TV is set to fixed ip address, but serviio detects it twice
raist1976
Post Sun Jan 15, 2012 12:24 am
I'm facing a rather new problem, because I was using serviio for several months without a hitch.
It might be since I upgraded to serviio 0.6.1, althougth I'm not 100% sure.
The problem is that my samsung TV is first beeing detected on the serviio console with ip address 192.168.0.20 (fixed ip with dhcp lease on router).
The right profile is recognized (samsung C/D) and I can play a video.
But if I return to the file selection on the tv and try to play the same file, or another one, it gives an error 'file not supported'.
Then I check on the serviio console and I see that my 192.168.0.20 has disapeared and is now 192.168.27.14 ... which is impossible because my router is only set to assign addresses of the form 192.168.0.* ....
I don't know what is happening there !
Here's an example in the log when both IP are rendered at almost the same time :
012-01-15 00:52:19,463 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.20
2012-01-15 00:52:19,464 DEBUG [RendererDAOImpl] Updating Renderer (uuid = ae6a4542-7fe3-fcb5-3c14-40f5616ca5c2, ipAddress = 192.168.0.20)
2012-01-15 00:52:19,465 DEBUG [RendererManager] Adding renderer Renderer [uuid=ae6a4542-7fe3-fcb5-3c14-40f5616ca5c2, ipAddress=192.168.0.20, name=Samsung DTV DMR, profileId=7, manuallyAdded=false, forcedProfile=false] to list of active renderers
2012-01-15 00:52:19,476 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.27.14
2012-01-15 00:52:19,476 DEBUG [RendererDAOImpl] Updating Renderer (uuid = ae6a4542-7fe3-fcb5-3c14-40f5616ca5c2, ipAddress = 192.168.27.14)
2012-01-15 00:52:19,477 DEBUG [RendererManager] Adding renderer Renderer [uuid=ae6a4542-7fe3-fcb5-3c14-40f5616ca5c2, ipAddress=192.168.27.14, name=Samsung DTV DMR, profileId=7, manuallyAdded=false, forcedProfile=false] to list of active renderers
WildRushSykes
Post Sun Jan 15, 2012 12:27 am
Re: TV is set to fixed ip address, but serviio detects it tw
do u have windows media player sharing enabled?
Post Sun Jan 15, 2012 12:32 am
can you ping the new IP?
ping 192.168.27.14
If yes it means it exists. You could also use wireshark to sniff traffic and see if there are any packets incoming from that address. Also by any change doesn't the TV havewifi as well as wired network adaptors?
raist1976
Post Sun Jan 15, 2012 12:38 am
reinstalled serviio-0.5.2, problem fixed ...
have yet to try with 0.6.0.1
WildRushSykes
Post Sun Jan 15, 2012 12:39 am
It would of helped us out more if you stuck with the latest 0.6.1 version so we can iron out bugs :D
raist1976
Post Sun Jan 15, 2012 12:45 am
zip wrote:can you ping the new IP?
ping 192.168.27.14
strange thing is that I can ping 192.168.27.14 but not 192.168.0.20 . I already checked that strang behaviour yesterday but thought maybe the tv was not accepting pings...
Maybe it has something to do with PLC plugs ? do that act like stand alone routers maybe ? Because my TV is plugged on such plugs.
Before my tv was connected on wifi, now I plugged it with PLC plug, but I removed the wifi adaptater from the TV... no way it can still work :)
raist1976
Post Sun Jan 15, 2012 12:46 am
WildRushSykes wrote:It would of helped us out more if you stuck with the latest 0.6.1 version so we can iron out bugs :D
sure, but I do need to be able to watch a movie without getting my nerves on edge ;)
anyway I'll try to sort this out.
TV will reply to pings, yes
raist1976
Post Sun Jan 15, 2012 1:02 am
EDIT : can reproduce with 0.6.0.1. so it just might not be a problem with serviio. will try to use 0.5.2 a little longer to make sure.
can't reproduce either with 0.6.0.1, but did reproduce it with 0.6.1 so there's something there...
with 0.6.0.1 I saw a strange address at some point after clicking refresh (was yet different), but it changed back to 192.168.0.20 with yet another click on refresh.
will do further testing and some sniffing tomorrow
Post Sun Jan 15, 2012 11:38 am
raist1976 wrote:strange thing is that I can ping 192.168.27.14 but not 192.168.0.20 . I already checked that strang behaviour yesterday but thought maybe the tv was not accepting pings...
192.168.27.14 and 192.168.0.20 are different IP subnets. They cannot talk to each other unless you have setup a bridge between the two IP subnets.
Post Sun Jan 15, 2012 11:47 am
ok so network issue can i have some info oon your network please.
from cmd prompt please run Ipconfig and paste out put here.
Post Sun Jan 15, 2012 12:30 pm
what about detailed log? are there any other requests from the dodgy IP address? incoming requests etc.
raist1976
Post Sun Jan 15, 2012 3:23 pm
WildRushSykes wrote:do u have windows media player sharing enabled?
I think yes because my TV sees my computer too. Should I try to disable that ?
raist1976
Post Sun Jan 15, 2012 3:27 pm
and now I'm seeing another IP address in serviio for the TV : 169.254.65.23 ... !
My computer is 192.168.0.10, my router 192.168.0.254 ... automatic DHCP is from 192.168.0.1 to 192.168.0.50 and the TV had a permanent lease, based on MAC address, on 192.168.0.20.
I saw somewhere, but don't know if true, that there can be a conflict between the DHCP range and the permanent lease that has an address in the DHCP range ? (but I don't believe the router would have problem with that...)
Post Sun Jan 15, 2012 3:29 pm
is your internet connection provided over pppoe protocol?
raist1976
Post Sun Jan 15, 2012 3:31 pm
IPoA
raist1976
Post Sun Jan 15, 2012 3:32 pm
Cerberus wrote:ok so network issue can i have some info oon your network please.
Windows IP Configuration
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Ethernet adapter Freebox LAN:
Link-local IPv6 Address . . . . . : fe80::a075:6f5f:5b61:8998%10
IPv4 Address. . . . . . . . . . . : 192.168.0.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.254
Tunnel adapter isatap.{3DA1EB0D-D45A-41DE-A0CC-485C9FE20A21}:
Tunnel adapter Teredo Tunneling Pseudo-Interface:
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:45d:3ab6:ad1a:7b49
Link-local IPv6 Address . . . . . : fe80::45d:3ab6:ad1a:7b49%21
Default Gateway . . . . . . . . . : ::
Tunnel adapter isatap.{DC549D36-2FC0-4F29-970F-A14118B59B17}:
... nothing unusual. As stated in previous post, my computer is 192.168.0.10, my router 192.168.0.254 ... automatic DHCP is from 192.168.0.1 to 192.168.0.50 and the TV had a permanent lease, based on MAC address, on 192.168.0.20.
Post Sun Jan 15, 2012 3:33 pm
ipoa???
edit: AHH ok IP over ATM that coudl be ur issue try disbaling your connection then try serviio, you should no longer see ironious IP.
Users browsing this forum: Majestic-12 [Bot] and 7 guests
