Optional Serviio Service Startup
sipla
Post Thu Sep 23, 2010 7:27 am
It'd be nice if I had an option to manually start the service with the Serviio Console.
At the moment (version 0.4.2) the service loads automatically by default. If I set the service Startup Type to manual with Windows Services, it doesn't load at start up (which is what I want) but I also can't start the service with the Serviio Console since it exits if it doesn't detect the service running.
So, what I'm requesting is
- for the console to start even if the service isn't running.
- a check box on the console for whether the service starts automatically
- a check box on the console for whether the console starts automatically
- possibly yet another check box to indicate whether the service starts when you start the console
- during installation to be asked whether I want an icon for the console on the desktop
That's all! :roll:
Also, I was wondering why the Force Refresh button gets disabled at all. It only gets enabled when I press the Save (configuration I presume) button.
Thanks!
Post Thu Sep 23, 2010 8:24 am
Re: Optional Serviio Service Startup
brotherjohn
Post Sat Jan 22, 2011 9:41 am
I would appreciate an option in the Serviio console like "Don't start Serviio at startup". Is this possible?
Post Sat Jan 22, 2011 11:24 am
Not in the console, it's Windows only feature. It could be in the installer.. ?
brotherjohn
Post Mon Jan 24, 2011 10:38 am
That's OK. Another little thing for the new version:
The "Start Serviio service" and "Stop Serviio service" link in windows should set to "Run as administrator", otherwise it won't work.
Return to Feature requests
