Sony SMP-N100 can't see Serviio
toblerone
Post Mon Jan 09, 2012 6:36 pm
Hi all, hope someone can help. I'm totally new to networking and am having major issues. I set up Serviio on my Windows XP PC with the aim of streaming video to my new SMP-N100 media player. The media player is connected to the network and internet fine, but can't see Serviio as a source in any category (photo, music or video).
When in the Serviio console (0.6.1), the device didn't show up automatically. I've added it and inputted the IP Address and selected the Sony BD Player/SMP profile. There's an orange dot next to it and I've checked that I have 3 folders set to share, but still nothing showing up on the media player.
Anyone have any suggestions for what I need to do to fix this?
Post Mon Jan 09, 2012 6:46 pm
Re: Sony SMP-N100 can't see Serviio
1. set reserved/prefered IP address's for all devices on your network (do this from your router).
2. enter the IP of the pc running serviio into the bound IP field of console.
3. restart pc running serviio
4. check the properties of your media folders and see if SYSTEM has access to them.
5. if that fails post your serviio log file here ( use attach file rather than pasting it )
toblerone
Post Mon Jan 09, 2012 7:34 pm
Hi, thanks for the reply. I have an Echolife HG521 router, but I can't see anywhere in the control panel to set reserved IP addresses. I've inputted the bound IP field and restarted. Not sure how to check the properties of the folders to see if SYSTEM has access? The log file is attached.
Thanks for your help, this is all very frustrating for people new to this.
(408.59 KiB) Downloaded 759 times
Post Mon Jan 09, 2012 7:40 pm
edited logs are next to useless to me, although it does tell me its not a permissions issue.
EDIT: after a quick google it seem you cant set reserved ip with that router, so buying a better router is recommended.
Post Mon Jan 09, 2012 7:44 pm
What are your devices address, could you list them?
Your log file is not complete.Suggest :
- Stop serviio service
- remove/delete serviio.log file
- Start serviio service
- repost serviio.log after a few minutes
toblerone
Post Mon Jan 09, 2012 8:10 pm
Sorry, I'm confused. I followed the instructions in the forum sticky to get the log, i.e http://forum.serviio.org/viewtopic.php?f=5&t=7. I didn't edit anything, but have followed Illico's advice, new log attached.
Unfortunately, buying a better router isn't an option as I connect via my landlady's router which is in her apartment downstairs. She's away for 3 months so I don't have easy access to it, only the control panel.
The addresses on the network are:
Router- 192.168.1.1
Laptop- 192.168.1.2
PC: 192.168.1.3 (where Serviio is installed)
SMP-N100: 192.168.1.50.
Currently when I ping the media player from the PC I get 'request timed out'. When I ping the media player from the laptop, I get 'Destination host unreachable'.
(94.95 KiB) Downloaded 782 times
WildRushSykes
Post Mon Jan 09, 2012 8:21 pm
That log dosent help at all as its all library additions could you delete the log and restart serviio and post the new log in its entirety. Thanks
toblerone
Post Mon Jan 09, 2012 8:37 pm
Third time lucky, I hope.
(9.18 KiB) Downloaded 767 times
WildRushSykes
Post Mon Jan 09, 2012 8:41 pm
bound address: 192.168.1.3 <----- not sure but that might be the issue are there any other device mapped in the landladys router that may affect serviio?
toblerone
Post Mon Jan 09, 2012 8:49 pm
No, I have the only computers in the house at the moment. She has a laptop, but she's taken it with her. I had the same problem even when the bound address field was blank. I can't think of any other applications that might be blocking anything, I'm utterly stumped.
WildRushSykes
Post Mon Jan 09, 2012 8:51 pm
could you post a screenshot of the devices setup in the routers control panel? Also could you make sure all your devices have static ip addresses.
toblerone
Post Mon Jan 09, 2012 9:10 pm
Screenshots of the main screens attached, if there's something else you need a shot of then please let me know.
WildRushSykes
Post Mon Jan 09, 2012 9:28 pm
Can you reset the router via the control panel and let all your devices assign ip addresses via dhcp? also clear your bound ip address field aswell.
Post Tue Jan 10, 2012 10:12 am
My suggestion :
Set all devices addresses on the network like this:
Router - 192.168.1.1
Laptop - 192.168.1.2
PC - 192.168.1.3 (where Serviio is installed)
SMP-N100: 192.168.1.4.
Open router configuration
"DHCP server" section
Change "Start IP address : 192.168.1.20"
So all IP address
- from 192.168.1.1 to 192.168.1.19 are reserved for fixed devices that you usually used (see previous list), not in DHCP server area.
- from 192.168.1.20 to 192.168.1.254 are for new nomad or external devices, on DHCP server area.
georgiuk
Post Mon Feb 27, 2012 1:58 am
I reopen this thread as i have the same problem. I am using serviio 0.6.2 on windows 7 x64 and I am trying to use it with sony smp-n100. So I have
192.168.1.30 sony smp-n100
192.168.1.2 my laptop (serviio)
my router is a bautec one.
So in smp Network Settings I am trying to find serviio and it doesn't appear. The serviio log says
2012-02-24 21:52:47,857 INFO  [MediaServer] ------------------------------------------------------------------------
2012-02-24 21:52:47,867 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-02-24 21:52:47,867 INFO  [MediaServer] Petr Nejedly 2009-2011
2012-02-24 21:52:47,867 INFO  [MediaServer] http://www.serviio.org
2012-02-24 21:52:47,867 INFO  [MediaServer] Java 1.7.0_02-Oracle Corporation
2012-02-24 21:52:47,867 INFO  [MediaServer] OS Windows 7 amd64 6.1
2012-02-24 21:52:47,868 INFO  [MediaServer] File encoding: windows-1253
2012-02-24 21:52:47,868 INFO  [MediaServer] Headless mode enabled: true
2012-02-24 21:52:47,868 INFO  [MediaServer] User home dir: C:\
2012-02-24 21:52:47,869 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2012-02-24 21:52:47,869 INFO  [MediaServer] ------------------------------------------------------------------------
2012-02-24 21:52:48,418 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2012-02-24 21:52:48,614 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-02-24 21:53:01,249 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2012-02-24 21:53:14,433 INFO  [ServiioConsole] Starting Serviio Console
2012-02-24 21:53:18,046 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-02-24 21:53:23,326 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-02-24 21:53:24,412 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-02-24 21:53:24,793 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-02-24 21:53:25,024 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-02-24 21:53:25,363 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-02-24 21:53:25,529 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-02-24 21:53:25,661 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-02-24 21:53:26,418 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-02-24 21:53:26,444 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-02-24 21:53:26,808 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-02-24 21:53:27,444 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-02-24 21:53:27,801 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-02-24 21:53:27,999 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-02-24 21:53:28,125 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-02-24 21:53:28,152 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-02-24 21:53:28,245 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-02-24 21:53:28,286 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-02-24 21:53:28,453 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-02-24 21:53:28,532 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-02-24 21:53:28,768 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-02-24 21:53:28,889 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-02-24 21:53:36,033 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-02-24 21:53:36,034 INFO  [Device] Created UPnP Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2012-02-24 21:53:36,108 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-02-24 21:53:36,114 INFO  [PluginCompilerThread] Started looking for plugins
2012-02-24 21:53:36,407 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-02-24 21:53:36,457 INFO  [WebServer] WebServer starting on port 8895
2012-02-24 21:53:36,471 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-24 21:53:36,472 INFO  [EventDispatcher] Starting EventDispatcher
2012-02-24 21:53:36,484 INFO  [RendererSearchSender] Searching for Renderer devices
2012-02-24 21:53:36,484 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-02-24 21:53:36,485 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-24 21:53:36,596 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net5 (Broadcom 802.11n Network Adapter) and address 192.168.1.4, timeout = 0
2012-02-24 21:53:44,855 INFO  [RendererManager] Stored a new renderer: uuid='f92ada68-58f9-476a-9cd0-aaeb29a67f0a', name = 'Unrecognized device', ipAddress='192.168.1.5', profile = '1'
2012-02-24 21:53:47,835 INFO  [Messages] Loaded console message bundle for locale: en
2012-02-24 21:53:47,854 INFO  [UpdateChecker] Checking if a new version is available
2012-02-24 21:53:53,134 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-02-24 21:53:53,887 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-02-24 21:54:07,308 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-02-24 21:54:07,310 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-02-24 21:54:07,311 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-02-24 21:55:56,303 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-24 21:55:56,319 INFO  [WebServer] WebServer shutting down
2012-02-24 21:55:56,351 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-24 21:55:56,358 INFO  [EventDispatcher] Leaving EventDispatcher
2012-02-24 21:55:56,489 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-02-24 21:56:02,808 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-25 16:09:59,537 INFO  [ServiioConsole] Leaving Serviio Console
2012-02-25 16:10:30,821 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-02-25 16:10:30,821 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-02-25 16:10:30,822 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-02-25 16:10:30,921 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-02-25 16:10:31,021 INFO  [FeedUpdaterThread] Finished looking for online resources information
2012-02-25 16:10:31,121 INFO  [PluginCompilerThread] Finished looking for plugins
2012-02-25 16:10:31,221 INFO  [DatabaseManager] Shutting down database
2012-02-25 16:10:54,516 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-02-25 16:15:56,573 INFO  [ServiioConsole] Starting Serviio Console
2012-02-25 16:15:56,631 INFO  [MediaServer] ------------------------------------------------------------------------
2012-02-25 16:15:56,799 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-02-25 16:15:56,800 INFO  [MediaServer] Petr Nejedly 2009-2011
2012-02-25 16:15:56,800 INFO  [MediaServer] http://www.serviio.org
2012-02-25 16:15:56,800 INFO  [MediaServer] Java 1.7.0_02-Oracle Corporation
2012-02-25 16:15:56,800 INFO  [MediaServer] OS Windows 7 amd64 6.1
2012-02-25 16:15:56,800 INFO  [MediaServer] File encoding: windows-1253
2012-02-25 16:15:56,887 INFO  [MediaServer] Headless mode enabled: true
2012-02-25 16:15:56,887 INFO  [MediaServer] User home dir: C:\
2012-02-25 16:15:56,887 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2012-02-25 16:15:56,888 INFO  [MediaServer] ------------------------------------------------------------------------
2012-02-25 16:16:00,713 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2012-02-25 16:16:04,287 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-02-25 16:16:09,690 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-02-25 16:21:36,843 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-02-25 16:21:39,125 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-02-25 16:21:40,089 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-02-25 16:21:40,834 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-02-25 16:21:41,379 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-02-25 16:21:41,537 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-02-25 16:21:41,633 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-02-25 16:21:42,080 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-02-25 16:21:42,112 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-02-25 16:21:42,644 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-02-25 16:21:43,209 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-02-25 16:21:43,465 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-02-25 16:21:43,662 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-02-25 16:21:43,776 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-02-25 16:21:43,801 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-02-25 16:21:43,889 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-02-25 16:21:43,928 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-02-25 16:21:44,076 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-02-25 16:21:44,159 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-02-25 16:21:44,353 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-02-25 16:21:44,473 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-02-25 16:21:55,903 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-02-25 16:21:55,904 INFO  [Device] Created UPnP Device with UUID: 95bd863e-03ad-37fb-b99b-831f014dbd89, bound address: 10.10.199.197
2012-02-25 16:21:56,128 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-02-25 16:21:56,130 INFO  [PluginCompilerThread] Started looking for plugins
2012-02-25 16:21:58,145 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-02-25 16:21:59,098 INFO  [WebServer] WebServer starting on port 8895
2012-02-25 16:22:00,249 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-25 16:22:00,257 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-25 16:22:00,284 INFO  [EventDispatcher] Starting EventDispatcher
2012-02-25 16:22:00,295 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-02-25 16:22:00,296 INFO  [RendererSearchSender] Searching for Renderer devices
2012-02-25 16:22:00,389 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth5 (Shrew Soft Virtual Adapter) and address 10.10.199.197, timeout = 0
2012-02-25 16:22:12,304 INFO  [Messages] Loaded console message bundle for locale: en
2012-02-25 16:22:12,322 INFO  [UpdateChecker] Checking if a new version is available
2012-02-25 16:22:26,304 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-02-25 16:22:27,250 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-02-25 16:22:31,931 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-02-25 16:22:31,934 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-02-25 16:22:31,936 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-02-25 16:23:34,486 INFO  [EventDispatcher] Leaving EventDispatcher
2012-02-25 16:23:34,487 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-25 16:23:34,488 INFO  [WebServer] WebServer shutting down
2012-02-25 16:23:34,501 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-25 16:23:35,295 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-02-25 16:23:41,662 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-27 02:18:00,636 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-02-27 02:18:00,735 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-02-27 02:18:00,871 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-02-27 02:18:00,927 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-02-27 02:18:05,263 INFO  [LibraryAdditionsCheckerThread] Added file '01 - Under the bridge.mp3' (title: Under the bridge) to Library
2012-02-27 02:18:05,390 INFO  [LibraryAdditionsCheckerThread] Added file '02 - Give it away.mp3' (title: Give it away) to Library
2012-02-27 02:18:05,511 INFO  [LibraryAdditionsCheckerThread] Added file '03 - Californication.mp3' (title: Californication) to Library
2012-02-27 02:18:05,647 INFO  [LibraryAdditionsCheckerThread] Added file '04 - Scar Tissue.mp3' (title: Scar Tissue) to Library
2012-02-27 02:18:05,863 INFO  [LibraryAdditionsCheckerThread] Added file '05 - Soul to squueze.mp3' (title: Soul to squueze) to Library
2012-02-27 02:18:05,965 INFO  [LibraryAdditionsCheckerThread] Added file '06 - Otherside.mp3' (title: Otherside) to Library
2012-02-27 02:18:06,037 INFO  [LibraryAdditionsCheckerThread] Added file '07 - Stuck by kiss.mp3' (title: Stuck by kiss) to Library
2012-02-27 02:18:06,235 INFO  [LibraryAdditionsCheckerThread] Added file '08 - By the way.mp3' (title: By the way) to Library
2012-02-27 02:18:06,385 INFO  [LibraryAdditionsCheckerThread] Added file '09 - Parallel universe.mp3' (title: Parallel universe) to Library
2012-02-27 02:18:06,497 INFO  [LibraryAdditionsCheckerThread] Added file '10 - Breaking the girl.mp3' (title: Breaking the girl) to Library
2012-02-27 02:18:06,648 INFO  [LibraryAdditionsCheckerThread] Added file '11 - My friends.mp3' (title: My friends) to Library
2012-02-27 02:18:06,802 INFO  [LibraryAdditionsCheckerThread] Added file '12 - Higher ground.mp3' (title: Higher ground) to Library
2012-02-27 02:18:06,958 INFO  [LibraryAdditionsCheckerThread] Added file '13 - Universally speaking.mp3' (title: Universally speaking) to Library
2012-02-27 02:18:07,146 INFO  [LibraryAdditionsCheckerThread] Added file '14 - Road trippin.mp3' (title: Road trippin) to Library
2012-02-27 02:18:07,223 INFO  [LibraryAdditionsCheckerThread] Added file '15 - Fortune faded.mp3' (title: Fortune faded) to Library
2012-02-27 02:18:07,346 INFO  [LibraryAdditionsCheckerThread] Added file '16 - Save the population.mp3' (title: Save the population) to Library
2012-02-27 02:18:12,165 INFO  [WebServer] WebServer starting on port 8895
2012-02-27 02:18:12,201 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-27 02:18:12,201 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-27 02:18:12,201 INFO  [RendererSearchSender] Searching for Renderer devices
2012-02-27 02:18:12,213 INFO  [EventDispatcher] Starting EventDispatcher
2012-02-27 02:18:12,688 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface Unknown and address 10.10.199.197, timeout = 0
2012-02-27 02:25:49,032 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-27 02:25:49,041 INFO  [WebServer] WebServer shutting down
2012-02-27 02:25:49,053 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-27 02:25:49,053 INFO  [EventDispatcher] Leaving EventDispatcher
2012-02-27 02:25:51,068 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-27 02:25:51,089 INFO  [WebServer] WebServer starting on port 8895
2012-02-27 02:25:51,089 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-27 02:25:51,093 INFO  [EventDispatcher] Starting EventDispatcher
2012-02-27 02:25:51,093 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-27 02:25:51,093 INFO  [RendererSearchSender] Searching for Renderer devices
2012-02-27 02:25:51,303 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface Unknown and address 10.10.199.197, timeout = 0
2012-02-27 02:31:36,930 INFO  [RendererManager] Stored a new renderer: uuid='79c09a6b-7012-4a7d-898b-2cce665862e2', name = 'Unrecognized device', ipAddress='192.168.1.2', profile = '1'
2012-02-27 02:40:45,598 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-27 02:40:45,598 INFO  [EventDispatcher] Leaving EventDispatcher
2012-02-27 02:40:45,598 INFO  [WebServer] WebServer shutting down
2012-02-27 02:40:45,598 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-27 02:40:48,138 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-27 02:40:48,144 INFO  [RendererSearchSender] Searching for Renderer devices
2012-02-27 02:40:48,221 INFO  [WebServer] WebServer starting on port 8895
2012-02-27 02:40:48,184 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-27 02:40:48,184 INFO  [EventDispatcher] Starting EventDispatcher
2012-02-27 02:40:48,184 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-27 02:40:48,522 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface Unknown and address 10.10.199.197, timeout = 0
2012-02-27 03:00:18,843 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-27 03:00:18,846 INFO  [WebServer] WebServer shutting down
2012-02-27 03:00:18,847 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-27 03:00:18,874 INFO  [EventDispatcher] Leaving EventDispatcher
2012-02-27 03:00:22,731 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-27 03:00:49,962 INFO  [WebServer] WebServer starting on port 8895
2012-02-27 03:00:49,969 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-27 03:00:49,969 INFO  [RendererSearchSender] Searching for Renderer devices
2012-02-27 03:00:49,973 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-27 03:00:50,008 INFO  [EventDispatcher] Starting EventDispatcher
2012-02-27 03:00:50,386 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface Unknown and address 10.10.199.197, timeout = 0
2012-02-27 03:23:08,710 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-27 03:23:08,711 INFO  [WebServer] WebServer shutting down
2012-02-27 03:23:08,711 INFO  [EventDispatcher] Leaving EventDispatcher
2012-02-27 03:23:08,711 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-27 03:23:11,645 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-02-27 03:23:13,966 INFO  [WebServer] WebServer starting on port 8895
2012-02-27 03:23:13,969 INFO  [RendererSearchSender] Searching for Renderer devices
2012-02-27 03:23:13,971 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-02-27 03:23:13,974 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-02-27 03:23:13,976 INFO  [EventDispatcher] Starting EventDispatcher
2012-02-27 03:23:14,336 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface Unknown and address 10.10.199.197, timeout = 0
2012-02-27 03:35:25,340 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-02-27 03:35:25,342 INFO  [EventDispatcher] Leaving EventDispatcher
2012-02-27 03:35:25,344 INFO  [WebServer] WebServer shutting down
2012-02-27 03:35:25,346 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-02-27 03:35:28,347 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
Thank you
Kostas
