Samsung C/D profile not playing m2ts after upgrade to 0.6.1
gbdb
Post Thu Jan 12, 2012 12:01 pm
After upgrading to 0.6.1 I found that m2ts movies would no longer play on my Samsung TV with an invalid codec message. I copied the video file to a USB stick and was able to play it directly on the TV so this sent me back to investigate what might have changed in Serviio since the upgrade. I found that in the profile.xml the details for the Samsung C/D series had changed. After saving a copy of the profile.xml I copied the C/D section from the bkup version of the old xml file and pasted it into the current profile.xml replacing the text that was there and the m2ts videos will now play on the TV.
Although this seems to have fixed my problem, I'm wondering what changed in the profile for this device and if there is a better fix than what I did?
thanks.
Post Thu Jan 12, 2012 1:39 pm
Re: Samsung C/D profile not playing m2ts after upgrade to 0.
can you post result on ffmpeg -i for the file?
gbdb
Post Fri Jan 13, 2012 11:21 am
Hi Zip,
Here is the result of the run.
C:\Program Files\Serviio\lib>ffmpeg -i "D:\Shared documents\My Videos\Home Video
\6. Sep 11 - Nov 11\00334. EOY Concert 2011 - Running of the Bulls.m2ts"
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 50.00 (50/1)
Input #0, mpegts, from 'D:\Shared documents\My Videos\Home Video\6. Sep 11 - Nov
11\00334. EOY Concert 2011 - Running of the Bulls.m2ts':
Duration: 00:06:13.38, start: 1.000033, bitrate: 10470 kb/s
Program 1
Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p, 1440x1
080 [SAR 4:3 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0:1[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), s1
6, 448 kb/s
Stream #0:2[0x1200]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
thanks
Grant
Post Fri Jan 13, 2012 11:20 pm
thanks. could you also run detailed log with the new profile vs the old one?
gbdb
Post Sat Jan 14, 2012 2:01 am
Hi Petr,
Do you want to see the output after just starting the service (small output) or after starting the console as well (huge output)?
Grant
Post Sat Jan 14, 2012 9:14 pm
no need the console, but I need you to try to play the file for a few seconds
gbdb
Post Sat Jan 14, 2012 10:32 pm
Hi Petr,
I used both profiles and ran the video for a few seconds for each. The name of the video is 00334. EOY Concert 2011 - Running of the Bulls.m2ts. It successfully runs with the old profile but when tried with the 0.6.1 profile gives the codec error message. It then moves onto the next video and tries to run that one where it will fail again. The second video is called 00335. EOY Concert 2011 - The Cup of Life.m2ts and I turned the TV off after it began to try to access that file. I have attached the logs here and named them for each run.
regards
Grant.
0.6.1 version serviio.log
(138.57 KiB) Downloaded 623 times
old version serviio.log
(475.25 KiB) Downloaded 585 times
Post Sun Jan 15, 2012 12:18 am
ok. Can you also post mediainfo of the file?
gbdb
Post Sun Jan 15, 2012 5:48 am
Hi Petr,
What do you mean by mediainfo for the file?
Sorry, new to this game.
Grant.
WildRushSykes
Post Sun Jan 15, 2012 6:19 am
gbdb
Post Sun Jan 15, 2012 9:23 am
The results of running ffmpeg are at the start of this set of posts, so I assumed that Petr mean't something different. I googled MediaInfo and found the SourceForge MediaInfo software. So I'm hoping this is what Petr mean't and have attached the output.
regards
Grant
MediaInfo.txt
(2.58 KiB) Downloaded 625 times
Post Sun Jan 15, 2012 12:44 pm
thanks. could you now remove the file from library and add it again, still with detailed log on? and post the log.
gbdb
Post Mon Jan 16, 2012 3:31 am
Hi Petr,
Removed the file from the library and reinserted it and let the log file build. Due to the large amount of media I have the log grew to over 40 mg. and I figured you probably don't want he whole 40 meg, so I edited the log and copied out the section where the video file was inserted. Due to the size limitations on attachments I have attached half of the file here and will post another message with the second half.
regards
Grant.
1st half after adding file to library.txt
(288.45 KiB) Downloaded 632 times
gbdb
Post Mon Jan 16, 2012 3:32 am
Hi Petr,
As promised here is the second half of the log portion.
regards
Grant
2nd half after adding file to library.txt
(383.05 KiB) Downloaded 721 times
Post Mon Jan 16, 2012 5:12 pm
Right, this is the problem:
H264 Level value stored in the AVC header (4) is different than one based on ref_frames value (5 will be stored)
There seems to be a bug with profile detection based on ref frames so the file gets transcoded. That should still play though. Anyway, could you run this command and send me the resulting file (c:\temp\m2tsheader.h264)?
ffmpeg.exe -i "D:\Shared documents\My Videos\Home Video\6. Sep 11 - Nov 11\00334. EOY Concert 2011 - Running of the Bulls.m2ts" -vframes 1 -vcodec copy -f h264 -an c:\temp\m2tsheader.h264
You can change the output path if this one doesn't work.
gbdb
Post Mon Jan 16, 2012 9:10 pm
Hi Petr,
Here is the output from the run. I had the change the extension from h264 to txt to get it to attach as h264 threw an error message, so you will need to change it back.
Grant.
m2tsheader.txt
(156.14 KiB) Downloaded 579 times
Post Mon Jan 16, 2012 10:49 pm
Thanks Grant. it's helpful. One more thing. Could you install Intel tools, run AV Media Controller, browse Serviio to find this item and display properties. Then find the resolution of the video resource and post it here (should be 1440 x 1080)
gbdb
Post Tue Jan 17, 2012 11:53 am
Hi Petr,
The resolution was 1440x1080 as you suggested in AV Media Controller.
Grant
eliane1234
Post Thu Jan 19, 2012 3:32 pm
hello
i have samsung tv c series i was using old version serviio it worked fine now i use only 2 min and serviio stopped working on tv. please help
thanks
Users browsing this forum: Baidu [Spider], Google [Bot] and 36 guests
