[OLD] Android Console
Post Wed Jan 11, 2012 10:09 am
Re: Android Console
Cerberus wrote:yer sadly free versions have to have ads, thats part of googles rules :( so a donate version for about £1 should work for most users.
1. Delete devices badly needed.
2. Presentation and about page tabs needed rather than in setting.
so far everything else seems to work, shows as expected.
I didn't realise that. Have you got a link to some informantion about that? I can't see anything imediately obvious in the docs.
Device management will be in the next release by the end of the week(end)
Moving presentation could work, I need to get more titles displayed on screen at once. I think I'll keep the about where it is though as it won't have any of the update info in it so will just be some text, I might just turn it back into a dialog.
Post Wed Jan 11, 2012 10:30 am
Re: Android Console
i dont no but going on what people i deal with have said, i work in IT industry.
ah yes found the about page after some digging, damn that was hidden lol, yer presentation definately has to be a tab rather than in settings and can you not link the setting for each tab from the tab rather than a setting tab of its own ??
Post Wed Jan 11, 2012 10:40 am
Re: Android Console
Well if you could find something written down that says that then that would help.
I could, but it think I would rather keep settings on their own. The tabs are only for things that are used often.If there are settings that poeple use all the time then I might promote them. However from my personal use, I hardly ever touch them. That is also why I kept presentation in the settings.
@Everyone using the app/serviio in general: Are there any settings you change often? Do you have a need to change the presentation visibility often or do you set it and leave it most of the time?
Post Wed Jan 11, 2012 10:50 am
Re: Android Console
its not really a usage for me ( i hardly open my console) but for newbie users if it not all in one place they get lost.
Post Wed Jan 11, 2012 11:23 am
Re: Android Console
something i have noticed is status page needs to auto refresh as if u click force update it doesn't update the number of files added or ball colour until u click refresh at top of screen.
Post Wed Jan 11, 2012 11:32 am
Re: Android Console
Thats on my todo list along with auto refreshing when the UPnP/DLNA server is starting up. I'll update the issue to include it.
Post Wed Jan 11, 2012 11:53 am
Re: Android Console
will wrote:Thats on my todo list along with auto refreshing when the UPnP/DLNA server is starting up. I'll update the issue to include it.
good to hear :D
Xmantium
Post Wed Jan 11, 2012 7:08 pm
Re: Android Console
If anyone is having problems with stock bowser, I use the android firefox browser to download the .apk and it allows you to install it too direct from the download section. :D
Xmantium
Post Wed Jan 11, 2012 9:56 pm
Re: Android Console
Just installed beta 10.
I think it would be much better if the Presentation settings moved to "Library" like you did with Online Sources, after the online sources
Presentation settings for parents title and language are hardly changed
And have "Presentation" just for visibilty change
Post Thu Jan 12, 2012 9:00 am
Re: Android Console
Yes I think I'll do that. I will however do device management first otherwise I'm never going to get it done.
Post Fri Jan 13, 2012 1:00 pm
Re: Android Console
@Xmantium can you clarify what you ment as reading it now I'm not quite sure
Beta 10 setup was the following tabs
Status
Devices
Shared Folders
Online Sources
Settings
Under 'Settings' tab:
Library
Trancoding
Metadata
Presentation (parents title and language)
Presentation - visibility
Cerberus suggested moving Presentation - visibility part to a new tab, thats also what I initially thought you ment so In my current build I now have the following tabs
Status
Devices
Shared Folders
Online Sources
Presentation
Settings
and under 'Settings' tab:
Library
Trancoding
Metadata
Is that what you ment or did you mean something different?
Post Fri Jan 13, 2012 1:13 pm
Re: Android Console
will wrote:Cerberus suggested moving Presentation - visibility part to a new tab, thats also what I initially thought you ment so In my current build I now have the following tabs
Status
Devices
Shared Folders
Online Sources
Presentation
Settings
Library
Trancoding
Metadata
Yer that what i ment but id put the settings as a Advanced button on relevent page ratehr than seperate tab but thats me. :) easyt o help user to just say click advance button than telling them its hidden in a settings tab :)
Post Fri Jan 13, 2012 1:17 pm
Re: Android Console
Yes but for settings such as transcoding and metadata, there is no relivent tab, and I don't want to have loads of tabs as it makes navigating around slow.
I'll have to have a think about this.
Post Fri Jan 13, 2012 1:30 pm
Re: Android Console
will wrote:Yes but for settings such as transcoding and metadata, there is no relivent tab, and I don't want to have loads of tabs as it makes navigating around slow.
yer metadata/library/share folders are all same thing i think and transcoding you could have as tab of its own instead of settings so like this:
Status
Devices
Shared Folders ( renamed Local Sources or Local Library ) with buttons for metadata and library settings
Online Sources
Presentation with its settings button
Transcoding
just my take on it :)
Post Fri Jan 13, 2012 6:00 pm
App name and icon help
After talking with Zip, we have agreeded to keep official Serviio products, and 3rd party apps a little seperated. Therefore I need some help choosing a name for the app and designing an icon.
App name rules:
It cannot contain 'Serviio', but can contain parts, e.g. Droidiio
Icon rules:
It cannot be the current serviio logo, but can use the shapes, themes, ideas from it, or it could be totally different. It can be a very rough Idea to a polished masterpice.
Should look good from 36x36 all the way upto 512x512 (ie not too much detail)
General rules
1) by submitting an idea you give me full permision to use it in anyway I see fit.
2) I'll setup a poll to let people vote, but I will have the final choice over the name and icon
Thank you in advanced for any ideas. Also keep the requests comming for the app.
Post Fri Jan 13, 2012 6:20 pm
Re: App name and icon help
will wrote:After talking with Zip, we have agreeded to keep official Serviio products, and 3rd party apps a little seperated. Therefore I need some help choosing a name for the app and designing an icon.
App name rules:
Icon rules:
Should look good from 36x36 to 128x128 (ie not too much detail)
General rules
will do this tomorrow for you gives me something to do on a sat stuck at work but personaly i think it should use the serviio icon and name as without it it could be related to anything.
Post Fri Jan 13, 2012 7:34 pm
Re: Android Console
Well serviio will the in the app's description/market listing and there will be information about it on the Serviio website.
Hopefully I will get a range of ideas, and zip can comment on their suitability.
Xmantium
Post Fri Jan 13, 2012 10:13 pm
Re: Android Console
NOOOOOOOO!!!! I actually like the name Serviio Droid! :cry:
But there's so many apps like XBMC Remote that use XBMC name and logo as long it's free app and makes it clear it's not endorsed by xbmc
About the presentation settings,
It should be simple Under 'Settings' tab:
Library
Transcoding
Metadata
Presentation
This can be resolved by either:
- "Presentation settings" placed in "Library" Settings after Online Source preferences (it's still related to library as it's settings how the library is viewed)
Or
-Presentation, the settings after the presentation views (just like the console)
Or
-Presentation has presentation settings on Action button option
Post Sat Jan 14, 2012 8:30 am
Re: Android Console
I initially put about 15 seconds into that name, so I'm sure there is another name out there.
With a suitable market description, then when someone types 'serviio' into the android market, the app should come up. Combined with having a link to it from the serviio website to the app, people should be able to find it.
Anyway Beta 11 is now ready Beta 11
This adds device management, automatic refresh on the status view, moves presentation settings and adds multiple view titles to the screen if they will fit.
Inparticular I want feedback on the automatic refresh and the new way that tabs are displayed. Try in on your phones and tablets in landscape and portrait and based on feedback I will adjust the padding etc.
*Implemented #21: Show more than three view titles on large phone screens
*Implemented #15: Automatically refresh data when starting/stopping the server and when the update checker is running - it may need adjusting based on feedback
*Added server name to status view
*Performance improvements when scrolling devices, shared folders and online sources lists
*Implemented #24: Move the main part of presentations settings to a top level tab
*Lists now keep their scroll position when updated
*All context menu actions except edit now show a toast. e.g. Deleting 'Device name'
*Added #4: Manage devices
*Fixed #19: Bad profile data getting though validation
Post Sat Jan 14, 2012 8:38 am
Re: Android Console
will wrote:I initially put about 15 seconds into that name, so I'm sure there is another name out there.
*Fixed #19
will test tonight when im home :) out of intrest what was #19 that you fixed??
Users browsing this forum: No registered users and 194 guests
