Viera TX-L37E30E mkv not playing
int13
Post Thu Jan 12, 2012 7:03 pm
AVIs are playing good, but I have problems playing MKVs. For example, this one cannot be played:
ffmpeg -i drive.mkv
FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1.2, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --extra-version=4:0.5.1-1ubuntu1.2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
built on Sep 16 2011 17:04:18, gcc: 4.4.3
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (54042/1127) -> 24.00 (24/1)
Input #0, matroska, from 'drive.mkv':
Duration: 01:40:24.09, start: 0.000000, bitrate: N/A
Stream #0.0(eng): Video: h264, yuv420p, 1280x528, PAR 1:1 DAR 80:33, 24 tbr, 1k tbn, 47.95 tbc
Stream #0.1: Audio: dca, 48000 Hz, 5.1, s16
The TV player says "file format not supported. I use Panasonic Viera profile. When I try the Generic or for example the Philips profiles, MKVs are played but either slow, or sound is glitchy.
Here's my Viera profie:
<Profile id="12" name="Panasonic Viera" extendsProfileId="1">
<MediaFormatProfiles>
</MediaFormatProfiles>
<!-- remux DTS/FLAC/LPCM in MKV/MP4 to AC3 -->
<Matches container="matroska" vCodec="h264" aCodec="dca" />
<Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
<!-- Remux all h264 video to MPEG-TS stream -->
<Matches container="matroska" vCodec="mpeg2video"/>
<!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
<Matches container="asf" />
<Matches container="flv" />
<Matches container="ogg" />
<Matches container="3gp" />
<Audio targetContainer="mp3">
<Matches container="mp4" />
<Matches container="flac" />
<Matches container="adts" />
</Audio>
I use the latest download of Serviio.
voodooo
Post Thu Jan 12, 2012 7:13 pm
Re: Viera TX-L37E30E mkv not playing
int13 wrote:Seems stream 0 codec frame rate differs from container frame rate: 47.95 (54042/1127) -> 24.00 (24/1)
I have the same TV model, except its 42' and i can play MKV just fine, can you remuxe your mkv to DAR 16:9 and try again ? Is this happening with all your mkvs ?
If the DAR change does not work, try to convert the MKV sound to AC3 or DTS, cause in my tests these 2 formats play. Will try to play DCA sound later.
int13 wrote:The TV player says "file format not supported. I use Panasonic Viera profile. When I try the Generic or for example the Philips profiles, MKVs are played but either slow, or sound is glitchy.
I believe that when you change to Philips profile, the philips TV cannot natively play mkv files, so, serviio starts transcoding and your PC cannot do-it on-the-fly. Thats why they run slowly.
Regards.
Return to Panasonic
