Samsung c series
• Page 1 of 2 • 1, 2
It would be nice if Serviio would support Samungs resume playback feature and its fast forward/rewind
Eagles may soar but Beavers don't get sucked into jet engines..
Re: Samsung c series
The resume feature - don't think it's gonna happen At least not in near future. Ffwd/Rev should work on most formats, right?
Petr
Help translate Serviio
Actually when I press my FWD or Rew buttons it states "Not Available"
if I use my external HD they work fine as well as resume (PRESS D [BLUE] BUTTON)
I can confirm that the forward/back skip buttons do not work on a 46C7700 TV either.
Using the left and right cursor keys on the remote you can skip in about 10 second intervals, but the rebuffering takes almost the same amount of time, wasting this option completely.
Resume playback would be extremely welcome...
FFwd/Rev is not working on the Samsung BD-C5500 BR player, either.
can "3rd" this.. its not working at the moment...
resume playback will be awesome!
I can get it to fast forward and seek via plug player on iphone
Same issue here using WiseLink for C-Series on a Samsung LE46C750, also occurs with other DNLA servers I've tried (eg. PS3MS) - the dedicated FF/REW buttons on the remote don't work. Holding down the cursor left or right button will bring on a fast forward (>>>>) or fast rewind (<<<<) mode after a while, which also only skips about 3 minutes forward or back with heavy buffering in between.
As this doesn't seem to be a Serviio specific issue, and being a developer myself, I wonder if this is an issue that can be fixed on the server side at all, or is it a Samsung specific problem?
the tv makes no request on ffwd/rew button press, only the arrow buttons, so nothing we can do
Petr
Thanks for the quick answer. I'd be fine using the cursor keys instead if they would work well. Is it possible to customise the step interval for forward or rewind?
The arrow right/left keys don't work for transcoded files on my Samung Blu-ray player. They work on any native files that the Samy can pick up.
Is it possible to fix that?
Serviio has support for time-based seek on the transcoded files. I'm not sure if the player supports that (my Samsung B series TV does).
Petr
I guess that makes sense. Does the Blu-ray player even know if the file is being transcoded? If not, couldn't support be added?
I mean that if it just sees the file then it should add the jump icons and then fail maybe...
Just an idea. Let me know if there's anything that I can try at this end to help troubleshoot. It's a BD-C7500. Cheers.
Yes, Serviio sends information that the file is transcoded. Not sure if the player does anything about it though. You can send a detailed log of when you start playing the file and try to ffwd.
Petr
Here's the log file dump. It wouldn't let me upload.
2010-09-18 10:55:08,656 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2010-09-18 10:55:08,656 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2010-09-18 10:55:08,671 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, title=Serviio Media Library, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,687 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, title=Audio, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,703 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, title=Artists, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,703 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,703 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,718 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,718 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, title=Folders, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,734 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2010-09-18 10:55:08,734 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, title=Genres, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,734 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,750 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,750 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, title=Titles, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,765 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,765 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,765 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, title=All songs, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,781 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,781 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, title=Artist Songs, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,781 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,796 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,796 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, title=All albums, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,796 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,812 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,812 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, title=Image, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,828 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, title=Albums, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,828 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,828 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,843 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, title=Folders, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,843 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2010-09-18 10:55:08,843 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, title=Year, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,859 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,859 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,875 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, title=Timeline, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,875 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,875 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,890 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,890 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, title=All images, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,906 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,906 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, title=Video, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,906 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, title=All titles, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,921 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,921 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,921 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, title=Movies, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-09-18 10:55:08,937 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, title=Series, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2010-09-18 10:55:08,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2010-09-18 10:55:08,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2010-09-18 10:55:08,968 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, title=Folders, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:08,968 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2010-09-18 10:55:08,984 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, title=Last viewed, class=CONTAINER, cacheRegion=local_resetafterplay
2010-09-18 10:55:08,984 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2010-09-18 10:55:08,984 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, title=Last added, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:09,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,000 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, title=Genres, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:09,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,015 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, title=Actors, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:09,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,046 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, title=Directors, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:09,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,078 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, title=Producers, class=CONTAINER, cacheRegion=local_default
2010-09-18 10:55:09,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2010-09-18 10:55:09,109 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-09-18 10:55:09,140 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-09-18 10:55:10,250 DEBUG [WebServer] Incoming connection from /192.168.1.104:34785
2010-09-18 10:55:10,250 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
2010-09-18 10:55:10,265 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2010-09-18 10:55:10,265 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-09-18 10:55:10,265 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-09-18 10:55:12,687 DEBUG [WebServer] Incoming connection from /192.168.1.104:34432
2010-09-18 10:55:12,687 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
2010-09-18 10:55:12,687 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2010-09-18 10:55:12,703 DEBUG [VideoDAOImpl] Retrieving number of video initials
2010-09-18 10:55:12,734 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-09-18 10:55:12,734 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-09-18 10:55:12,750 DEBUG [WebServer] Incoming connection from /192.168.1.104:44687
2010-09-18 10:55:12,750 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
2010-09-18 10:55:12,750 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2010-09-18 10:55:12,750 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-09-18 10:55:12,765 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-09-18 10:55:12,781 DEBUG [WebServer] Incoming connection from /192.168.1.104:43422
2010-09-18 10:55:12,796 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
2010-09-18 10:55:12,796 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2010-09-18 10:55:12,796 DEBUG [VideoDAOImpl] Retrieving number of video initials
2010-09-18 10:55:12,796 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
2010-09-18 10:55:12,812 DEBUG [SeriesDAOImpl] Retrieving number of series
2010-09-18 10:55:12,843 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2010-09-18 10:55:12,843 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2010-09-18 10:55:12,859 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2010-09-18 10:55:12,859 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2010-09-18 10:55:12,875 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2010-09-18 10:55:12,890 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2010-09-18 10:55:12,937 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2010-09-18 10:55:12,937 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2010-09-18 10:55:12,937 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-09-18 10:55:12,937 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-09-18 10:55:16,062 DEBUG [WebServer] Incoming connection from /192.168.1.104:58477
2010-09-18 10:55:16,062 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
2010-09-18 10:55:16,062 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_LA, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2010-09-18 10:55:16,062 DEBUG [VideoDAOImpl] Retrieving list of 10 last added videos (from=0, count=1)
2010-09-18 10:55:16,093 DEBUG [GenreDAOImpl] Reading a Genre (id = 84)
2010-09-18 10:55:16,093 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6957)
2010-09-18 10:55:16,093 DEBUG [MediaItemDAOImpl] Getting file of media item 6957
2010-09-18 10:55:16,109 DEBUG [VideoDAOImpl] Reading a Video (id = 6957)
2010-09-18 10:55:16,109 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6957 and profile Samsung TV / player (C-series)
2010-09-18 10:55:16,109 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_EU_ISO
2010-09-18 10:55:16,125 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_NA_ISO
2010-09-18 10:55:16,125 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_KO_ISO
2010-09-18 10:55:16,125 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4517)
2010-09-18 10:55:16,171 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6957)
2010-09-18 10:55:16,171 DEBUG [MediaItemDAOImpl] Getting file of media item 6957
2010-09-18 10:55:16,171 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2010-09-18 10:55:16,171 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2010-09-18 10:55:16,171 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-09-18 10:55:16,187 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-09-18 10:55:16,203 DEBUG [WebServer] Incoming connection from /192.168.1.104:42179
2010-09-18 10:55:16,203 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
2010-09-18 10:55:16,203 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_LA, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2010-09-18 10:55:16,203 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2010-09-18 10:55:16,203 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2010-09-18 10:55:16,203 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-09-18 10:55:16,218 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-09-18 10:55:16,250 DEBUG [WebServer] Incoming connection from /192.168.1.104:33188
2010-09-18 10:55:16,265 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from DLNADOC/1.50:
2010-09-18 10:55:16,265 DEBUG [ContentDirectory] Browse() called for profile Samsung TV / player (C-series) with parameters: objectID = V_LA, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2010-09-18 10:55:16,265 DEBUG [VideoDAOImpl] Retrieving list of 10 last added videos (from=0, count=20)
2010-09-18 10:55:16,281 DEBUG [GenreDAOImpl] Reading a Genre (id = 84)
2010-09-18 10:55:16,281 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6957)
2010-09-18 10:55:16,281 DEBUG [MediaItemDAOImpl] Getting file of media item 6957
2010-09-18 10:55:16,281 DEBUG [VideoDAOImpl] Reading a Video (id = 6957)
2010-09-18 10:55:16,281 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6957 and profile Samsung TV / player (C-series)
2010-09-18 10:55:16,281 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_EU_ISO
2010-09-18 10:55:16,281 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_NA_ISO
2010-09-18 10:55:16,281 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_KO_ISO
2010-09-18 10:55:16,281 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4517)
2010-09-18 10:55:16,281 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2010-09-18 10:55:16,281 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2010-09-18 10:55:16,281 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-09-18 10:55:16,281 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-09-18 10:55:16,859 DEBUG [WebServer] Incoming connection from /192.168.1.104:60133
2010-09-18 10:55:16,859 DEBUG [ResourceTransportRequestHandler] GET /resource/4517/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.102:8895, ACCEPT-LANGUAGE: en-us, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Interactive, ]
2010-09-18 10:55:16,859 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:16,859 DEBUG [ResourceTransportRequestHandler] Request for resource 4517 and type 'COVER_IMAGE' received
2010-09-18 10:55:16,859 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4517)
2010-09-18 10:55:16,859 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 4517
2010-09-18 10:55:16,875 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2010-09-18 10:55:16,875 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -1
2010-09-18 10:55:16,875 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 10:55:16,875 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Date: Sat, 18 Sep 2010 14:55:16 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000, transferMode.dlna.org: Interactive, ]
2010-09-18 10:55:20,343 DEBUG [WebServer] I/O error: Connection reset
2010-09-18 10:55:20,406 DEBUG [WebServer] Incoming connection from /192.168.1.104:38407
2010-09-18 10:55:20,421 DEBUG [ResourceTransportRequestHandler] HEAD /resource/6957/MEDIA_ITEM/MPEG_TS_SD_KO_ISO HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.1.102:8895, ]
2010-09-18 10:55:20,421 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:20,421 DEBUG [ResourceTransportRequestHandler] Request for resource 6957 and type 'MEDIA_ITEM' received
2010-09-18 10:55:20,421 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6957)
2010-09-18 10:55:20,421 DEBUG [VideoDAOImpl] Reading a Video (id = 6957)
2010-09-18 10:55:20,421 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6957, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C-series)
2010-09-18 10:55:20,421 DEBUG [VideoDeliveryEngine] Getting media info for transcoded version of file THE_GODFATHER.mkv
2010-09-18 10:55:20,421 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_EU_ISO
2010-09-18 10:55:20,421 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_NA_ISO
2010-09-18 10:55:20,421 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_KO_ISO
2010-09-18 10:55:20,421 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2010-09-18 10:55:20,421 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, Content-Length: 9000000000, Date: Sat, 18 Sep 2010 14:55:20 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 10:55:20,453 DEBUG [WebServer] Incoming connection from /192.168.1.104:40733
2010-09-18 10:55:20,453 DEBUG [ResourceTransportRequestHandler] GET /resource/6957/MEDIA_ITEM/MPEG_TS_SD_KO_ISO HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, getMediaInfo.sec: 1, TimeSeekRange.dlna.org: npt=0-, Host: 192.168.1.102:8895, ]
2010-09-18 10:55:20,453 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:20,453 DEBUG [ResourceTransportRequestHandler] Request for resource 6957 and type 'MEDIA_ITEM' received
2010-09-18 10:55:20,453 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6957)
2010-09-18 10:55:20,453 DEBUG [VideoDAOImpl] Reading a Video (id = 6957)
2010-09-18 10:55:20,453 DEBUG [VideoDeliveryEngine] Delivering item '6957' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:20,453 DEBUG [VideoDeliveryEngine] Delivering file 'THE_GODFATHER.mkv' using transcoding
2010-09-18 10:55:20,453 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:20,453 DEBUG [MediaItemDAOImpl] Getting file of media item 6957
2010-09-18 10:55:20,453 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: S:\TEST\THE_GODFATHER.mkv
2010-09-18 10:55:20,453 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads 1 -i S:\TEST\THE_GODFATHER.mkv -y -vcodec copy -copyts -acodec copy -ac 2 -sn -f mpegts S:\Serviio\transcoding-temp-6957-MPEG2TS.stf
2010-09-18 10:55:20,953 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_EU_ISO
2010-09-18 10:55:20,953 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_NA_ISO
2010-09-18 10:55:20,953 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_KO_ISO
2010-09-18 10:55:20,953 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2010-09-18 10:55:20,953 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 6957) as read
2010-09-18 10:55:21,125 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2010-09-18 10:55:21,125 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2010-09-18 10:55:21,125 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 10:55:21,125 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, TimeSeekRange.dlna.org: npt=0-10529/10529, Content-Length: 9000000000, Date: Sat, 18 Sep 2010 14:55:21 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 10:55:23,765 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 10:55:23,796 DEBUG [WebServer] Incoming connection from /192.168.1.104:52948
2010-09-18 10:55:23,796 DEBUG [ResourceTransportRequestHandler] HEAD /resource/6957/MEDIA_ITEM/MPEG_TS_SD_KO_ISO HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.1.102:8895, ]
2010-09-18 10:55:23,796 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:23,796 DEBUG [ResourceTransportRequestHandler] Request for resource 6957 and type 'MEDIA_ITEM' received
2010-09-18 10:55:23,796 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6957)
2010-09-18 10:55:23,796 DEBUG [VideoDAOImpl] Reading a Video (id = 6957)
2010-09-18 10:55:23,796 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6957, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C-series)
2010-09-18 10:55:23,796 DEBUG [VideoDeliveryEngine] Getting media info for transcoded version of file THE_GODFATHER.mkv
2010-09-18 10:55:23,796 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_EU_ISO
2010-09-18 10:55:23,796 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_NA_ISO
2010-09-18 10:55:23,796 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_KO_ISO
2010-09-18 10:55:23,796 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2010-09-18 10:55:23,796 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, Content-Length: 9000000000, Date: Sat, 18 Sep 2010 14:55:23 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 10:55:23,828 DEBUG [WebServer] Incoming connection from /192.168.1.104:46205
2010-09-18 10:55:23,828 DEBUG [ResourceTransportRequestHandler] GET /resource/6957/MEDIA_ITEM/MPEG_TS_SD_KO_ISO HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, getMediaInfo.sec: 1, TimeSeekRange.dlna.org: npt=0-, Host: 192.168.1.102:8895, ]
2010-09-18 10:55:23,828 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:23,828 DEBUG [ResourceTransportRequestHandler] Request for resource 6957 and type 'MEDIA_ITEM' received
2010-09-18 10:55:23,828 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6957)
2010-09-18 10:55:23,828 DEBUG [VideoDAOImpl] Reading a Video (id = 6957)
2010-09-18 10:55:23,843 DEBUG [VideoDeliveryEngine] Delivering item '6957' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:23,843 DEBUG [VideoDeliveryEngine] Delivering file 'THE_GODFATHER.mkv' using transcoding
2010-09-18 10:55:23,843 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:23,843 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_EU_ISO
2010-09-18 10:55:23,843 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_NA_ISO
2010-09-18 10:55:23,843 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_KO_ISO
2010-09-18 10:55:23,843 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2010-09-18 10:55:23,843 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 6957) as read
2010-09-18 10:55:23,843 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2010-09-18 10:55:23,843 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2010-09-18 10:55:23,843 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 10:55:23,843 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, TimeSeekRange.dlna.org: npt=0-10529/10529, Content-Length: 9000000000, Date: Sat, 18 Sep 2010 14:55:23 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 10:55:23,921 DEBUG [WebServer] Incoming connection from /192.168.1.104:33229
2010-09-18 10:55:23,921 DEBUG [ResourceTransportRequestHandler] HEAD /resource/6957/MEDIA_ITEM/MPEG_TS_SD_KO_ISO HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
2010-09-18 10:55:23,921 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:23,921 DEBUG [ResourceTransportRequestHandler] Request for resource 6957 and type 'MEDIA_ITEM' received
2010-09-18 10:55:23,921 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6957)
2010-09-18 10:55:23,921 DEBUG [VideoDAOImpl] Reading a Video (id = 6957)
2010-09-18 10:55:23,921 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6957, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C-series)
2010-09-18 10:55:23,921 DEBUG [VideoDeliveryEngine] Getting media info for transcoded version of file THE_GODFATHER.mkv
2010-09-18 10:55:23,921 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_EU_ISO
2010-09-18 10:55:23,921 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_NA_ISO
2010-09-18 10:55:23,921 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_KO_ISO
2010-09-18 10:55:23,921 DEBUG [MediaItemDAOImpl] Getting file of media item 6957
2010-09-18 10:55:23,921 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2010-09-18 10:55:23,921 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, Content-Length: 9000000000, Date: Sat, 18 Sep 2010 14:55:23 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, transferMode.dlna.org: Streaming, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, ]
2010-09-18 10:55:28,140 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 10:55:28,187 DEBUG [WebServer] Incoming connection from /192.168.1.104:36669
2010-09-18 10:55:28,203 DEBUG [ResourceTransportRequestHandler] GET /resource/6957/MEDIA_ITEM/MPEG_TS_SD_KO_ISO HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, TimeSeekRange.dlna.org: npt=0-, Host: 192.168.1.102:8895, ]
2010-09-18 10:55:28,203 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:28,203 DEBUG [ResourceTransportRequestHandler] Request for resource 6957 and type 'MEDIA_ITEM' received
2010-09-18 10:55:28,203 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6957)
2010-09-18 10:55:28,203 DEBUG [VideoDAOImpl] Reading a Video (id = 6957)
2010-09-18 10:55:28,203 DEBUG [VideoDeliveryEngine] Delivering item '6957' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:28,203 DEBUG [VideoDeliveryEngine] Delivering file 'THE_GODFATHER.mkv' using transcoding
2010-09-18 10:55:28,203 DEBUG [VideoDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 10:55:28,203 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_EU_ISO
2010-09-18 10:55:28,203 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_NA_ISO
2010-09-18 10:55:28,203 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file THE_GODFATHER.mkv: MPEG_TS_SD_KO_ISO
2010-09-18 10:55:28,203 DEBUG [VideoDeliveryEngine] Sending transcoding stream
2010-09-18 10:55:28,203 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 6957) as read
2010-09-18 10:55:28,203 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2010-09-18 10:55:28,203 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2010-09-18 10:55:28,203 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 10:55:28,203 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, TimeSeekRange.dlna.org: npt=0-10529/10529, Content-Length: 9000000000, Date: Sat, 18 Sep 2010 14:55:28 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 10:55:40,671 DEBUG [WebServer] I/O error: Connection reset
2010-09-18 10:55:55,390 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1025
2010-09-18 10:55:55,703 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1025
2010-09-18 10:55:56,015 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1025
2010-09-18 10:56:53,453 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:3ffad415-9d1a-32d2-80c7-718d4ac17c97 from address /192.168.1.104:1025
2010-09-18 10:56:53,453 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-09-18 10:56:53,453 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1026
2010-09-18 10:56:53,765 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:3ffad415-9d1a-32d2-80c7-718d4ac17c97 from address /192.168.1.104:1025
2010-09-18 10:56:53,765 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-09-18 10:56:53,765 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1026
2010-09-18 10:56:54,078 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:3ffad415-9d1a-32d2-80c7-718d4ac17c97 from address /192.168.1.104:1025
2010-09-18 10:56:54,078 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
Yep, all looks good from my perspective. The TV asks for the whole file and after that there are no additional (ffwd) requests coming in.
Petr
Heres what happens when I play a mkv file which I converted to H264 and AC3 (for native playback).
2010-09-18 11:15:28,812 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:28,812 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:28,812 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:28,812 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 6958) as read
2010-09-18 11:15:28,812 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2010-09-18 11:15:28,812 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1640374444
2010-09-18 11:15:28,812 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:28,812 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 0-1640374443/1640374444, Content-Length: 1640374444, Date: Sat, 18 Sep 2010 15:15:28 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:28,859 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:28,875 DEBUG [WebServer] Incoming connection from /192.168.1.104:41012
2010-09-18 11:15:28,875 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=2965504-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:28,875 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:28,875 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:28,875 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:28,875 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:28,875 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:28,875 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:28,875 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:28,875 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1637408940
2010-09-18 11:15:28,875 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:28,875 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 2965504-1640374443/1640374444, Content-Length: 1637408940, Date: Sat, 18 Sep 2010 15:15:28 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:28,937 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:28,953 DEBUG [WebServer] Incoming connection from /192.168.1.104:48280
2010-09-18 11:15:28,953 DEBUG [ResourceTransportRequestHandler] HEAD /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:28,953 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:28,953 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:28,953 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:28,953 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:28,953 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6958, format MATROSKA and profile Samsung TV / player (C-series)
2010-09-18 11:15:28,953 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2010-09-18 11:15:28,953 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-mkv, Content-Length: 1640374444, Date: Sat, 18 Sep 2010 15:15:28 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:28,968 DEBUG [WebServer] Incoming connection from /192.168.1.104:51275
2010-09-18 11:15:28,968 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=0-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, getMediaInfo.sec: 1, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:28,968 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:28,968 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:28,968 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:28,968 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:28,968 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:28,968 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:28,968 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:28,968 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 6958) as read
2010-09-18 11:15:28,968 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2010-09-18 11:15:28,968 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1640374444
2010-09-18 11:15:28,968 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:28,968 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 0-1640374443/1640374444, Content-Length: 1640374444, Date: Sat, 18 Sep 2010 15:15:28 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:29,015 DEBUG [WebServer] Incoming connection from /192.168.1.104:51256
2010-09-18 11:15:29,015 DEBUG [ResourceTransportRequestHandler] HEAD /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [getCaptionInfo.sec: 1, ]
2010-09-18 11:15:29,015 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,015 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:29,015 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:29,015 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:29,015 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6958, format MATROSKA and profile Samsung TV / player (C-series)
2010-09-18 11:15:29,015 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:29,015 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2010-09-18 11:15:29,015 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/x-mkv, Content-Length: 1640374444, Date: Sat, 18 Sep 2010 15:15:29 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, transferMode.dlna.org: Streaming, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, ]
2010-09-18 11:15:29,468 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:29,468 DEBUG [WebServer] Incoming connection from /192.168.1.104:57936
2010-09-18 11:15:29,484 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=2965504-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:29,484 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,484 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:29,484 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:29,484 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:29,484 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,484 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:29,484 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:29,484 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1637408940
2010-09-18 11:15:29,484 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:29,484 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 2965504-1640374443/1640374444, Content-Length: 1637408940, Date: Sat, 18 Sep 2010 15:15:29 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:29,531 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:29,546 DEBUG [WebServer] Incoming connection from /192.168.1.104:48835
2010-09-18 11:15:29,546 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=2977792-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:29,546 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,546 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:29,546 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:29,546 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:29,546 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,546 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:29,546 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:29,546 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1637396652
2010-09-18 11:15:29,546 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:29,546 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 2977792-1640374443/1640374444, Content-Length: 1637396652, Date: Sat, 18 Sep 2010 15:15:29 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:29,578 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:29,593 DEBUG [WebServer] Incoming connection from /192.168.1.104:58804
2010-09-18 11:15:29,593 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=1640366080-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:29,593 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,593 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:29,593 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:29,593 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:29,593 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,593 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:29,593 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:29,593 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8364
2010-09-18 11:15:29,593 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:29,593 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 1640366080-1640374443/1640374444, Content-Length: 8364, Date: Sat, 18 Sep 2010 15:15:29 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:29,609 DEBUG [WebServer] I/O error: Connection reset
2010-09-18 11:15:29,625 DEBUG [WebServer] Incoming connection from /192.168.1.104:35047
2010-09-18 11:15:29,625 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=1640333312-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:29,625 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,625 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:29,625 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:29,625 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:29,625 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,625 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:29,625 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:29,625 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 41132
2010-09-18 11:15:29,625 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:29,625 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 1640333312-1640374443/1640374444, Content-Length: 41132, Date: Sat, 18 Sep 2010 15:15:29 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:29,656 DEBUG [WebServer] I/O error: Connection reset
2010-09-18 11:15:29,671 DEBUG [WebServer] Incoming connection from /192.168.1.104:57876
2010-09-18 11:15:29,671 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=16384-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:29,671 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,671 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:29,671 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:29,671 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:29,671 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:29,671 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:29,671 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:29,671 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1640358060
2010-09-18 11:15:29,671 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:29,671 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 16384-1640374443/1640374444, Content-Length: 1640358060, Date: Sat, 18 Sep 2010 15:15:29 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:38,265 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:38,265 DEBUG [WebServer] Incoming connection from /192.168.1.104:48302
2010-09-18 11:15:38,265 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=2965504-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:38,265 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,265 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:38,265 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:38,265 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:38,265 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,265 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:38,265 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:38,281 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1637408940
2010-09-18 11:15:38,281 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:38,281 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 2965504-1640374443/1640374444, Content-Length: 1637408940, Date: Sat, 18 Sep 2010 15:15:38 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:38,328 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:38,343 DEBUG [WebServer] Incoming connection from /192.168.1.104:51692
2010-09-18 11:15:38,343 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=2977792-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:38,343 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,343 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:38,343 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:38,343 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:38,343 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,343 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:38,343 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:38,359 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1637396652
2010-09-18 11:15:38,359 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:38,359 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 2977792-1640374443/1640374444, Content-Length: 1637396652, Date: Sat, 18 Sep 2010 15:15:38 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:38,375 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:38,375 DEBUG [WebServer] Incoming connection from /192.168.1.104:57809
2010-09-18 11:15:38,390 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=1640366080-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:38,390 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,390 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:38,390 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:38,390 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:38,390 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,390 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:38,390 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:38,390 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8364
2010-09-18 11:15:38,390 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:38,390 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 1640366080-1640374443/1640374444, Content-Length: 8364, Date: Sat, 18 Sep 2010 15:15:38 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:38,406 DEBUG [WebServer] I/O error: Connection reset
2010-09-18 11:15:38,406 DEBUG [WebServer] Incoming connection from /192.168.1.104:39403
2010-09-18 11:15:38,406 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=1640333312-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:38,406 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,406 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:38,406 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:38,406 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:38,421 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,421 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:38,421 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:38,421 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 41132
2010-09-18 11:15:38,421 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:38,421 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 1640333312-1640374443/1640374444, Content-Length: 41132, Date: Sat, 18 Sep 2010 15:15:38 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:38,437 DEBUG [WebServer] I/O error: Connection reset
2010-09-18 11:15:38,453 DEBUG [WebServer] Incoming connection from /192.168.1.104:46546
2010-09-18 11:15:38,453 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=2977792-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:38,453 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,453 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:38,453 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:38,453 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:38,453 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:38,453 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:38,453 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:38,453 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1637396652
2010-09-18 11:15:38,453 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:38,453 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 2977792-1640374443/1640374444, Content-Length: 1637396652, Date: Sat, 18 Sep 2010 15:15:38 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:43,250 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:43,296 DEBUG [WebServer] Incoming connection from /192.168.1.104:53165
2010-09-18 11:15:43,296 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=8224768-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:43,296 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:43,296 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:43,296 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:43,312 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:43,312 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:43,312 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:43,312 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:43,312 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1632149676
2010-09-18 11:15:43,312 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:43,312 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 8224768-1640374443/1640374444, Content-Length: 1632149676, Date: Sat, 18 Sep 2010 15:15:43 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:43,328 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:15:43,328 DEBUG [WebServer] Incoming connection from /192.168.1.104:32793
2010-09-18 11:15:43,328 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=8232960-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:15:43,328 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:43,328 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:15:43,328 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:15:43,328 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:15:43,328 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:15:43,328 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:15:43,328 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:15:43,328 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1632141484
2010-09-18 11:15:43,328 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:15:43,328 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 8232960-1640374443/1640374444, Content-Length: 1632141484, Date: Sat, 18 Sep 2010 15:15:43 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:15:46,437 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1025
2010-09-18 11:15:46,750 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1025
2010-09-18 11:15:47,062 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1025
2010-09-18 11:15:56,468 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:3ffad415-9d1a-32d2-80c7-718d4ac17c97 from address /192.168.1.104:1025
2010-09-18 11:15:56,468 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-09-18 11:15:56,687 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:3ffad415-9d1a-32d2-80c7-718d4ac17c97 from address /192.168.1.104:1025
2010-09-18 11:15:56,687 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-09-18 11:15:56,984 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:3ffad415-9d1a-32d2-80c7-718d4ac17c97 from address /192.168.1.104:1025
2010-09-18 11:15:56,984 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-09-18 11:16:11,687 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:16:11,687 DEBUG [WebServer] Incoming connection from /192.168.1.104:59123
2010-09-18 11:16:11,687 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=2965504-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:16:11,687 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,703 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:16:11,703 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:16:11,703 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:16:11,703 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,703 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:16:11,703 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:16:11,703 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1637408940
2010-09-18 11:16:11,703 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:16:11,703 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 2965504-1640374443/1640374444, Content-Length: 1637408940, Date: Sat, 18 Sep 2010 15:16:11 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:16:11,750 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:16:11,750 DEBUG [WebServer] Incoming connection from /192.168.1.104:47630
2010-09-18 11:16:11,750 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=2977792-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:16:11,750 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,750 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:16:11,750 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:16:11,765 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:16:11,765 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,765 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:16:11,765 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:16:11,765 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1637396652
2010-09-18 11:16:11,765 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:16:11,765 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 2977792-1640374443/1640374444, Content-Length: 1637396652, Date: Sat, 18 Sep 2010 15:16:11 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:16:11,781 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:16:11,781 DEBUG [WebServer] Incoming connection from /192.168.1.104:56673
2010-09-18 11:16:11,781 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=1640366080-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:16:11,781 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,781 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:16:11,781 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:16:11,781 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:16:11,781 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,781 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:16:11,781 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:16:11,796 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8364
2010-09-18 11:16:11,796 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:16:11,796 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 1640366080-1640374443/1640374444, Content-Length: 8364, Date: Sat, 18 Sep 2010 15:16:11 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:16:11,812 DEBUG [WebServer] I/O error: Connection reset
2010-09-18 11:16:11,812 DEBUG [WebServer] Incoming connection from /192.168.1.104:45814
2010-09-18 11:16:11,812 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=1640333312-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:16:11,812 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,812 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:16:11,812 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:16:11,812 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:16:11,812 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,812 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:16:11,812 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:16:11,812 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 41132
2010-09-18 11:16:11,812 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:16:11,812 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 1640333312-1640374443/1640374444, Content-Length: 41132, Date: Sat, 18 Sep 2010 15:16:11 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:16:11,843 DEBUG [WebServer] I/O error: Connection reset
2010-09-18 11:16:11,859 DEBUG [WebServer] Incoming connection from /192.168.1.104:60378
2010-09-18 11:16:11,859 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=216137728-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:16:11,859 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,859 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:16:11,859 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:16:11,859 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:16:11,859 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,859 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:16:11,859 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:16:11,859 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1424236716
2010-09-18 11:16:11,859 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:16:11,875 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 216137728-1640374443/1640374444, Content-Length: 1424236716, Date: Sat, 18 Sep 2010 15:16:11 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:16:11,890 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:16:11,906 DEBUG [WebServer] Incoming connection from /192.168.1.104:50907
2010-09-18 11:16:11,906 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=216137728-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:16:11,906 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,906 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:16:11,906 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:16:11,906 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:16:11,906 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:11,906 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:16:11,906 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:16:11,906 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1424236716
2010-09-18 11:16:11,906 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:16:11,906 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 216137728-1640374443/1640374444, Content-Length: 1424236716, Date: Sat, 18 Sep 2010 15:16:11 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:16:16,343 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2010-09-18 11:16:16,359 DEBUG [WebServer] Incoming connection from /192.168.1.104:59464
2010-09-18 11:16:16,359 DEBUG [ResourceTransportRequestHandler] GET /resource/6958/MEDIA_ITEM/MATROSKA HTTP/1.0, headers = [Range: bytes=220540928-, getcontentFeatures.dlna.org: 1, transferMode.dlna.org: Streaming, Host: 192.168.1.102:8895, ]
2010-09-18 11:16:16,359 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:16,359 DEBUG [ResourceTransportRequestHandler] Request for resource 6958 and type 'MEDIA_ITEM' received
2010-09-18 11:16:16,359 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6958)
2010-09-18 11:16:16,359 DEBUG [VideoDAOImpl] Reading a Video (id = 6958)
2010-09-18 11:16:16,359 DEBUG [VideoDeliveryEngine] Delivering item '6958' for client 'IPAddress=/192.168.1.104, Profile=Samsung TV / player (C-series)'
2010-09-18 11:16:16,359 DEBUG [VideoDeliveryEngine] Delivering file 'MKVMPEG4AC3.mkv' in native format
2010-09-18 11:16:16,359 DEBUG [MediaItemDAOImpl] Getting file of media item 6958
2010-09-18 11:16:16,359 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1419833516
2010-09-18 11:16:16,359 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-09-18 11:16:16,359 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-mkv, Content-Range: bytes 220540928-1640374443/1640374444, Content-Length: 1419833516, Date: Sat, 18 Sep 2010 15:16:16 GMT, Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-09-18 11:16:47,468 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1025
2010-09-18 11:16:47,781 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1025
2010-09-18 11:16:47,984 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:9805e361-5ec1-4586-83a9-5b43765d9ddb from address /192.168.1.104:1025
Re: Samsung c series
Just want to dig up this old topic...resuming will work when using Samsung PC share program or playing a file directly connected to USB on my C5000. It will be nice if Serviio can work this way.
Any updates?
Any updates?
resume will be in 0.5.1
Petr
Help translate Serviio
sweet...can't wait.
zip wrote:resume will be in 0.5.1
awesome work ZIP <3
• Page 1 of 2 • 1, 2
Users browsing this forum: Baidu [Spider] and 12 guests
