Noob needs help regarding plugins
bibbys0
Post Sun Jan 15, 2012 1:45 pm
Hi I am very new to this I have been looking at the available plugins and running serviio from windows.I have seen the many usefull plugins but dont know where to put them.
It states to add them to the plugin folder but on searching i dont seem to have one I have checked in the serviio folder and nothing.
Any help would be greatly appreciated
Thanks in advance
steve
Post Sun Jan 15, 2012 1:48 pm
Re: Noob needs help regarding plugins
bibbys0 wrote:Hi I am very new to this I have been looking at the available plugins and running serviio from windows.I have seen the many usefull plugins but dont know where to put them.
Thanks in advance
steve
what version of serviio are u running?
bibbys0
Post Sun Jan 15, 2012 1:50 pm
Hi thanks for your quick response the version is 0.6.1
Post Sun Jan 15, 2012 2:15 pm
bibbys0
Post Sun Jan 15, 2012 2:55 pm
thanks for pointing me there but have read this and really dont understand it it one bit
Post Sun Jan 15, 2012 3:02 pm
Online resource plugins are simple programs written in Groovy language. Once copied to the Serviio's plugins directory, the plugin is registered and related resources can be indexed for Serviio to play. To register a new plugin with Serviio you have to copy the plugin file (.groovy) to Serviio's plugins directory. This directory is located under Serviio's installation directory.
NOTE: On a Mac you will have to store it inside Serviio.app. Right-click on Serviio(.app) icon -> Browse contents -> naviagate to Contents/Resources/Java/plugins
On windows it will most likely be under
C:\Program Files\Serviio\plugins\
or
C:\Program Files (x86)\Serviio\plugins\
bibbys0
Post Sun Jan 15, 2012 3:15 pm
Thank you so much i have now found the plugin folder for some reason its was hidden so after showing hidden folders it was there
Thanks again now i will have a play and see if i can get it to work
Return to Plugin development
