TX32dt35e no remote control
norsa
Post Fri Jan 13, 2012 5:31 pm
Hi, my platform is a new panasonic TX32DT35E and a macbook with OS 10.6.8. I have installed serviio v0.6.1 yesterday. It runs very good and I have to say, it is a very fine software. I have only one problem and I cant find any tip to solve it.
The problem is: DLNA server remote control on TV is on, but it is impossible to fast forward, rewind or set pause.
could you please give me a help to solve it?
many tks in advance
voodooo
Post Fri Jan 13, 2012 6:27 pm
Re: TX32dt35e no remote control
Hello.
Check if you are transcoding the files, cause when you'r transcoding it isn't possible to FF.
Post Fri Jan 13, 2012 7:41 pm
on most renderer's remote controls you do not use the ff/rev buttons, but the left and right arrow buttons.
norsa
Post Sat Jan 14, 2012 11:11 am
I try it without transcoding, it also doesnt work. Also the left an right button on remote control dont work.
Do you have any other idea?
Post Sat Jan 14, 2012 11:24 am
DT series does not support it only PLAY and STOP
norsa
Post Sat Jan 14, 2012 2:07 pm
is it a malfunction of serviio or panasonic software? the panasonic dt shows the ff and rew when starting a movie. ff on right button an rew on left.
Post Sat Jan 14, 2012 2:16 pm
norsa wrote:is it a malfunction of serviio or panasonic software? the panasonic dt shows the ff and rew when starting a movie. ff on right button an rew on left.
pansonic, the DLNA spec for DT series only show play and pause and nothing else.
norsa
Post Sat Jan 14, 2012 4:06 pm
i have contact the panasonic support and they say it is a server software problem. with twonky, win7 and other ff,rew and pause works fine.
Post Sat Jan 14, 2012 4:11 pm
norsa wrote:i have contact the panasonic support and they say it is a server software problem. with twonky, win7 and other ff,rew and pause works fine.
install twonky then and take a waveshark reading of it working then and FYI win7 isnt a DLNA server.
norsa
Post Sun Jan 15, 2012 10:47 am
now i have tested with isedora demo version and ff, rew and pause works fine.
Post Sun Jan 15, 2012 10:55 am
norsa wrote:now i have tested with isedora demo version and ff, rew and pause works fine.
take a waveshrk capture of it working.
Return to Panasonic
Users browsing this forum: Baidu [Spider] and 10 guests
