A.P.P for Serviio 1.4.1 - Last Update (24/10/2013)
How often do you check to see if there is a plugin pack update?
Daily
37
19%
Weekly
77
39%
Monthly
63
32%
Never
20
10%
Total votes : 197
zit1343
Post Mon Jan 09, 2012 10:17 pm
Re: All Plugins Pack 0.6.1 (07/01/12)
I extracted all the files in /plugin folder I restarted my pc & my sony player
I do not see any plugins there such as yahoomovies or megavideo
m I doing something wrong?
WildRushSykes
Post Mon Jan 09, 2012 10:53 pm
megavideo and yahoo plugins are both in my pack just checked. Do you mean the feeds arent showing up or that the plugins are not in the plugins folder?
maltmoose
Post Thu Jan 12, 2012 8:48 pm
Re: All Plugins Pack 0.6.1 (13/01/12)
great work on compiling these plugins.
What would be really nice is a little script that will download and extract these plugins to my ubuntu server every week :0
plugin support should be more automated in the long run
WildRushSykes
Post Thu Jan 12, 2012 9:30 pm
Zip was against automated downloading thats why i compiled this pack so it would make it easier to download them. Im sure automation maybe looked at again in the future :D
sunchar
Post Fri Jan 13, 2012 4:34 am
Thanks!!!
This pack is really helpfull.
englishwhistler
Post Mon Jan 16, 2012 11:59 pm
Re: All Plugins Pack 0.6.1 (16/01/12)
I've copied the plugins into my PC folder (Plugins) but nothing is showing up.
If I need to add the plugin feed into the online library - what are the feeds for each of the plugins in the plugin pack please?
kappclark
Post Tue Jan 17, 2012 12:28 am
Thx for doing this - I am getting CNN loud and clear now
WildRushSykes
Post Tue Jan 17, 2012 8:18 am
@whistler most of the feeds are located in the individual plugins thread
@kappclark thats good to hear :D
PMI
Post Mon Jan 23, 2012 4:51 am
Re: All Plugins Pack 0.6.1 (20/01/12)
I have installed the Plugin Pack and tested with a few common feeds like Hulu, YouTube, and a couple US news feeds.
It is working well so far, and thanks for consolidating the plugins into one neat package!
I would like to try some feeds from Europe, and past experience has been that some feeds that work well in Europe are a bit iffy here... So, I would like to ask anyone who is familiar with what works (and what doesn't), for some suggestions of some common examples which:
a) originate in Europe and work in Europe without issues and
b) in some language I can understand, incl. German, French (or English, obviosuly)
News or other common example would be ideal.
Thanks in advance.
Peter
WildRushSykes
Post Mon Jan 23, 2012 4:29 pm
It would help if i knew where you were from :D
Im from england and so far all uk only content works really well so far i dont have access to us only content but im sure someone from the us will answer your questions :D
and thanks for the feedback on the plugins pack glad it worked out for you ;)
PMI
Post Mon Jan 23, 2012 7:48 pm
WildRushSykes wrote:It would help if i knew where you were from :D
Yes, good point (chuckle). From Milwaukee, in the US. Most internet connections here are made through Chicago. I can play some UK-only content on my computer, either through proxy servers, or other workarounds, but that was not really what I was trying to do.
To explain properly:
In the past, a lot of feeds and/or video-related resources in Europe just do not play or do not play well in my area. Most US streams and rss feeds work fine, and so do audio streams from anywhere (like radio stations).
This includes not only the UK-restricted BBC feeds which are clearly labeled UK only. Fox example, I tried TF-1 as described in this forum, and I get nothing (not sure I got the url correctly, b/c seems to have some extra chars in it, but for now, nothing).
So, to the point:
...to test, I wanted to ask someone from Europe to post a couple rss feeds (not streams) which are local to the poster, and 1) work in Europe, 2) use the plugins from the pack, and 3) in some language I can understand (Fr, Engl, Ger), so I can do some testing...
So far, one of the Hulu feeds I tried, the audio was occasionally out of sync w. the video. Also, same feed, after pause and resume, video would break up and did not sync for about ten seconds. Only one out of several I tested, so that may be a Hulu problem, not sure.
And, not to belabor the point, putting the plugins into one neat package with winrar worked really well, and saved a lot of time.
Peter
tombert
Post Thu Feb 02, 2012 9:59 pm
Re: All Plugins Pack For Serviio 0.6.2 - Last Updated (02/02
Some knows something about this youtube error?
java.io.IOException: Cannot parse resource from http://www.youtube.com/t/rss_fee
ds. Message: Error during feed parsing, provided URL probably doesn't point to a
valid RSS/Atom feed. Message: Invalid XML: Error on line 46: The element type "
link" must be terminated by the matching end-tag "</link>".
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLi
braryManager.java:177)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOr
Parse(OnlineLibraryManager.java:184)
at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(
FeedUpdaterThread.java:158)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdater
Thread.java:95)
thx
WildRushSykes
Post Thu Feb 02, 2012 10:30 pm
http://www.youtube.com/t/rss_fee is not a valid feed and reports a 404 error through my browser check your feed link again and try again
Post Thu Feb 02, 2012 10:54 pm
WildRushSykes wrote:http://www.youtube.com/t/rss_fee is not a valid feed and reports a 404 error through my browser check your feed link again and try again
you have the link wrong its http://www.youtube.com/t/rss_feeds :) but yer its not valid as it points to the feed help page and not an actual feed :)
tombert
Post Fri Feb 03, 2012 7:54 am
Well ok ...
I simply searched in google for "youtube feeds" and this link came up.
The point is - I couldn't find nowhere a list of working feeds ... and I'am new to this "feeds" stuff - thats probably the reason for me having troubles.
Are there any links, collections etc. you can share with me?
thx
Post Fri Feb 03, 2012 9:29 am
tombert wrote:Are there any links, collections etc. you can share with me?
thx
viewtopic.php?f=23&t=3279
Post Fri Feb 03, 2012 8:58 pm
How to Get YouTube Videos to Play in Serviio
http://wiki.serviio.org/doku.php?id=you_tube_videos
WildRushSykes
Post Sun Feb 12, 2012 7:44 am
Re: All Plugins Pack For Serviio 0.6.2 - Last Updated (11/02
Post is now more popular than youtube :D Now im after bbc iplayers crown :lol:
Xmantium
Post Thu Feb 23, 2012 4:23 pm
Re: All Plugins Pack For Serviio 0.6.2 - Last Updated (21/02
Some plugins now are invalid, either the website is no longer providing the feed or down
Examples
Yahoo Movie Trailers - All RSS removed, they relaunched a new trailer page but no RSS
Megavideo - Well... i think they are being looked after by the FBI
Best to not include these and put DISCONTINUED or something in red
WildRushSykes
Post Sat Mar 10, 2012 9:53 pm
Re: All Plugins Pack For Serviio 0.6.2 - Last Updated (10/03
:o I forgot to remove the megavideo plugin. All done now and updated OP with discontinued in red thanks for the tip :D
Return to Available plugins
