[OLD] Android Console
Post Sun Jan 15, 2012 6:22 pm
Re: Android Console
Xmantium wrote:I like this
or
Settings tab:
Library <---------- Shared Folder Options, Online Sources Options, Presentation Extras
Transcoding
Metadata
Presentation <-------- Browsing categories
Won't that be more confusing? I'm all for splitting things up to fit on a mobile device, but don't really want to add things from multiple console tabs together.
@Zip would 'Serviioid' be too similar?
Xmantium
Post Sun Jan 15, 2012 6:24 pm
Re: Android Console
I dont it will, Presentation Extras is something is hardly touched, in my experience ive never changed it
Its still related to Library, as its something that changes how the Library is viewed
I like Serviioid :) Its serviio with "id" at the end
what about Servdroiid, you get both Serv and droid together plus you get the iconic "ii" of serviio
Post Sun Jan 15, 2012 6:26 pm
Re: Android Console
will wrote:@Zip would 'Serviioid' be too similar?
Sounds ok to me.
Post Sun Jan 15, 2012 6:34 pm
Re: Android Console
Xmantium wrote:I dont it will, Presentation Extras is something is hardly touched, in my experience ive never changed it
I like Serviioid :)
I'll have a think about it. The ideal solution would be to have them at the bottom of the list. I'll have another google for it, but I don't think its going to be possible without some horrifically hacky code.
Servdroiid
How would you pronounce that/spell it phonetically?
Xmantium
Post Sun Jan 15, 2012 6:39 pm
Re: Android Console
Just like Serv - Droid :D
or we can have ServiDroiid
Post Sun Jan 15, 2012 7:08 pm
Re: Android Console
Well i'm leaning towards Serviioid, partly because it should come to the top of the android market if you seach for just serviio
What are everyones top 3 names?
Post Sun Jan 15, 2012 8:28 pm
Re: Android Console
will wrote:Well i'm leaning towards Serviioid, partly because it should come to the top of the android market if you seach for just serviio
I like Serviioid also.
Post Sun Jan 15, 2012 8:48 pm
Re: Android Console
serviiod cant even spell it let alone say it lolol
tests on beta 12
Delete function works
profile change works
library status work perfectly now ( just how id expect )
layout much better ( still not perfect but can live with it )
Post Sun Jan 15, 2012 9:02 pm
Re: Android Console
What bits don't you like about the layout?
The fact that the tabs aren't the same as the normal console?
Post Sun Jan 15, 2012 9:03 pm
Re: Android Console
will wrote:What bits don't you like about the layout?
i still dont like separate setting tab but i will live with it
Post Mon Jan 16, 2012 11:40 am
Re: Android Console
OK. Can you think of a compromise? I don't want to have too many tabs as it takes quite a few actions to move around, especially in portait mode on a phone. While it would be possible to swap tabs in and out depending on the orientation/screen size, I feel that that would make it inconsitent and confusing.
I currently feel that it should just be [Status|Devices|Shared folders|Online Sources|Adavanced]
Where advanced will be a list of the settings (for now - may include extra things like feedback or any future tabs zip adds) that the user doesn't use very often. I'll have a title and a short description under the title for each item. This should help differentiate between the two presentation settings.
What are other peoples thoughts on this?
Are there any other requests for features/changes/fixes? I want to get the last beta done at some point soon. I'll then wait a good few weeks while people use it to make sure there aren't any crashes, and then do the first release.
Post Mon Jan 16, 2012 11:47 am
Re: Android Console
[Status|Devices|Shared folders|Online Sources|Presentation|Adavanced] <-- perfect advanced sound alot better than setting so makes it less confusing :)
nope i cant think of anything else i would add. well console version on front page would be a wish of mine.
Post Mon Jan 16, 2012 11:50 am
Re: Android Console
But how often do people actually need to change the main Presentation settings? Once it is set up how they like it, the only reason they would re-visit it, is if zip added a new entry.
moleculezz
Post Mon Jan 16, 2012 1:14 pm
Re: Android Console
I kinda like servdroid, but then again you are right about getting better results in the Market with serviioid
IMO.. the only tabs that are needed are the following:
[Status|Devices|Shared folders|Online Sources]
Then you put an extra button "Advanced" in Options for the rest.
DMS: QNAP TS-459 Pro+
DMR: Samsung LE40B650 | Sony PS3
Post Mon Jan 16, 2012 1:40 pm
Re: Android Console
will wrote:But how often do people actually need to change the main Presentation settings? Once it is set up how they like it, the only reason they would re-visit it, is if zip added a new entry.
not often but don't just think about ppl like us think about new users.
moleculezz
Post Mon Jan 16, 2012 2:13 pm
Re: Android Console
I think new users will probably have the basic setup (Server/Console) and then afterwards see if there is an app for that in the market.
Post Mon Jan 16, 2012 2:15 pm
Re: Android Console
trust me i have answer hundred of how do i manage my headlless server questions.
Post Mon Jan 16, 2012 2:25 pm
Re: Android Console
OK, I will keep presentation under the advacned tab for now. It is an advanced option that is not needed to get Serviio up and running. If I get feedback from more users then I will consider moving it.
Are these the top few names then?
Serviioid
Servdroiid
ServiDroiid
Servoid
I think servdroiid has too many constanants in a row.
Post Mon Jan 16, 2012 2:57 pm
Re: Android Console
*shurgs*
moleculezz
Post Mon Jan 16, 2012 3:01 pm
Re: Android Console
Cerberus wrote:trust me i have answer hundred of how do i manage my headlless server questions.
Can't argue with that.. you're the guy with 3000+ posts :shock: :D
Users browsing this forum: No registered users and 109 guests
