40c6000 no refresh of deleted/renamed items
Panzerfaust
Post Wed Jan 11, 2012 6:04 pm
Re: 40c6000 no refresh of deleted/renamed items
I know this is an old thread but I seem to be having the same issues. I am using Serviio with my WDTV Live Plus. It seems to work better than any other media server out there, and I've tried them all. I really enjoy the file organizational structure it provides, such as Newly Added, Recently Watched, Series, etc...
But I am having precisely the same issues as mention in this thread. Weeks after deleting a folder and/or file it will still appear in the media list, despite countless "refreshes" and both computer resets AND WDTV live resets... Nothing seems to make them go away, and its quite frustrating. I didn't see a way to resolve the problem in the thread so I wonder if, since the last reply, has there been a solution found to this bug? I am running v0.6.1.
Thanks!
Post Wed Jan 11, 2012 7:01 pm
Panzerfaust wrote:Hello,
Thanks!
did you upgrade to 0.6.1 or start fresh by uninstalling first then reinstalling ?
if you upgraded its likely your brought a DB corruption over from your old install and a nice fresh install will solve your problem
if you did do a fresh install then this is case for ZIP to look into. :)
Panzerfaust
Post Wed Jan 11, 2012 10:13 pm
Thanks!
Well, I actually just DLed the file and installed, havent done any upgrade or update that I know of since I installed it initially...
So, bascially you are recommending that I un-install Servio, then do a fresh re-install and my woes shall be remedied? Thanks for speedy response...
What is latest version BTW?
Post Thu Jan 12, 2012 8:45 am
Thanks!
0.6.1 is latest but 0.6.2 is due very soon with a few bug fixes that were missed.
Previous
