Hulu (US only)
Post Thu Jan 05, 2012 8:51 pm
Hulu (US only)
Note that it looks like RSS feeds are now discontinued at Hulu, so this plugin will not work.
Plugin for feeds from hulu.com. Requires at least Serviio 0.6.1.
Added 5/1/2012
Fixed 11/1/2012
Updated 22/9/2012
Updated 06/10/2012
Hulu.groovy
(4.27 KiB) Downloaded 5226 times
rocketjordon
Post Fri Jan 06, 2012 10:33 pm
Re: Hulu (US only)
WOW!!
This is great work ZIP! Absolutely fantastic! Works Super!
Thanx!
So... anyway to make Hulu Plus work with this. As said above it is already super as it is, but for us who already have Hulu Plus it would of course be kool if it would work with the plugin as well.
Anyway, thanx for the great work you've put in to Serviio and all things surounding it!
Post Fri Jan 06, 2012 10:36 pm
Re: Hulu (US only)
I assume there is some kind of login required. That is not possible with the plugins currently.
rocketjordon
Post Sun Jan 08, 2012 8:21 am
Re: Hulu (US only)
zip wrote:I assume there is some kind of login required. That is not possible with the plugins currently.
Yes login required. Well nevermind, it is alredy super as it is.
paultry
Post Mon Jan 09, 2012 5:23 pm
Re: Hulu (US only)
Wonder why some Hulu feeds work for me when others don't.
Examples:
These work:
http://www.hulu.com/feed/show/58/episodes
http://www.hulu.com/feed/show/2103/episodes
These don't ("There is no playable file"):
http://www.hulu.com/feed/show/12/episodes
http://www.hulu.com/feed/show/172/episodes
All are Source Type Online RSS/Atom Feed
All work with Google Reader
Windows 7
Sony BDP-S570
Alabama, USA
Windows 7
Sony BDP-S570
Alabama, USA
Post Mon Jan 09, 2012 8:57 pm
Re: Hulu (US only)
is there anything in the log?
paultry
Post Mon Jan 09, 2012 9:55 pm
Re: Hulu (US only)
More in the log than I can decipher, but this may be relevant:
2012-01-09 15:01:28,658 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.hulu.com/released/episodes?h ... has_free=1. Message: Error during feed parsing : Invalid XML: Error on line 282: The element type "link" must be terminated by the matching end-tag "</link>".
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:177)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
Windows 7
Sony BDP-S570
Alabama, USA
Post Tue Jan 10, 2012 9:33 am
Re: Hulu (US only)
looks like a dodgy XML feed
Post Wed Jan 11, 2012 1:19 pm
Re: Hulu (US only)
Zip I had to reinstall everything do to a harddrive crash that took out my OS.
I installed 0.6.1, copied the plugins to the plugin directory. tried 4 different rss links from HULU none of them worked. I will post any errors when I get home from work today. The links I tried was for wipeout, 16 and pregnant, The lying Game. I do not remember the last. But I will post the information in the log this afternoon.
Post Wed Jan 11, 2012 1:22 pm
Re: Hulu (US only)
Are you in US?
Post Wed Jan 11, 2012 1:31 pm
Re: Hulu (US only)
yes, ohio
Post Wed Jan 11, 2012 1:38 pm
Re: Hulu (US only)
check the log
paultry
Post Wed Jan 11, 2012 5:31 pm
Re: Hulu (US only)
zip wrote:looks like a dodgy XML feed
I turned on detailed logging and got this log info for one of the Hulu shows (Emergency) which won't work with Serviio but does work with Google reader:
2012-01-11 11:19:47,667 DEBUG [OnlineLibraryManager] Resource http://www.hulu.com/feed/show/172/episodes not in cache yet, loading it
2012-01-11 11:19:47,668 DEBUG [FeedParser] Parsing feed 'http://www.hulu.com/feed/show/172/episodes'
2012-01-11 11:19:48,230 DEBUG [FeedParser] Found matching url extractor (Hulu (US only)) for resource http://www.hulu.com/feed/show/172/episodes
2012-01-11 11:19:48,230 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e22 - 905-Wild
2012-01-11 11:19:48,382 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e22 - 905-Wild: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 58ede58ce5
2012-01-11 11:19:48,382 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e21 - Back-Up
2012-01-11 11:19:48,483 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e21 - Back-Up: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 58814c8dee
2012-01-11 11:19:48,483 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e20 - The Mouse
2012-01-11 11:19:48,660 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e20 - The Mouse: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 58ede58ce5
2012-01-11 11:19:48,660 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e19 - It's How You Play the Game
2012-01-11 11:19:48,773 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e19 - It's How You Play the Game: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 58814c8dee
2012-01-11 11:19:48,775 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e18 - Prestidigitation
2012-01-11 11:19:48,892 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e18 - Prestidigitation: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 58814c8dee
2012-01-11 11:19:48,892 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e17 - Kidding
2012-01-11 11:19:49,006 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e17 - Kidding: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 58814c8dee
2012-01-11 11:19:49,006 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e16 - The Smoke Eater
2012-01-11 11:19:49,113 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e16 - The Smoke Eater: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... edf128c993
2012-01-11 11:19:49,113 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e15 - Transition
2012-01-11 11:19:49,226 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e15 - Transition: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... edf128c993
2012-01-11 11:19:49,226 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e14 - The Bash
2012-01-11 11:19:49,319 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e14 - The Bash: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... edf128c993
2012-01-11 11:19:49,320 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e13 - The Parade
2012-01-11 11:19:49,416 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e13 - The Parade: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... c86ecd921c
2012-01-11 11:19:49,416 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e12 - Details
2012-01-11 11:19:49,516 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e12 - Details: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... edf128c993
2012-01-11 11:19:49,517 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e11 - Firehouse Four
2012-01-11 11:19:49,628 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e11 - Firehouse Four: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... edf128c993
2012-01-11 11:19:49,628 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e10 - The Camera Bug
2012-01-11 11:19:49,743 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e10 - The Camera Bug: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... edf128c993
2012-01-11 11:19:49,743 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e9 - Foreign Trade
2012-01-11 11:19:49,837 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e9 - Foreign Trade: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... edf128c993
2012-01-11 11:19:49,837 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e8 - Quicker Than the Eye
2012-01-11 11:19:49,950 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e8 - Quicker Than the Eye: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... edf128c993
2012-01-11 11:19:49,950 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e7 - Daisy's Pick
2012-01-11 11:19:50,141 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e7 - Daisy's Pick: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... edf128c993
2012-01-11 11:19:50,142 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e6 - Surprise
2012-01-11 11:19:50,259 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e6 - Surprise: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 6084a21ee2
2012-01-11 11:19:50,259 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e5 - Communication Gaffe
2012-01-11 11:19:50,352 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e5 - Communication Gaffe: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 6084a21ee2
2012-01-11 11:19:50,352 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e4 - Nagging Suspicion
2012-01-11 11:19:50,450 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e4 - Nagging Suspicion: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 6084a21ee2
2012-01-11 11:19:50,450 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Emergency! - s4 | e3 - Gossip
2012-01-11 11:19:50,561 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Emergency! - s4 | e3 - Gossip: Server returned HTTP response code: 400 for URL: http://s.hulu.com/select.ashx?video_id= ... 6084a21ee2
2012-01-11 11:19:50,561 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://www.hulu.com/feed/show/172/episodes' in the cache (online_feeds), returning it
2012-01-11 11:19:50,561 DEBUG [OnlineLibraryManager] Feed http://www.hulu.com/feed/show/172/episodes will expire in the cache on Thu Jan 12 11:19:50 CST 2012
2012-01-11 11:20:22,189 DEBUG [WebServer] I/O error: Connection reset
Any ideas on what may be causing the errors?
Windows 7
Sony BDP-S570
Alabama, USA
Post Wed Jan 11, 2012 10:52 pm
Re: Hulu (US only)
Updated the plugin in the first post, try it now.
Post Thu Jan 12, 2012 6:37 pm
Re: Hulu (US only)
2012-01-12 03:55:27,945 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEbOcFaKaEchdjcqdja3dudpbMbOalbocs-bpdP__-c0-WpGBxCn0HAv&aifp=sll02152008&slist=hulu11/410/40026410;.international=false&hgt=OZU7Pvs7j27-nhteNno7wrXeIA64S6tjiQ2Yim1arG5JGVdsbusA3DIUwwfLmrDA6ugvvXAFenmzzT63PghkTkuDv0YUyghZtiWSSW_9oAz6UAOoAnVQ4cGKXkopMhRH1GGtE_mSIFLZCqQZPRpCViNVsfS_wq-574Zea1QKf_RvPe8rpJH27hW_isF6feBhMEspO3c9x4FGYlB5I7G0Od1TkKkq2F0f0hF5Rj_WGpJA87kI1rZfLf1a-SzaPsV1&hgt_ver=331370278 app=ondemand?auth=daEbOcFaKaEchdjcqdja3dudpbMbOalbocs-bpdP__-c0-WpGBxCn0HAv&aifp=sll02152008&slist=hulu11/410/40026410;.international=false&hgt=OZU7Pvs7j27-nhteNno7wrXeIA64S6tjiQ2Yim1arG5JGVdsbusA3DIUwwfLmrDA6ugvvXAFenmzzT63PghkTkuDv0YUyghZtiWSSW_9oAz6UAOoAnVQ4cGKXkopMhRH1GGtE_mSIFLZCqQZPRpCViNVsfS_wq-574Zea1QKf_RvPe8rpJH27hW_isF6feBhMEspO3c9x4FGYlB5I7G0Od1TkKkq2F0f0hF5Rj_WGpJA87kI1rZfLf1a-SzaPsV1&hgt_ver=331370278 playpath=mp4:hulu11/410/40026410/agave50183380_5835961_H264_650.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:272)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:254)
   ... 2 more
2012-01-12 03:55:29,185 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEckckdxbfaSdebsa7aVdBcEdrbJdUa2dF-bpdQaa-c0-WpFEuDsYEAq&aifp=sll02152008&slist=hulu11/635/40023635;.international=false&hgt=OZU7Pvs7j27-nhteNno7wrPRtGAQW3gH6sK__uZqcmH5a6d4PVeZFOVfpsBvLrdqse0-DR7TmioOMjLvkW3DDdDd1y3heFZ2GrgyRrmZpA3HLlPQrmodGequOl77ODOwYBqj9eNLG7cgstV8rFGORUKZ2u25tozfHSUsuDRnESLqoT_f8JR3TaSjjmf7nFplCTOCYJDN3KWvmzB1n_AY_7PndenqlBvDN4ACiM6WMlxhndZYRW5O1RGQXmfhnXNB&hgt_ver=331370278 app=ondemand?auth=daEckckdxbfaSdebsa7aVdBcEdrbJdUa2dF-bpdQaa-c0-WpFEuDsYEAq&aifp=sll02152008&slist=hulu11/635/40023635;.international=false&hgt=OZU7Pvs7j27-nhteNno7wrPRtGAQW3gH6sK__uZqcmH5a6d4PVeZFOVfpsBvLrdqse0-DR7TmioOMjLvkW3DDdDd1y3heFZ2GrgyRrmZpA3HLlPQrmodGequOl77ODOwYBqj9eNLG7cgstV8rFGORUKZ2u25tozfHSUsuDRnESLqoT_f8JR3TaSjjmf7nFplCTOCYJDN3KWvmzB1n_AY_7PndenqlBvDN4ACiM6WMlxhndZYRW5O1RGQXmfhnXNB&hgt_ver=331370278 playpath=mp4:hulu11/635/40023635/agave50179640_5789072_H264_650.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   ... 2 more
2012-01-12 04:02:54,171 WARN  [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error.
Installed latest hulu plugin and still get the above.
Post Thu Jan 12, 2012 7:19 pm
Re: Hulu (US only)
try running ffmpeg -i "rtmp url", eg:
ffmpeg -i "rtmpe://cp39466.edgefcs.net/ondemand?auth=daEbOcFaKaEchdjcqdja3dudpbMbOalbocs-bpdP__-c0-WpGBxCn0HAv&aifp=sll02152008&slist=hulu11/410/40026410;.international=false&hgt=OZU7Pvs7j27-nhteNno7wrXeIA64S6tjiQ2Yim1arG5JGVdsbusA3DIUwwfLmrDA6ugvvXAFenmzzT63PghkTkuDv0YUyghZtiWSSW_9oAz6UAOoAnVQ4cGKXkopMhRH1GGtE_mSIFLZCqQZPRpCViNVsfS_wq-574Zea1QKf_RvPe8rpJH27hW_isF6feBhMEspO3c9x4FGYlB5I7G0Od1TkKkq2F0f0hF5Rj_WGpJA87kI1rZfLf1a-SzaPsV1&hgt_ver=331370278 app=ondemand?auth=daEbOcFaKaEchdjcqdja3dudpbMbOalbocs-bpdP__-c0-WpGBxCn0HAv&aifp=sll02152008&slist=hulu11/410/40026410;.international=false&hgt=OZU7Pvs7j27-nhteNno7wrXeIA64S6tjiQ2Yim1arG5JGVdsbusA3DIUwwfLmrDA6ugvvXAFenmzzT63PghkTkuDv0YUyghZtiWSSW_9oAz6UAOoAnVQ4cGKXkopMhRH1GGtE_mSIFLZCqQZPRpCViNVsfS_wq-574Zea1QKf_RvPe8rpJH27hW_isF6feBhMEspO3c9x4FGYlB5I7G0Od1TkKkq2F0f0hF5Rj_WGpJA87kI1rZfLf1a-SzaPsV1&hgt_ver=331370278 playpath=mp4:hulu11/410/40026410/agave50183380_5835961_H264_650.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1"
from the above log. Note that this URL will be probably expired by now so refresh the feed and get a fresh url from the log.
paultry
Post Fri Jan 13, 2012 2:17 am
Re: Hulu (US only)
Thanks so much for updating the Hulu plugin! All of the Hulu RSS fees that I have tried are now working. Looks like Hulu is limiting the number of episodes available via Rss through Serviio and other DLNA servers to the 20 or 25 most recent, leaving a large percentage of some shows still unavailable via Serviio. I'm still not having any success with live streams of US based http feeds. Most recent attempt gave this result:
2012-01-12 20:01:52,299 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://www.imdb.com/video/hulu/vi4018208793/. It might not play.
Do I understand correctly that live feeds are not plugin dependent?
Windows 7
Sony BDP-S570
Alabama, USA
erik
Post Fri Jan 13, 2012 3:04 am
Re: Hulu (US only)
I'm having the same problem, here's my log
ffmpeg -i "rtmpe://cp39466.edgefcs.net/ondemand?auth=daEbgdpcpbjdPd_dGaUdjbRdBcFdQapdUae-bpd51_-c0-2qKDwDw1BAp&aifp=sll02152008&slist=hulu23/147/40015147;.international=false&hgt=OZU7Pvs7j27-nhteNno7wsm2PaTCe_sgTHj-NyCKJjZKuRIAL5o9uEmsnRfmrXSJE0ojCsEyVSlPAPGIZPf1xPlH9y6UHrfj7CvFAwFf3l4qP0MXMAQijr2v5e1FjFHfjOzU64FgoYcVOarTTjvS03O-zcztdgco-Q5G2nVgzs0ZMU0RPZtiB8Wc7R0YyPYP-mohZX5_9cFSe15pX9pwZ_POIgmBNFaNDLh80U4UvQATqMdoiFsaThER4IG9B7Q7&hgt_ver=331370278 app=ondemand?auth=daEbgdpcpbjdPd_dGaUdjbRdBcFdQapdUae-bpd51_-c0-2qKDwDw1BAp&aifp=sll02152008&slist=hulu23/147/40015147;.international=false&hgt=OZU7Pvs7j27-nhteNno7wsm2PaTCe_sgTHj-NyCKJjZKuRIAL5o9uEmsnRfmrXSJE0ojCsEyVSlPAPGIZPf1xPlH9y6UHrfj7CvFAwFf3l4qP0MXMAQijr2v5e1FjFHfjOzU64FgoYcVOarTTjvS03O-zcztdgco-Q5G2nVgzs0ZMU0RPZtiB8Wc7R0YyPYP-mohZX5_9cFSe15pX9pwZ_POIgmBNFaNDLh80U4UvQATqMdoiFsaThER4IG9B7Q7&hgt_ver=331370278 playpath=mp4:hulu23/147/40015147/agave40015147_5672672_H264_1000.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1"
ffmpeg version 0.8.7, Copyright (c) 2000-2011 the FFmpeg developers
  built on Dec 27 2011 09:51:30 with gcc 4.5.2
  configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/man --disable-debug --enable-shared --disable-static --enable-pthreads --enable-libtheora --enable-libvorbis --enable-gpl --enable-version3 --enable-postproc --enable-swscale --enable-x11grab --enable-avfilter --arch=x86_64 --enable-libdc1394 --enable-libmp3lame --enable-libfaac --enable-libxvid --enable-libx264 --enable-libspeex --enable-libschroedinger --enable-nonfree --enable-librtmp --enable-libopencore-amrnb --enable-libopencore-amrwb
  libavutil    51.  9. 1 / 51.  9. 1
  libavformat  53.  5. 0 / 53.  5. 0
  libavdevice  53.  1. 1 / 53.  1. 1
  libavfilter   2. 23. 0 /  2. 23. 0
  libpostproc  51.  2. 0 / 51.  2. 0
HandShake: Type mismatch: client sent 6, server answered 9
HandShake: Server not genuine Adobe!
RTMP_Connect1, handshake failed.
rtmpe://cp39466.edgefcs.net/ondemand?auth=daEbgdpcpbjdPd_dGaUdjbRdBcFdQapdUae-bpd51_-c0-2qKDwDw1BAp&aifp=sll02152008&slist=hulu23/147/40015147;.international=false&hgt=OZU7Pvs7j27-nhteNno7wsm2PaTCe_sgTHj-NyCKJjZKuRIAL5o9uEmsnRfmrXSJE0ojCsEyVSlPAPGIZPf1xPlH9y6UHrfj7CvFAwFf3l4qP0MXMAQijr2v5e1FjFHfjOzU64FgoYcVOarTTjvS03O-zcztdgco-Q5G2nVgzs0ZMU0RPZtiB8Wc7R0YyPYP-mohZX5_9cFSe15pX9pwZ_POIgmBNFaNDLh80U4UvQATqMdoiFsaThER4IG9B7Q7&hgt_ver=331370278 app=ondemand?auth=daEbgdpcpbjdPd_dGaUdjbRdBcFdQapdUae-bpd51_-c0-2qKDwDw1BAp&aifp=sll02152008&slist=hulu23/147/40015147;.international=false&hgt=OZU7Pvs7j27-nhteNno7wsm2PaTCe_sgTHj-NyCKJjZKuRIAL5o9uEmsnRfmrXSJE0ojCsEyVSlPAPGIZPf1xPlH9y6UHrfj7CvFAwFf3l4qP0MXMAQijr2v5e1FjFHfjOzU64FgoYcVOarTTjvS03O-zcztdgco-Q5G2nVgzs0ZMU0RPZtiB8Wc7R0YyPYP-mohZX5_9cFSe15pX9pwZ_POIgmBNFaNDLh80U4UvQATqMdoiFsaThER4IG9B7Q7&hgt_ver=331370278 playpath=mp4:hulu23/147/40015147/agave40015147_5672672_H264_1000.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1: Operation not permitted
edit: just to say I am in the US and have no problem with Hulu in a browser.
Post Fri Jan 13, 2012 11:44 am
Re: Hulu (US only)
erik wrote:I'm having the same problem, here's my log
From above:
wonder if this is the problem?
Post Fri Jan 13, 2012 12:41 pm
Re: Hulu (US only)
rtmp version is probably not compatible with the server side.
Return to Available plugins
Users browsing this forum: Google [Bot] and 18 guests
