Re: Streaming desktop
However, I played a DVD on the PC and it just showed a black screen on the TV.
How can I use this to get a DVD to stream from the PC to the TV?
It might also be caused by the fullscreen mode not properly captured by the driver.
zip wrote:Try to play the DVD in VLC itself
WildRushSykes wrote:Is your networked wired or wireless? Try wired and report back.
jhb50 wrote:I'm a little confused, you never said what you were using to play the DVD when you got the black screen, nor did you respond back with the results of the window option. Now you have asked if playing it with a different player would make a difference, but it obviously did because you got a picture with WMP.
It would be nice to know why you got a black screen so we could help others with the same problem. Zip's reconmendation to use VLC for playback is the best because using the Advanced Playback option you can play the DVD and stream the output. If you select the same options as used for streaming the desktop in the wiki it should work fine.
Susan-334 wrote:I think you must have missed my answers.
An update... using one instance of VLC, you can actually stream from the DVD
I can't see the DVD being played in the VLC window
jhb50 wrote:
Still be nice to see your black screen answers.
jhb50 wrote:Ok thanks, I misunderstood your response. Is it working now with one vlc? You might post a wiki entry on How to Stream a DVD!
jhb50 wrote:I've drafted a wiki for playing and streaming a DVD. Please test it.
http://wiki.serviio.org/doku.php?id=stream_dvd
Users browsing this forum: Baidu [Spider] and 12 guests
