online folder
• Page 1 of 1
I can't see this folder, I tried youtube plugin and nothing appears, I tried several feeds that work in Google Reader. The log file shows no errors. Any help? I
Re: online folder
did you read this? http://www.serviio.org/index.php?option ... icle&id=42
Petr
Help translate Serviio
Re: online folder
Yes, I did. The folder was displayed in the previous version (0.6). I've tried the pack plugin and the youtube post plugin (I tried the examples urls from youtube post). Any advice?
Thanks, I love this software.
Re: online folder
There is a bit of a bug in the youtube plugin now. Can you try any other resource?
Petr
Re: online folder
I tried some live stream radios like:
http://194.169.201.177:8085/liveM80.mp3
http://194.169.201.177:8085/liveDial.mp3
They work in VLC, but I don´t see the online folder.
Re: online folder
It works for me. Did you select Live stream when adding the URL in the console?
Petr
Re: online folder
I solve it, I don't choose display online folder in presentation settings. Thanks, great soft
• Page 1 of 1
