Post Thu Jan 12, 2012 9:04 am
Panasonic DMR-PWT500 GL video playback
Howdy,
I've got my PWT500GL set up (DLNA Certificate), it's connected to the TV and Serviio through my PC running Windows 7.
I'm having trouble with video playback.
Debug Log: http://pastebin.com/raw.php?i=e3quLBU3
With the DIrecTV HD-DVR profile active, some videos playback perfectly:
Complete name                    : E:\Movies\13 (2010).avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 702 MiB
Duration                         : 1h 32mn
Overall bit rate mode            : Variable
Overall bit rate                 : 1 059 Kbps
Writing application              : Noir's Hyper HD Xvid
Writing library                  : VirtualDub build 32839/release
Original source form             : Noir's Shit
Copyright                        : By Noir
Format                           : MPEG-4 Visual
Format profile                   : Advanced Simple@L5
Format settings, BVOP            : 5
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Muxing mode                      : Packed bitstream
Codec ID                         : XVID
Codec ID/Hint                    : XviD
Duration                         : 1h 32mn
Bit rate                         : 933 Kbps
Width                            : 672 pixels
Height                           : 286 pixels
Display aspect ratio             : 2.35:1
Frame rate                       : 25.000 fps
Bits/(Pixel*Frame)               : 0.194
Stream size                      : 619 MiB (88%)
Writing library                  : XviD 57
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Mode                             : Joint stereo
Mode extension                   : MS Stereo
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 1h 32mn
Bit rate mode                    : Variable
Bit rate                         : 112 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 44.1 KHz
Stream size                      : 75.1 MiB (11%)
Alignment                        : Aligned on interleaves
Interleave, duration             : 26 ms (0.65 video frame)
Interleave, preload duration     : 537 ms
Writing library                  : LAME9š…V šÿ.Œ\€rE
Where as others seem to play in complete black and white:
Complete name                    : E:\Movies\Fear and Loathing In Las Vegas (1998).avi
Format                           : AVI
File size                        : 698 MiB
Duration                         : 1h 58mn
Overall bit rate                 : 824 Kbps
Writing library                  : VirtualDub build 10740/release
Codec ID                         : DIV3
Codec ID/Hint                    : DivX 3 Low
Duration                         : 1h 58mn
Bit rate                         : 654 Kbps
Width                            : 640 pixels
Height                           : 272 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.157
Stream size                      : 554 MiB (79%)
Format                           : MPEG Audio
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 1h 58mn
Bit rate                         : 160 Kbps
Stream size                      : 136 MiB (19%)
Alignment                        : Split accross interleaves
Interleave, duration             : 42 ms (1.00 video frame)
Interleave, preload duration     : 500 ms
And this particular .mkv file (the only one I have) plays for about 1 second in black and white, then stops:
Unique ID                        : 222260528267996285581742557483954970931 (0xA735D21863E8B0D0BAFD58550A85A133)
Complete name                    : E:\Movies\Fight Club (1999).mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 700 MiB
Duration                         : 2h 19mn
Overall bit rate                 : 703 Kbps
Movie name                       : Fight Club 1999 BRrip 720p x264 [Herakler]
Encoded date                     : UTC 2010-12-17 23:48:29
Writing application              : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
Writing library                  : libebml v0.7.9 + libmatroska v0.8.1
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 2h 19mn
Nominal bit rate                 : 638 Kbps
Maximum bit rate                 : 25.0 Mbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Bits/(Pixel*Frame)               : 0.029
Writing library                  : x264 core 105 r1732 2b04482
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=638 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr
Default                          : No
Forced                           : No
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : HE-AAC / LC
Codec ID                         : A_AAC
Duration                         : 2h 19mn
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz / 24.0 KHz
Language                         : English
Default                          : No
Forced                           : No
I tried the other render profiles, but DirecTV HD-DVR is the only profile that gives at least some form of playback.
Hopefully I have provided enough information for the problem to be solved.
