Web UI in Ajax (Mobile & desktop edition)
kairoh
Post Fri Dec 23, 2011 9:46 pm
Re: Web UI in Restful Ajax
Next release is almost there containing a lot of new features/bugfixes, i'm just waiting Zip to release the final 0.6.1. ;)
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
qoolbox
Post Sat Dec 24, 2011 11:00 am
Hurry to test this and adapt this on Thecus NAS...
Thanks Kairoh for your work...
Third Party Thecus NAS Develloper
http://forum.thecus.com
http://www.tsuga.fr
Post Sat Dec 24, 2011 11:48 am
kairoh wrote:Next release is almost there containing a lot of new features/bugfixes, i'm just waiting Zip to release the final 0.6.1. ;)
I've added one more field on transcoding tab (play in highest quality) that is not described in the published 0.6.1 beta API spec.
kairoh
Post Sat Dec 24, 2011 1:28 pm
I've already noticed that ;)
patters
Post Sat Dec 24, 2011 6:23 pm
zip wrote:I've added one more field on transcoding tab (play in highest quality) that is not described in the published 0.6.1 beta API spec.
What effect does that have on FFmpeg?
Post Sat Dec 24, 2011 6:59 pm
either uses -sameq (best quality) or -qscale 3 (faster but still good quality).
kairoh
Post Wed Dec 28, 2011 12:19 pm
As promised new version (0.6.1-a) is here !
It is compatible with Serviio 0.6.1 (beta4, RC and hopefully final version!).
0.6.1-a
- added new 0.6.1 features (live stream, edit online repositories, force online refresh).
- added sub tabs navigation.
- updated auto disabling forms (like the swing console does).
- fixed UTF-8 support (when using oriental charset).
- added alert when "functional error" occurs in REST response.
- added html5 new attributes for some input (url, number).
- updated i18n properties file.
- updated starting jvm parameters.
- updated libs (jquery-1.7.1, jquery.tmpl-1.0.0.pre).
- improved general javascript performance.
- [windows] fixed bat when using space in classpath.
Post Wed Dec 28, 2011 12:46 pm
great stuff. I'll probably add the links to the official download page later on. Do you have some snapshots?
qoolbox
Post Wed Dec 28, 2011 5:54 pm
Thank you Kairoh...
Great Job i update Asap the Thecus NAS Module...
:D
http://www.tsuga.fr
kairoh
Post Thu Dec 29, 2011 9:57 am
See 1st post for some snapshots.
patters
Post Fri Dec 30, 2011 1:01 am
Looking good. I think I may have to ditch the PHP Web UI and go for this one for the Synology Package. I'll have a play with the CSS...
Xmantium
Post Fri Dec 30, 2011 2:08 am
Looks very good!
i used this bout 6 months ago on my QNAP NAS, noticed few bugs and reverted back to php web ui, hopefully the problems i encountered before have been fixed
qoolbox
Post Sun Jan 01, 2012 2:30 pm
Thanks Kairoh,
Thecus Module Updated
http://forum.thecus.com/viewtopic.php?f=36&t=2835
I also fixed the UTF-8 Encoding for the webui, it works like charm (just tricked the Thecus OS for that) :D
just got a problem, on first install and first launch the WEBUi indicate error in RED, such like Serviio core engine was not running background but it is, i need to refresh the browser to remove the error and all is ok.... :?
Best Regards,
Stéphane
http://www.tsuga.fr
qoolbox
Post Tue Jan 17, 2012 12:04 pm
Just update the core engine serviio into 0.6.1 on Thecus and use Wrapper mode to launch... and i have error following on launching the script
root@127.0.0.1:/raid/data/module/serviio/bin/bin# ./serviio-wrapper.sh
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/serviio/restui/ServiioWrapper : Unsupported major.minor version 51.0
        at java.lang.ClassLoader.defineClass1(Native Method)
        at java.lang.ClassLoader.defineClassCond(Unknown Source)
        at java.lang.ClassLoader.defineClass(Unknown Source)
        at java.security.SecureClassLoader.defineClass(Unknown Source)
        at java.net.URLClassLoader.defineClass(Unknown Source)
        at java.net.URLClassLoader.access$000(Unknown Source)
        at java.net.URLClassLoader$1.run(Unknown Source)
        at java.net.URLClassLoader.findClass(Unknown Source)
        at java.lang.ClassLoader.loadClass(Unknown Source)
        at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
Could not find the main class: org.serviio.restui.ServiioWrapper.  Program will exit.
any idea ???
the script i use is following
PATH=/raid/data/module/serviio/sys/bin/:$PATH
export PATH
SERVIIO_HOME=/raid/data/module/serviio/bin
JAVA_HOME=/raid/data/module/OracleJRE6/system/jre
JAVA="$JAVA_HOME/bin/java"
NOHUP=/raid/data/module/serviio/sys/bin/nohup
# Setup the classpath
SERVIIO_CLASSPATH="$SERVIIO_HOME/config"
LIB=${SERVIIO_HOME}/plugins
for jar in `ls -1 ${LIB}/*.jar`; do SERVIIO_CLASSPATH="${SERVIIO_CLASSPATH}:${jar}"; done
LIB=${SERVIIO_HOME}/lib
# Execute the JVM in the foreground
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dserviio.home=$SERVIIO_HOME -Dderby.system.home=$SERVIIO_HOME/library"
JVM_OPTS="-Xms20M -Xmx384M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Dfile.encoding=UTF-8"
# $NOHUP </dev/null >/dev/null 2>&1 &
"$JAVA" $JVM_OPTS $JAVA_OPTS -classpath "$SERVIIO_CLASSPATH" org.serviio.restui.ServiioWrapper "$@"
Help please... i am lost...
http://www.tsuga.fr
patters
Post Tue Jan 17, 2012 7:28 pm
I'm finally finding some time to work on the CSS ready to include this in the Synology 0.6.1 package but I have the same problem as the last post. I can run it manually, but the wrapper isn't working. I'm on Linux.
Also I have noticed that I can't change language either. Is this another slash/blackslash issue that is only affecting Linux systems perhaps?
kairoh
Post Tue Jan 17, 2012 10:33 pm
Here is a small version (0.6.2-a) available here !
It is compatible with Serviio 0.6.2 (and every 0.6.1).
0.6.2-a
- fixed wrapper (recompile to java6 instead of java7).
kairoh
Post Tue Jan 17, 2012 10:45 pm
patters wrote:I'm finally finding some time to work on the CSS ready to include this in the Synology 0.6.1 package but I have the same problem as the last post. I can run it manually, but the wrapper isn't working. I'm on Linux.
Wrapper was compiled on java7, so it only worked on java7... sorry :roll:
I've actually working on 2 problems : one about language changing, and another about new renderer addition.
patters
Post Wed Jan 18, 2012 11:42 am
Thanks - your download page isn't updated. I was able to guess the download URL though :)
patters
Post Wed Jan 18, 2012 11:54 am
Hmm. The wrapper still doesn't work. This is on Java 6:
DS111> /volume1/@appstore/Serviio/bin/serviio-wrapper.sh
        at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
        at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
        at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
        at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
        at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
        at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
On Java 7 nothing happens at all (this is launched from a shell running as user 'serviio'):
DS111> ps
  PID USER       VSZ STAT COMMAND
    1 root      3020 S    init
    2 root         0 SW   [kthreadd]
    3 root         0 SW   [ksoftirqd/0]
    4 root         0 SW   [events/0]
    5 root         0 SW   [khelper]
    8 root         0 SW   [async/mgr]
   87 root         0 SW   [sync_supers]
   89 root         0 SW   [bdi-default]
   90 root         0 SW   [kblockd/0]
   96 root         0 SW   [ata/0]
   97 root         0 SW   [ata_aux]
  112 root         0 SW   [rpciod/0]
  120 root         0 SW   [kswapd0]
  121 root         0 SW   [nfsiod]
  274 root         0 SW   [scsi_eh_0]
  276 root         0 SW   [scsi_eh_1]
  282 root         0 SW   [mtdblockd]
  618 root         0 SW   [jbd2/sda1-8]
  619 root         0 SW   [ext4-dio-unwrit]
 1046 root      7168 S    /usr/syno/apache/bin/httpd -f /usr/syno/apache/conf/httpd.conf-sys
 1147 root      7168 S    /usr/syno/apache/bin/httpd -f /usr/syno/apache/conf/httpd.conf-sys
 1660 serviio   5484 S    -sh
 1688 root         0 SW   [kstriped]
 1733 root      7168 S    /usr/syno/apache/bin/httpd -f /usr/syno/apache/conf/httpd.conf-sys
 1854 root         0 SW   [khubd]
 1902 root         0 SW   [ksnapd]
 1917 root      7160 S    /usr/syno/apache/bin/httpd -f /usr/syno/apache/conf/httpd.conf-sys
 1952 root         0 SW   [crypto/0]
 2072 serviio   5484 R    ps
 2104 root         0 SW   [crypto]
 2105 root         0 SW   [crypto_ret]
 2191 root         0 SW   [ecryptfs-kthrea]
 2692 root      3020 S    /sbin/syslogd -S
 2697 root      3020 S    /sbin/klogd
 2782 root      8172 S <  /usr/syno/bin/findhostd
 2817 root         0 SW   [jbd2/sda3-8]
 2818 root         0 SW   [ext4-dio-unwrit]
 2920 root     12268 S    sshd: root@pts/0
 2988 root      5484 S    -ash
 3433 admin    33756 S    /usr/syno/pgsql/bin/postgres -D /var/services/pgsql --config_file=/usr/syno/pgsql/etc/postgresql.conf
 3455 admin    33884 S    postgres: writer process
 3456 admin    33756 S    postgres: wal writer process
 3619 root      8716 S    /usr/syno/sbin/hotplugd
 3641 root      5480 S    /usr/sbin/inetd
 3648 root      5480 S    /usr/sbin/crond
 4228 root     12148 S    /usr/syno/bin/scemd
 4484 root         0 SW<  [kslowd000]
 4628 root         0 SW<  [kslowd001]
 5124 root         0 SW   [usbhid_resumer]
 5405 root      3024 S    /sbin/getty 115200 console
 5609 root      3020 S    /bin/sh /usr/syno/mysql/bin/mysqld_safe --datadir=/volume1/@database/mysql --pid-file=/tmp/mysqld.pid
 5763 admin     109m S    /usr/syno/mysql/libexec/mysqld --basedir=/usr/syno/mysql --datadir=/volume1/@database/mysql --user=adm
 6530 root      7880 S    /usr/syno/sbin/cupsd -C /usr/local/cups/cupsd.conf
 6736 root     12660 S    /usr/syno/sbin/fileindexd
 6833 root     16996 S    /usr/syno/sbin/nmbd -D
 6887 root     21132 S    /usr/syno/sbin/smbd -D
 6889 root     21132 S    /usr/syno/sbin/smbd -D
 6908 root      7124 S    /usr/syno/sbin/cnid_metad -l log_error
 6910 root     13800 S    /usr/syno/sbin/afpd -g guest -c 256 -n DS111 AFPServer -l default log_error
 7030 root      4116 S    /usr/syno/sbin/sshd
 7033 root      6920 S    /usr/syno/apache/bin/httpd -f /usr/syno/apache/conf/httpd.conf-sys
 7152 root      2408 S    avahi-daemon: running [DS111.local]
 7436 nobody   59840 S    /usr/syno/apache/bin/httpd -DHAVE_PHP
 8174 root     27020 S N  /usr/syno/sbin/synoindexd
 8179 root     25980 S N  /usr/syno/bin/synomkthumbd
 8186 root     25980 S N  /usr/syno/sbin/synomkflvd
 8251 admin    34720 S    postgres: admin mediaserver [local] idle
 8672 nobody   59816 S    /usr/syno/apache/bin/httpd -DHAVE_PHP
32122 root      7168 S    /usr/syno/apache/bin/httpd -f /usr/syno/apache/conf/httpd.conf-sys
32125 root         0 SW   [flush-8:0]
32435 root     59068 S    /usr/syno/apache/bin/httpd -DHAVE_PHP
32442 nobody   59788 S    /usr/syno/apache/bin/httpd -DHAVE_PHP
32443 nobody   72564 S    /usr/syno/apache/bin/httpd -DHAVE_PHP
32444 nobody   59652 S    /usr/syno/apache/bin/httpd -DHAVE_PHP
DS111>
kairoh
Post Wed Jan 18, 2012 4:25 pm
patters wrote:Thanks - your download page isn't updated.
You were absolutely right! And the download itself wasn't correct either, just renamed... :?
Now all urls and downloads are fixed
Users browsing this forum: No registered users and 149 guests
