[OLD] Android Console
Post Wed Jan 18, 2012 4:03 pm
Re: Android Console
yer i pulled it from there, but u ask someone to test the update thing so i did while i could :)
Post Thu Jan 19, 2012 6:33 pm
Re: Android Console
Not sure yet If I will go for Serviioid or ServiiDroid yet, although I'm leaning towards ServiiDroid. Anwway, thoughts on the logo text. Keep it all the same size or do something like this?
Post Thu Jan 19, 2012 7:19 pm
Re: Android Console
big S and D and rest smaller then we can refer to it as SD :P when we being lazy
Xmantium
Post Thu Jan 19, 2012 7:24 pm
Re: Android Console
YAY!! to ServiiDroid!!
How about
Post Thu Jan 19, 2012 7:47 pm
Re: Android Console
Well that was the other option, all upper or a mix. I'll have a play with it in the app and see what looks best.
@zip Just a final check before I refactor and rename everything - your happy with 'ServiiDroid' as a name?
Post Thu Jan 19, 2012 7:58 pm
Re: Android Console
that's ok with me.
Xmantium
Post Thu Jan 19, 2012 8:00 pm
Re: Android Console
zip wrote:that's ok with me.
Yayyy!!! :D
NX3
Post Sun Jan 22, 2012 9:26 pm
Re: Android Console
Just download and installed on HTC Legend, excellent app, really useful for my setup.
Post Sun Jan 22, 2012 9:54 pm
Re: Re: Android Console
NX3 wrote:Just download and installed on HTC Legend, excellent app, really useful for my setup.
Thanks :smile:
moleculezz
Post Sun Jan 22, 2012 10:35 pm
Re: Android Console
Came across this today and thought you'd be interested.
http://www.androiddesign.info/
DMS: QNAP TS-459 Pro+
DMR: Samsung LE40B650 | Sony PS3
Post Tue Jan 24, 2012 11:59 am
Re: Android Console
@Cerberus
Not sure why the app just crashed for you, it apeared to get half way through the JSON parsing and then fail to read the rest, however I've restructured the part that it crashed in to fix another problem so that shouldn't happen in the next release.
Was the server just starting/stopping / was there a connection problem?
Post Tue Jan 24, 2012 2:54 pm
Re: Android Console
will wrote:@Cerberus
server had failed completely wasnt even running, i dont think it was a console issue is was a bad upgrade issue on my part :)
Post Tue Jan 24, 2012 4:50 pm
Re: Android Console
Well I still don't want the app crashing even if the server is doing something odd. Anyway, should be fixed in the next version.
Post Tue Jan 24, 2012 6:20 pm
Re: Android Console
@All users running Android 2.1/2.2
I've worked out why you can't save information such as ignoring server versions. Basically I was using a method that does the save in the background, however it wasn't actually added until 2.3 and hense the crash and me not knowing what was wrong. This is fixed in the next release.
Post Tue Jan 24, 2012 6:45 pm
Re: Android Console
android 2.3.5 - on HTC phone working perfectly with android console :)
Post Tue Jan 24, 2012 7:09 pm
Re: Android Console
I'm going to have a go at setting something up for translating the app. If you are interested in helping go to http://www.getlocalization.com/serviidroid/ sign up and start translating :) If its crap let me know and I'll try and find something else, if it seams easy to use then also let me know.
Do not translate the strings about_text or copyright_short
Do not translate the words 'Serviio', 'ServiiDroid', or any of the following holder words SOURCE PORT ADDRESS ITEM INDEX ILLEGAL_CHAR VERSION CURRENT_VERSION REQUIRED_VERSION FEATURE PARAMETER0 PARAMETER1 PARAMETER2 etc
Also don't forget to contact me with your name (real or otherwise) so that I can add it to the about box text
@ZIP have you considered using a similar site for managing translations?
Post Tue Jan 24, 2012 8:53 pm
Re: Android Console
will wrote:@ZIP have you considered using a similar site for managing translations?
Just looking at that, had not idea something like this exists. Let me know your experiences and I can move to this model in future.
Post Tue Jan 24, 2012 9:42 pm
Re: Android Console
will wrote:I'm going to have a go at setting something up for translating the app. If you are interested in helping go to http://www.getlocalization.com/serviidroid/ sign up and start translating :) If its crap let me know and I'll try and find something else, if it seams easy to use then also let me know.
Do you want to split English in English (UK) and English (US)? I have seen it that way on different programs not sure it is worth it.
Northguy
Post Tue Jan 24, 2012 10:07 pm
Re: Android Console
App is running without problems on asus tf101 with android 3.2. Thanks
Also added 1st 50% of Dutch localisation...
Cheers
Post Tue Jan 24, 2012 10:13 pm
Re: Android Console
It looks quite good and I will let you know how it goes.
moltra wrote:Do you want to split English in English (UK) and English (US)? I have seen it that way on different programs not sure it is worth it.
I'm happy to have any languages that people want, however I simply don't have time at the moment to do any of the translations myself (not that I would be very good anyway).
The default will be English UK. Do translate any relivent words into US english if you want.
Northguy wrote:App is running without problems on asus tf101 with android 3.2. Thanks
Cheers
I saw, thanks. Any thoughts on the translation service?
