[SOLVED] Sony KDL-32CX521 does not play video file
lavvash
Post Wed Jan 11, 2012 8:06 am
Hi all, hope someone can help.
Many thanks to developers for the excellent program.
A computer running windows 7 X64 installed Serviio
TV Sony KDL-32CX521 is connected to the network through the ASUS rt n13u
TV on the latest available firmware for Russia
http://www.sony.ru/support/ru/product/K ... ia_3807EUA
From TV to connect to Serviio is successful, the video played perfectly. Profile of selected Sony Brava 2011.
Unfortunately I can not play the video file with the following characteristics (mediainfo)
Complete name : D:\ServerFolders\Фильмы\Prisluga.2011.XviD.HDRip.avi
Format : AVI
Format profile : OpenDML
File size : 2.05 GiB
Duration : 2h 26mn
Overall bit rate : 2 006 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2h 26mn
Bit rate : 1 610 Kbps
Width : 720 pixels
Height : 384 pixels
Display aspect ratio : 1.875
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.243
Stream size : 1.64 GiB (80%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 2h 26mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 402 MiB (19%)
Alignment : Split accross interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 500 ms
How to solve this problem ?
WildRushSykes
Post Wed Jan 11, 2012 8:13 am
Re: Sony KDL-32CX521 does not play video file
The mediainfo looks like a standard xvid file to me so should be fine the only thing is the BVOP setting but that shouldnt prevent it from playing it may just be a broken file do all other xvid files play?
lavvash
Post Wed Jan 11, 2012 8:40 am
This file plays fine with Home Media Server
http://www.homemediaserver.ru/
he also
Wild Media Server
http://www.wildmediaserver.com/
NX3
Post Wed Jan 11, 2012 8:49 am
If you can't resolve the issue with the file set your profile to the Sony 2010 profile, not the 2011 profile. The AVI will be transcoded as mpeg2 and play then. Its possible that's what the other DLNA server apps your linked to are doing to make it play.
Post Wed Jan 11, 2012 9:02 am
Probably because Russia 2011 firmware does not support DivX media (There were some difference between states : US, CA, UK, RU,etc)
Select Sony 2010 Profile that transcode avi files.
To confirm, please could you provide this result ?: http://wiki.serviio.org/doku.php?id=device_sf
lavvash
Post Wed Jan 11, 2012 9:43 am
codecs are supported by the television set
http://www.sony.ru/support/ru/product/K ... -solutions
In the evening try to change the profile, the results will inform
Intel UPnP review
lavvash
Post Wed Jan 11, 2012 10:00 am
This page
viewtopic.php?f=11&t=3662
requires firmware PKG3.807EUA (19/12/2011)
This page
my firmware (22/12/2011) PKG3.807EUA
What can I do not understand, but I think it's not in the firmware - it is the same at both sites
Or there is a dependence on the region?
how to change the region in the TV?
Post Wed Jan 11, 2012 10:53 am
lavvash wrote:my firmware (22/12/2011) PKG3.807EUA
OK, the device is updated.
lavvash wrote:Or there is a dependence on the region?
Don't know.
We're waiting for INTEL Upnp result.
lavvash
Post Wed Jan 11, 2012 3:01 pm
Profile Bravia 2010 - play this video file :)
My firmware PKG3.807eua-0104
Result UPNP utilites
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_T;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;SONY.COM_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;SONY.COM_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;SONY.COM_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;SONY.COM_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;SONY.COM_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_JP_T;ARIB.OR.JP_PN=MPEG_TTS_CP;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_60_L2_T;SONY.COM_PN=HD2_60_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_50_L2_T;SONY.COM_PN=HD2_50_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_60_L2_ISO;SONY.COM_PN=HD2_60_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_50_L2_ISO;SONY.COM_PN=HD2_50_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_AC3_T;SONY.COM_PN=DTCP_SESF_60_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_L2_T;SONY.COM_PN=DTCP_SESF_60_L2_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L1_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L2_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_T;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;SONY.COM_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;SONY.COM_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-mp2t-mphl-188:*,
http-get:*:image/jpeg:*,
http-get:*:audio/mpeg:*,
http-get:*:audio/L16:*,
http-get:*:audio/x-ms-wma:*,
http-get:*:video/mpeg:*,
http-get:*:video/vnd.dlna.mpeg-tts:*,
http-get:*:video/mp4:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/x-divx:*,
http-get:*:video/divx:*,
http-get:*:video/avi:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/x-ms-asf:*
viewtopic.php?f=5&t=7
Post Thu Jan 12, 2012 11:54 am
lavvash wrote:Profile Bravia 2010 - play this video file :)
Cool,
lavvash wrote:Result UPNP utilites
So use the profile Bravia 2011 by default, should support avi/divx file, but some file should failed then select 2010 profile.
lavvash
Post Thu Jan 12, 2012 1:49 pm
What is the difference between the profiles Bravia 2010 vs Bravia 2011 ?
Can leave the default profile Bravia 2010 ?
Post Thu Jan 12, 2012 2:05 pm
lavvash wrote:What is the difference between the profiles Bravia 2010 vs Bravia 2011 ?
Bravia 2010 transcode ALL DivX avi files, Bravia 2011 may support DivX file without transcoding (with exception).
lavvash wrote:Can leave the default profile Bravia 2010 ?
Yes, all avi file will be transcoded.
lavvash
Post Thu Jan 12, 2012 5:15 pm
thank you
Sony TV 2010 profile : transcoded avi into a mpeg2 video stream (supported by 2010 and 2011 models)
Sony Tv 2011 profile : delivered avi file in native format, but its seems that 2011 models only supports SD format, not HD (1280x544 in this case)
viewtopic.php?f=11&t=3683
I have a new problem
out of sync video and audio playback of the file, just twitches and frozen bell - especially in dynamic scenes
changing the profile 2010-2011 did not help
Unique ID : 206819410662566746743958255100928181842 (0x9B97F83833662515834D09DFE683C652)
Complete name : D:\ServerFolders\Фильмы\Zhivaja.stal.2011.x264.BDRip.1080p.mkv
Format : Matroska
Format version : Version 2
File size : 13.6 GiB
Duration : 2h 6mn
Overall bit rate : 15.4 Mbps
Movie name : UNIONGANG.TV
Encoded date : UTC 2012-01-11 15:31:51
Writing application : mkvmerge v5.2.1 ('A Far Off Place') built on Jan 2 2012 23:21:10
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 6mn
Bit rate : 13.5 Mbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.359
Stream size : 11.7 GiB (86%)
Title : DON
Writing library : x264 core 116 r2057 0ba8a9c
Encoding settings : cabac=1 / ref=3 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=13500 / ratetol=1.0 / qcomp=0.65 / qpmin=0 / qpmax=40 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.25 / pb_ratio=1.25 / aq=1:0.65
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Codec ID : A_AC3
Duration : 2h 6mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 348 MiB (2%)
Title : Dub
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 2h 6mn
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Stream size : 1.34 GiB (10%)
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Voronin
Language : Russian
Default : No
Forced : No
Text #2
Format : UTF-8
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Title : SDH
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:03:00.472 : en:00:03:00.472
00:10:38.304 : en:00:10:38.304
00:18:50.546 : en:00:18:50.546
00:24:29.885 : en:00:24:29.885
00:34:14.761 : en:00:34:14.761
00:41:22.355 : en:00:41:22.355
00:48:46.131 : en:00:48:46.131
00:52:08.709 : en:00:52:08.709
00:57:15.015 : en:00:57:15.015
01:05:01.231 : en:01:05:01.231
01:12:33.974 : en:01:12:33.974
01:18:26.994 : en:01:18:26.994
01:26:28.517 : en:01:26:28.517
01:32:50.773 : en:01:32:50.773
01:39:19.704 : en:01:39:19.704
01:48:22.663 : en:01:48:22.663
01:52:26.865 : en:01:52:26.865
01:57:21.868 : en:01:57:21.868
02:00:50.326 : en:02:00:50.326
lavvash
Post Fri Jan 13, 2012 8:10 am
Is that bad?
This film starts badly play 10 minutes after launch.
Boot the computer when playing the movie at an average level
now try to run this movie in 720p
Post Fri Jan 13, 2012 8:21 am
lavvash wrote:Format : Matroska
Format : AVC
Height : 816 pixels
That could be a hight video bitrate : check with that tools that video bitrate always less than 20-25Mbps http://wiki.serviio.org/doku.php?id=vbitrate
That also could be a transcoding h264 option.
lavvash
Post Fri Jan 13, 2012 9:22 am
tested this 1080 file bitrate viewer
result
Peak 28325
Average 13496
this movie in 720p
Peak 13442
Average 6301
I think this file will be played without any problems. very hopeful.
another thank you from Russia:)
At night on the results accomplish your goal.
Find this page
viewtopic.php?f=11&t=1769
Post Fri Jan 13, 2012 9:50 am
lavvash wrote:tested this 1080 file bitrate viewer
result
Peak 28325
Average 13496
Peak 28325 is probably the reason
lavvash wrote:this movie in 720p
Peak 13442
Average 6301
video rate is better
lavvash wrote:I think this file will be played without any problems. very hopeful.
Find this page
hopefully
lavvash
Post Fri Jan 13, 2012 3:19 pm
720 P video file PLAY
:) Спасибо !!!
lavvash
Post Wed Jan 18, 2012 6:17 pm
Re: [SOLVED] Sony KDL-32CX521 does not play video file
I updated my firmware to the new TV
Now that the file I pointed out earlier 1080p plays perfectly.
About this upgrade (18/01/2012)
This file updates your TV set firmware to version PKG3.904EUA, and provides the following benefits:
Improvements in this version:
Improves TV performance during 1080i / 1080p transitions
lavvash
Post Sat Jan 28, 2012 5:53 pm
Unique ID : 223838873953785662187739151746223368303 (0xA865CC8BB1806032B5CD7E68658CE86F)
Complete name : D:\ServerFolders\Torrent\Bablo.2011.x264.BDRip(720p).mkv
Format : Matroska
File size : 5.43 GiB
Duration : 1h 31mn
Overall bit rate : 8 458 Kbps
Movie name : Rip by - Seksi03 - X-TORRENTS
Encoded date : UTC 2011-11-22 09:10:58
Writing application : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
Writing library : libebml v1.2.2 + libmatroska v1.3.0
Format : AVC
Format profile : High@L5.1
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=15
Duration : 1h 31mn
Bit rate mode : Variable
Bit rate : 6 729 Kbps
Maximum bit rate : 9 739 Kbps
Width : 1 280 pixels
Height : 690 pixels
Display aspect ratio : 1.855
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.318
Stream size : 4.32 GiB (80%)
Title : Rip by - Seksi03 - X-TORRENTS
Default : Yes
Forced : No
Format : DTS
Format profile : MA / Core
Codec ID : A_DTS
Duration : 1h 31mn
Bit rate : 1 561 Kbps / 1 510 Kbps
Bit depth : 16 bits
Compression mode : Lossless / Lossy
Language : Russian
Default : Yes
Forced : Yes
Menu
00:00:00.000 : en:(01)00:00:00:000
00:05:39.714 : en:(02)00:05:39:714
00:11:42.451 : en:(03)00:11:42:451
00:19:21.118 : en:(04)00:19:21:118
00:25:20.185 : en:(05)00:25:20:185
00:30:28.284 : en:(06)00:30:28:284
00:37:07.934 : en:(07)00:37:07:934
00:43:26.687 : en:(08)00:43:26:687
00:50:37.534 : en:(09)00:50:37:534
00:55:13.643 : en:(10)00:55:13:643
01:02:06.639 : en:(11)01:02:06:639
01:07:19.910 : en:(12)01:07:19:910
01:12:58.332 : en:(13)01:12:58:332
01:18:02.052 : en:(14)01:18:02:052
01:22:23.438 : en:(15)01:22:23:438
01:28:52.035 : en:(16)01:28:52:035
01:31:59.597 : en:(17)01:31:59:597
Peak bitrate 14444
average 6492
error - Format profile : High@L5.1 ?
