[Solved] Ver 6.1 broke presentation options
PVRone
Post Mon Jan 09, 2012 12:46 am
I have a C series (550) TV and now that I updated to 6.1 the media play menu on the tv does not work anymore :( 6.01 works fine
seviio is putting all my files (audio,video and pics) into every dir now . each dir has all files and folders regardless of file type
If I re install 6.01 everything is working fine (i'm using the exact same setting for both versions)
How can I get rid of the stupid update message !! I don't want 6.1 till this issue is fixed (If it isn't broke I don't want the broken update ;)
Before video Only had video files audio only had audio files and pictures only had Pictures in 6.1 every cat has all folders and files in each one :(
Eagles may soar but Beavers don't get sucked into jet engines..
Post Mon Jan 09, 2012 12:50 am
Re: Ver 6.1 broke presentation options
This will fix it for now. There will be a new release with fixes soon. viewtopic.php?f=10&t=4670#p31986
PVRone
Post Mon Jan 09, 2012 1:17 am
Thanks zip
I guess I can live with the update popup till then ;)
Just a suggestion here why not have an option in the update message check box don't show again
The message isn't that bad but it pops up the console every time you reboot the computer and that is whats very annoying lol
Thanks for the quick reply and of course for this great program ;)
Cheers
Post Mon Jan 09, 2012 5:45 am
PVRone wrote:Thanks zip
Cheers
cause to many people would click no and then complain that a function does work cause they have older version that doesnt support it
PVRone
Post Mon Jan 09, 2012 6:07 am
what about a remind me later function which will pop it up again every 48 -72 hrs as an example .
That would give us enough time to wait for a fix if something wasn't working anymore or incorrectly
Just an idea
PS If you have a disclaimer stating that this is at your own risk and further support is only available to current releases
Legally we will running the old version at our own risk and waive any liability (if this were to be a issue)
Any ways as far as my issue that I posted I'll wait till the update rather than edit my config file so no real biggie
I am glad you were aware of it :)
eclp
Post Mon Jan 09, 2012 7:54 am
Cerberus wrote:cause to many people would click no and then complain that a function does work cause they have older version that doesnt support it
Excuse but I totally disagree.
Each user has the right to determine themselves. I want to decide for themselves whether I would like to be notified. Just two examples. Also in Java I can decide when or Adbobe Reader I can disable this feature. And many more applications ...
1. I wish I could turn off the notification.
2. I want to disable automatic updates.
Sorry my bad English.
Post Mon Jan 09, 2012 10:21 am
if you want support you use latest version, simples.
PVRone
Post Wed Jan 11, 2012 9:19 pm
Re: [Solved] Ver 6.1 broke presentation options
well I gave in and edited my config and it works again ,Thanks again ;)
