P42s30 doesnt see serviio
woltmide
Post Wed Jan 11, 2012 10:14 pm
Hi evreybody,
I just installed serviio and have a p42s30, my laptop sees the tv with servio, but i don't have a clue how i get the tv to see my laptop and the maps with the moviefiles. I entered in serviio the maps that should be visible for the panasonic, but i dont know how to acces the files on the tv. I tried via usb/sd button, but it says there is no connection.
Somebody got any ideas?
Grtz,
Woltmide
voodooo
Post Thu Jan 12, 2012 12:04 pm
Re: P42s30 doesnt see serviio
On my TV have to go to "VIERA CONNECT" (green button) -> "Connect to media server".
woltmide
Post Thu Jan 12, 2012 2:24 pm
Thank you for the fast reply.
I did what you said, but i can't see the choice connect to' media server'
Only mediaplayer and that says there is no device attached.
Hope for some other possibilities
grtz,
Woltmide
Post Thu Jan 12, 2012 4:05 pm
voodooo
Post Thu Jan 12, 2012 5:11 pm
That's it, connect to media server. Disable all firewalls i guess..
woltmide
Post Fri Jan 13, 2012 4:32 pm
I don't have the option connect to mediaserver. Perhaps the p42s30 doesnt has a dlna?
voodooo
Post Fri Jan 13, 2012 6:23 pm
According to this link it has: http://shop.panasonic.com/shop/model/TC-P42S30?t=specs
Check your TV's manual on how to connect through DLNA.
woltmide
Post Fri Jan 13, 2012 8:54 pm
I checked the manual but it doesnt state that it has dlna. Perhaps because ive got the dutch model? On the dutch website of panasonic it doesnt say it has dlna.
The tv only has the mediaplayer option using usb or sd, its not possible to connect to mediaserver...
Post Fri Jan 13, 2012 9:29 pm
Can you post your serviio.log file.
Also what is the IP address of the computer running serviio and the P42S30?
Post Sat Jan 14, 2012 8:30 am
woltmide wrote:I checked the manual but it doesnt state that it has dlna. Perhaps because ive got the dutch model? On the dutch website of panasonic it doesnt say it has dlna.
yep that would explain it, guess panasonic decided the dutch dont need dlna.
Return to Panasonic
