Serviio [Windows] not finding any Renderers
• Page 1 of 1
I have just installed Serviio on my Windows notebook but it doesn't seem to find any renderers. I want to connect it to my Samsung D8000 TV. I have also installed it on my MacBook Pro and it worked just fine. TV, Windows PC, MacBook are all connected to the same network.
Re: Serviio [Windows] not finding any Renderers
My device doesn't see Serviio
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
Cerberus wrote:This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one.
I have already binded the correct one (192.168.1.4).
Cerberus wrote:Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
I have already opened both of them.
And I even tried adding the device manually by clicking the Add button in the Renderers window and typing 192.168.1.6 and UE46D8000, because the TV got found under that name and IP on the MacBook Pro, but it didn't work either
dzebna wrote:Cerberus wrote:This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one.
I have already binded the correct one (192.168.1.4).Cerberus wrote:Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
And I even tried adding the device manually by clicking the Add button in the Renderers window and typing 192.168.1.6 and UE46D8000, because the TV got found under that name and IP on the MacBook Pro, but it didn't work either.
you did restart after adding bound ip yer ?
I solved it by restarting my router and turning off the antivirus firewall. Thanks for replies
If you have it working correctly can you mark this thread [Solved]
• Page 1 of 1
