Video Codec not supported
wintersonata
Post Wed Jan 11, 2012 2:36 pm
For Samsung C/D series profile with 46C5000, unable to get transcoding to work for this video file.
Unique ID : 244355965292257570449475512772715734932 (0xB7D53F3FA02BFCC0842E662BB785E794)
Complete name : D:\**************.mkv
Format : Matroska
Format version : Version 2
File size : 295 MiB
Duration : 23mn 34s
Overall bit rate : 1 749 Kbps
Encoded date : UTC 2011-12-03 00:30:12
Writing application : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Attachment : Yes / Yes
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 34s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : h.264
Writing library : x264 core 116 r2057 0ba8a9c
Encoding settings : cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x13 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=130 / rc=crf / mbtree=1 / crf=18.5 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : Japanese
Default : Yes
Forced : No
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 34s
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Title : aac 2ch
Language : Japanese
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : subtitles & notes
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Opening
00:03:13.527 : en:Recap
00:04:07.447 : en:Part 1
00:14:58.865 : en:Part 2
00:23:04.884 : en:Preview
Post Wed Jan 11, 2012 2:56 pm
Re: Video Codec not supported
can you provide mediainfo for this file aswell please
wintersonata
Post Wed Jan 11, 2012 11:45 pm
Cerberus wrote:can you provide mediainfo for this file aswell please
Above information is generated from mediainfo. Cheers.
I have attaching the FFMPEG info below as well.
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 719.28 (72000
0/1001) -> 0.08 (1/12)
Input #0, matroska,webm, from 'D:\***************.mkv':
Duration: 00:23:34.91, start: 0.000000, bitrate: 1748 kb/s
Chapter #0.0: start 0.000000, end 193.527000
title : Opening
Chapter #0.1: start 193.527000, end 247.447000
title : Recap
Chapter #0.2: start 247.447000, end 898.865000
title : Part 1
Chapter #0.3: start 898.865000, end 1384.884000
title : Part 2
Chapter #0.4: start 1384.884000, end 1414.912000
title : Preview
Stream #0:0(jpn): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 0
.08 tbr, 1k tbn, 719.28 tbc (default)
title : h.264
Stream #0:1(jpn): Audio: aac, 48000 Hz, stereo, s16 (default)
title : aac 2ch
Stream #0:2(eng): Subtitle: ssa (default)
title : subtitles & notes
Stream #0:3: Attachment: ttf
filename : Impress BT.ttf
mimetype : application/x-truetype-font
Stream #0:4: Attachment: ttf
filename : PRISTINA.TTF
YTMY
Post Thu Jan 12, 2012 5:52 am
I never seen notes' files attached to mkv, maybe TV does not like them?
If You don't need notes, try remuxing file file with mkvmerge without notes and play then. Mkv with aac does not need to be transcoded and should work.
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
