[SOLVED] "File is Corrupt"
mmmmmmmmmmh
Post Mon Jan 02, 2012 10:18 pm
Hi - I replied to an old post with this issue, but no one responded, so I thought I'd give it another shot.
I have a BDV-S570. Some videos play great with Serviio, but for others it refuses to play them and says "File is corrupt or not supported." It seems like the files that don't play are "DivX 5" per MediaInfo, while those that do play are "XviD" - but I didn't check all of the files.
Any help would be appreciated. File info pasted below.
ffmpeg:
Input #0, avi, from 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX':
encoder : VirtualDubMod 1.5.10.1 (build 2366/release)
Duration: 02:24:33.75, start: 0.000000, bitrate: 775 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 580x234 [PAR 1:1 DAR 290:117], 23.98 tbr
, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 96 kb/s
MediaInfo:
Format : AVI
File size : 802 MiB
Duration : 2h 24mn
Overall bit rate : 776 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Writing library : VirtualDubMod build 2366/release
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 2h 24mn
Bit rate : 671 Kbps
Width : 580 pixels
Height : 234 pixels
Display aspect ratio : 2.479
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.206
Stream size : 693 MiB (86%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 2h 24mn
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 99.3 MiB (12%)
Alignment : Aligned on interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 504 ms
mbrydon
Post Mon Jan 02, 2012 10:53 pm
Re: "File is Corrupt"
Don't know if it is the same issue but it is likely as I have a BDP-S480 and can't play divx via dlna, whether it be serviio or Windows 7. The same files play fine locally on disk or USB.
When I did a bit of digging there are loads of posts on the likes of avsforum and on the sony forums that say it was due to a licensing issue that divx over dlna was unsupported, but apparently sony were sorting it out, and it would be resolved with a future firmware update. I'll not be holding my breath on that one.
Its not a great issue for me though as I convert most divx files to xvid which works fine.
So basically I think that your issue is likely with your player rather than serviio, hope that is of some help.
movielover
Post Tue Jan 03, 2012 11:28 am
I have the s480, any divx files I have problems with then simply change the codec to xvid in both fields using avi fourcc changer. A very simple fast solution.
http://www.afterdawn.com/software/audio ... hanger.cfm
mmmmmmmmmmh
Post Tue Jan 03, 2012 11:36 pm
awesome! that fixed it.
Post Wed Jan 04, 2012 9:45 am
Very interesting !!!
This information should be add to the FAQ Sony BDP.
Tools added : viewtopic.php?f=17&t=4599
warobbo
Post Fri Jan 13, 2012 12:03 pm
Re: [SOLVED] "File is Corrupt"
Hi, does anyone know of a fix for Macs? thanks
Post Fri Jan 13, 2012 12:47 pm
warobbo wrote:Hi, does anyone know of a fix for Macs? thanks
http://www.macupdate.com/app/mac/10603/ ... cchangerx/
warobbo
Post Sun Jan 15, 2012 12:45 pm
Many thanks most appreciated
Post Mon Jan 16, 2012 8:58 am
warobbo wrote:Many thanks most appreciated
Does it work on Mac?
Does it fixed the avi file?
