Vimeo
BDM
Post Thu Jan 12, 2012 2:50 pm
Re: Vimeo
UPDATE:
After re-installing 0.6.1 (OSX LION 10.7.2) and plugins for 0.6.1 I can see the online folders "VIMEO/YouTube" and play all the videos on my PS3!!! :D
Only 2 folders stay empty, could be the Vimeo rss feed.
Still working out why none of the Vimeo/YouTube videos play on my Viera TX-P54. Keep getting the message "file format not supported" :twisted:
Any thoughts???? Anyone playing on a Viera TX with a different profile? I use "DirecTV HD-DVR"
Thanks & Cheers!
Panasonic Viera TX-P54Z1 (2.403) WIRED - Profile: "Toshiba REGZA" | Play Station 3 (4.0) WIRELESS - Profile: "Playstation 3" | OSX LION (10.7.2) | Serviio (0.6.1)
BDM
Post Mon Jan 16, 2012 11:48 am
Re: Vimeo
Vimeo works now fine on my Pana-gear but can't seem to show & play:
http://vimeo.com/groups/5dmk2/videos/rss
http://vimeo.com/groups/1minute/videos/rss
Anyone a suggestion?
Cheers!!!
JUser
Post Mon Jan 16, 2012 12:44 pm
Why certain VIMEO Channels are not working with serviio?
Hello Zip
Please let me know why certain VIMEO Channels are not working with Serviio?
for example I am not able to see the contents nor playthem:
http://vimeo.com/channels/saisouljourns/videos/rss
Regards
Juser
Post Mon Jan 16, 2012 1:07 pm
Re: Why certain VIMEO Channels are not working with serviio
JUser wrote:Hello Zip
Regards
Juser
What does 'not working' mean? Did you try with the latest plugin in the first post of this topic?
BDM
Post Tue Jan 17, 2012 8:28 am
Regards
Juser
Hi ZIP,
Thanks for your reply!
Channels are empty with no feeds or thumbs.
Installed the latest plugin, restarted the server (stopped both the server and console process first).
Setup online resources:
Max. number of feeds: "50" (in none of the ques 50 feeds are listed)
Feed expiry interval: "1 hour"
Preferred online contant Q: "High"
Hope this feedback helps!
Cheers!
JUser
Post Tue Jan 17, 2012 2:31 pm
Hi ZIP
I am using latest Vimeo Plugin
When I use the following channel the folders are empty they contain videos in the Vimeo Site.
However the channel "hd"
http://vimeo.com/channels/hd/videos/rss
works great I am able to see the videos in this channel.
My question is why the channel hd is working great in Serviio (where I can see the videos and play them) and the channel saisouljourns is not working (meaning the contents are empty).
Cheers
Juser
jstahl
Post Tue Jan 17, 2012 2:43 pm
Re: Vimeo
Interesting... after switching from High content quality to Medium I had a couple more videos appear in this feed:
http://vimeo.com/user4577902/likes/rss
I still don't get any videos listed in this feed though:
http://vimeo.com/user4577902/videos/rss
Jeph
jstahl
Post Tue Jan 17, 2012 4:08 pm
Re: Vimeo
jstahl wrote:Interesting... after switching from High content quality to Medium I had a couple more videos appear in this feed:
Jeph
Actually on Medium, all the videos are now displayed.
Unfortunately, both my android, and my samsung bluray say unsupported video codec for these videos :cry:
Post Tue Jan 17, 2012 4:41 pm
Re: Vimeo
Jeph
samsung - will be sorted with 0.6.2 due soon
android - when coupled with skifta and rockplayer lite will play anything u through at it
jstahl
Post Tue Jan 17, 2012 5:22 pm
Re: Vimeo
Cerberus wrote:samsung - will be sorted with 0.6.2 due soon
Thanks, installed skifta and rockplayer and android now likes it. (I was previously using Samsung Allshare on the android)
Jeph
Post Wed Jan 18, 2012 4:08 pm
Re: Vimeo
Updated the first post with a new version which should fix the problems with some feeds not appearing for High quality setting.
BDM
Post Wed Jan 18, 2012 4:27 pm
Re: Vimeo
zip wrote:Updated the first post with a new version which should fix the problems with some feeds not appearing for High quality setting.
Thanks a mill ZIP! :D :D :D
Cheers
JUser
Post Thu Jan 19, 2012 10:40 am
Re: Vimeo Channels not working
Hi Zip
Million Thanks and now I am able to see all the channels of Vimeo in my Sony TV.
Once again thanks for fixing
Cheers
Juer
BDM
Post Fri Jan 20, 2012 9:25 am
Re: Vimeo
Hi Zip,
Updated the groovy, but still having problems with two of my channels:
And still not all (listing # set to 50 feeds) video's show in the listing on my Viera.
Any idea's what could be a solution for it?
Cheers
Post Fri Jan 20, 2012 10:03 am
Re: Vimeo
these are not feed URLs though, right?
BDM
Post Fri Jan 20, 2012 12:38 pm
Re: Vimeo
zip wrote:these are not feed URLs though, right?
Hi Zip,
Correcting:
Cheers!
Post Fri Jan 20, 2012 3:06 pm
Re: Vimeo
The first one only includes like 10 videos, right? How could it display 50 when the source itself only has 9? Didn't check the other one but I assume it'll be the same.
Can you see the 10 videos at least?
JUser
Post Sat Jan 21, 2012 1:45 am
Again Vimeo channels not working with Serviio
Hi Zip
From yesterday, Vimeo and Dailymotion channels are not working / recognised by Serviio. These were working perfectly 2 days ago.
However youtube channels work.
I am using 0.6.1 and have not changed any settings/plugins etc.
BDM
Post Sat Jan 21, 2012 8:01 am
Re: Again Vimeo channels not working with Serviio
JUser wrote:Hi Zip
Same here with Vimeo, all channels are gone! Made no changes to settings :twisted:
Post Sat Jan 21, 2012 10:31 am
Re: Vimeo
Didn't they change feed URLs? The plugin seems ok.
Return to Available plugins
