, when i close the app using Task Manager on my phone, you could use a similiar application close app, it doesnt auto connect to the last server used, instead its the list of Serviio found
But if i close the app using "back" on the phone buttons and launch the app it does auto connect to the last server used
*Fixed crash on download introduced in Beta 8 by mistake
*Fixed autoconnect after being killed by a task manager
*Fixed being notified about app updates on screen rotate
*Fixed being notified about server updates on screen rotate
*Added button to ignore server updates until a new version is available
*Aligned indent of the presentation list
*Added radio button to idicate the current visibility when changing presentation visibilty
*Improved performance of the presentation list
*Added extra error checking
*Added #3 metadata settings
*Finished #1 presentation settings
*Added prompt for Serviio forum username so that I can PM you if I can't fix a bug with just the crash report
*Refdata will use locally translated strings if they exist
*Re-wrote refdata fetching (Hopefully this will fix #19)
*Added #2 library settings
*Transcoding settings enable and dissable with the main setting
Note: You may not be able to install it directly from you browser's download manager as they often require that the apps are served as an 'application/vnd.android.package-archive' by the HTTP server. If you get a 'cannot open file'/'no program available' error, then please use a file manager to open and install the .apk as they use file extentions to determine the type of file.
will wrote:Did you read the wikiNote: You may not be able to install it directly from you browser's download manager as they often require that the apps are served as an 'application/vnd.android.package-archive' by the HTTP server. If you get a 'cannot open file'/'no program available' error, then please use a file manager to open and install the .apk as they use file extentions to determine the type of file.
will wrote:I assume most people who use android will have some sort of file manager installed surely?
The following should work
https://market.android.com/details?id=com.rhmsoft.fm
https://market.android.com/details?id=l ... ndexplorer
https://market.android.com/details?id=com.metago.astr
will wrote:Certainly for when It is released properly, during this stage of early testing I assumed that most non techy people would shy away from it, not even notice it.
I've put a few suggestions on the wiki about it.
Provided there is enough interest, which I think there should be, once I'm happy with it I'll proably pay for a developer account so that I can host it on android market.
will wrote:Thanks. Its about £16 so not very much.
I might do a free version and an identical cheapo donate version. If people don't want to donate, I still want to give them all the features/no adds or limitations.
Anyway, lots of things left to do first.
Any feedback on the app as someone who hasn't used it yet? Anything that was not obvious at first, seamed out of place/not how you expected it to work?
