FF/rewind
snovik
Post Sun Jan 15, 2012 10:01 pm
FF/rewind
As I am a complete newbie and this is the only serious forum I found :) I will try to ask here.
I having problems with FF/rewind when I stream from a hard disk a) connected to the router wired to TV via cable TV box or b) serviio. So FF and rewind do not work but pause/resume do work.
Is it a solvable problem for either a) or b)?
I tried to connect the hard disk to the TV directly and played the same files. FF/rewind work perfectly in this case so it is not the issue of file formats
WildRushSykes
Post Sun Jan 15, 2012 10:02 pm
Re: FF/rewind
does your TV support ff/rw on streamed media?
Last edited by WildRushSykes on Sun Jan 15, 2012 10:03 pm, edited 1 time in total.
snovik
Post Sun Jan 15, 2012 10:03 pm
Re: FF/rewind
I added later to the post
"I tried to connect the hard disk to the TV directly and played the same files. FF/rewind work perfectly in this case so it is not the issue of file formats"
And my TV is UE46D5000
snovik
Post Sun Jan 15, 2012 10:18 pm
Re: FF/rewind
My bad. At least on serviio fast forward etc. work. I was pressing the wrong buttons on the remote control. which was not obvious since to rewind one has to press navigation buttons rather than control buttons.
