Disable local computer as a renderer
On the Status tab of my serviio 0.6.1, under Renderer, I see IP address of my TV and that of the computer itself. When that happens, it takes serviio for forever to appear on the list of DLNA servers on my TV and sometimes it doesn’t appear at all. I would like to disable that so only my TV appears as a Renderer on the serviio console. How can I do that?
I’m running serviio on a Windows 7 laptop and my TV is Panasonic TCP50S30.
By the way, is there a good profile for my TV? Almost all transcoded movies are stretched to full screen and I’d like to watch them in their intended format if possible.
Thank you for all your help,
