Editing the media library DB
CraigD wrote:What would be the best way to edit the derby DB? I'm not too familiar with Derby, so I'm looking here to see if anyone has any suggestions. The main reason I want to do this is because I have a few movies that Serviio has got wrong or just can't find and I would like to add/correct them manually.
This VBs Script (Windows Only) will parse the Serviio.log file looking for films which failed online Metadata lookup with an error... Ie time out/Connection error while querying the online database and will Move them to another folder so they can be reimported to force Metadata Rescan.
Any film found with MetaData lookup errors will be moved from it's current location to <Film Drive>\Temp\Serviio\<subfolders> (Keeping your folder structure). With the films moved to a new folder Serviio will remove the films from the database (about an hour). Once the films have been removed from the database manually copy the films back to their original location to get Serviio to rescan Metadata for just these films.
When run the script will ask for the root path to your films.. IE x:\myfilms it uses this in conjunction with Serviio.log to identify series folders so it can keep the folder structure. Each film with a lookup error will be moved to <Film Drive>\temp\Serviio\<Sub Folders>
This script is designed to enable you to rescan just films which got metadata Errors, so you don't have to rescan all the files and maybe get lookup errors on other films.
moltra wrote:CraigD wrote:What would be the best way to edit the derby DB? I'm not too familiar with Derby, so I'm looking here to see if anyone has any suggestions. The main reason I want to do this is because I have a few movies that Serviio has got wrong or just can't find and I would like to add/correct them manually.
There is a windows script that should help with your problem, if you are using windows.
http://forum.serviio.org/viewtopic.php?f=17&t=3865
- Code:
CraigD wrote:2 examples of in correctly or missed files:
Leon (1994).m2ts gets pick up as Lion King
Hangover Part II, The.m2ts doesn't find a match
Users browsing this forum: No registered users and 54 guests
