Device doesn't detect Serviio anymore
Xor111
Post Sun Jan 15, 2012 6:00 pm
It worked fine yesterday, DHCP address of server changer and now it's down, setting forced IP to the new one given by dhcp doesn't work, nor getting a reserved IP (same as I had yesterday).
I can make every other Media Server I can find right now work (PS3Media, AllShare, the windows one, ...).
Serviio does detect the device, just not the other way around.
Steps I took:
Ensured Serviio uses right adapter (should be ok given the description given in log)
Ensured I put the current IP of my computer in the console. Even tried adding -Dserviio.boundAddr=192.168.1.8 to the service params.
Log attached.
Any ideas?
(8.76 KiB) Downloaded 632 times
eclp
Post Sun Jan 15, 2012 6:15 pm
Re: Device doesn't detect Serviio anymore
Xor111 wrote: Even tried adding -Dserviio.boundAddr=192.168.1.8 to the service params.
next step: reboot the pc!
Xor111
Post Sun Jan 15, 2012 6:30 pm
Already tried that :)
Also Stop/start the service manually.
Tried with a Automatic(Delayed) also at startup
eclp
Post Sun Jan 15, 2012 6:33 pm
command prompt: ipconfig /all
Post Sun Jan 15, 2012 8:26 pm
did you check and make sure the ports are still open?
Xor111
Post Tue Jan 17, 2012 6:48 pm
moltra wrote:did you check and make sure the ports are still open?
they are :?
ipconfig in french but you can see the first description is the name of the one Serviio should use, and he uses it...:
Carte Ethernet Connexion au réseau local :
Suffixe DNS propre à la connexion. . . : lan
Description. . . . . . . . . . . . . . : Realtek RTL8168B/8111B Family PCI-E
Gigabit Ethernet NIC (NDIS 6.20)
Adresse physique . . . . . . . . . . . : 00-15-CG-CA-5C-B3
DHCP activé. . . . . . . . . . . . . . : Oui
Configuration automatique activée. . . : Oui
Adresse IPv6 de liaison locale. . . . .: fe80::a4a1:8709:f060:c3be%10(préféré
Adresse IPv4. . . . . . . . . . . . . .: 192.168.1.8(préféré)
Masque de sous-réseau. . . . . . . . . : 255.255.255.0
Bail obtenu. . . . . . . . . . . . . . : mardi 17 janvier 2012 19:24:24
Bail expirant. . . . . . . . . . . . . : mercredi 18 janvier 2012 19:24:21
Passerelle par défaut. . . . . . . . . : 192.168.1.254
Serveur DHCP . . . . . . . . . . . . . : 192.168.1.254
IAID DHCPv6 . . . . . . . . . . . : 184555995
DUID de client DHCPv6. . . . . . . . : 00-01-00-01-13-17-E8-E3-00-15-CG-CA-5C
-AE
Serveurs DNS. . . . . . . . . . . . . : 194.158.122.10
194.158.122.15
NetBIOS sur Tcpip. . . . . . . . . . . : Activé
Carte Ethernet Hamachi :
Description. . . . . . . . . . . . . . : Hamachi Network Interface
Adresse physique . . . . . . . . . . . : 7A-79-05-6B-AE-CF
Adresse IPv4. . . . . . . . . . . . . .: 5.107.174.207(préféré)
Masque de sous-réseau. . . . . . . . . : 255.0.0.0
Bail obtenu. . . . . . . . . . . . . . : mardi 17 janvier 2012 19:24:32
Bail expirant. . . . . . . . . . . . . : mercredi 16 janvier 2013 19:24:32
Passerelle par défaut. . . . . . . . . : 5.0.0.1
Serveur DHCP . . . . . . . . . . . . . : 5.0.0.1
IAID DHCPv6 . . . . . . . . . . . : 393902516
DUID de client DHCPv6. . . . . . . . : 00-01-00-01-13-17-E8-E3-00-19-DB-CB-6F
-AE
Serveurs DNS. . . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Xor111
Post Tue Jan 17, 2012 7:02 pm
Oddly enough, an uninstall/install has just made it work again. No idea what happened!
Edit : Installation Folder moved from Program Files (x86) - installed with 0.6 - to Program Files (used for 64b softs)- installed with 0.6.1. Does it mean 0.6.1 nows is 64b?
Post Tue Jan 17, 2012 9:13 pm
Xor111 wrote:Oddly enough, an uninstall/install has just made it work again. No idea what happened!
serviio has always been 64bit but windows decides its not so put it in wrong folder this was corrected with 0.6.1 we kicked windows in the bum and told it to put it in right place.
