Web UI in Ajax (Mobile & desktop edition)
patters
Post Wed Jan 18, 2012 8:47 pm
Re: Web UI in Restful Ajax
Thanks kairoh. Now that I've spent some time styling it many of the small things you have changed make perfect sense (button placements, etc.). It's really well made - great work!
Here's how I'm getting on with trying to make it look like the Synology UI. There's a lot of content to squeeze into a small window so I don't want quite as much whitespace as Synology use, and I can't use the same javascript library for the UI widgets that they use without editing your code, so I've made it look as similar as I can using plain colours. I'm pleased with the result, but I want to find some way of incorporating the busy spinner animation without it taking up too much space.
I can confirm that the newer 0.6.2-a version's wrapper script does work with Java 6 and Java 7.
I have a few things to feed back/suggest if possible:
. Can you put the "Serviio Console" text in <h1> in a class so it can be hidden by the CSS, leaving the spinner visible? As you can see above, I don't really need the title because the window is already titled.
. Contrary to my earlier post, the UI does change language ok, but you have to click refresh. That wasn't obvious - I thought that Save would do it. Is there a reason to keep that as a separate button? All languages seem to work except the ones with country codes longer than 2 characters (pt_PT, pt_BR, zh_CN, zh_HK), so that's probably a simple fix. For these languages, the only text that is correctly changed is the Online Metadata Sources dropdown, so that should hopefully lead you to the problem.
. There are just a few superfluous <br> tags in there that need removing (I can adjust the spacing between elements using CSS, but these few inconsistent extra breaks are a problem). There is one on just above the Serviio Server Status, one below the text on the Trancoding tab, and one on the Console Settings lab above the language selection.
. Library Refresh probably ought to be a fieldset within the Shared Folders tab since it only relates to that (not to Online Sources which are parsed at a different interval). That's how it's done in Zip's UI.
. In Online Sources some feed URLs like gametrailers.com for instance can be very long - would it be possible to truncate them with "..." when they are longer than say 55 chars so they don't make a mess of the table? Perhaps something similar for long Shared Folder paths (but display "..." + the last 55 chars - which are more important than the first for a folder name).
. Online sources still have a selector check box even though they can be selected by being clicked (like Renderers and Shared Folders), so presumably that whole table column can be removed?
. In the Presentation tab could the table contents be split into classes depending on whether it's a heading (audio, video) or normal items, so they can be styled differently (indented)?
. I'm finding it hard to style this text on the Metadata tab. "Serviio includes various ways to retrieve descriptive metadata of your video files. Please pick one or select 'No descriptive metadata' from the drop-down box.". Should this perhaps be in <i> tags like the rest of the larger text fields? I need the linespacing to be narrower for that text in particular. In fact, those <i> items probably should be in their own class (to keep the styling completely separate from the HTML).
. If I use n-thchild to style every odd table row white (even rows slightly grey so the the rows are easier to see on screen without table borders) then it breaks the row select behaviour for those rows that have been styled differently. Do you know why this might be? I'm guessing it's connected to how you implemented that in javascript. To make it absolutely clear that they are selectable it would be great to have a "hover" class for these too, like with the tabs.
Now I'm going to work on the dialog boxes... :)
I'm going to be away for a few days, so the Synology package will need to wait just a little while longer. It'll be worth the wait though!
Post Thu Jan 19, 2012 12:04 am
this looks bloody good mate :shock:
kairoh
Post Thu Jan 19, 2012 10:23 am
Whooa Thanks Patters for all your good comments.
I definitely should create some bitbucket tickets to track them!
I'm currently working on a mobile edition to compete with will :P
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
Post Thu Jan 19, 2012 11:23 am
zip wrote:this looks bloody good mate :shock:
yer zip the standard one should look this good :P
kairoh
Post Thu Jan 19, 2012 2:01 pm
Patters, i've added your enhancements on bitbucket:
#2: Enhance busy spinner animation
#3: Languages change
#4: Superfluous <br> tags
#5: Repository tabs
#6: Online sources checkboxes
#7: Split table in presentation tab
#8: Create new class for description texts
#9: Update selectable rows CSS
I will try to include them in the next version.
reboot81
Post Sun Jan 22, 2012 6:16 pm
Cant get it to work...
userx:bin userx$ sh serviio-webui.sh
Exception in thread "main" java.lang.NoClassDefFoundError: org/restlet/Application
Caused by: java.lang.ClassNotFoundException: org.restlet.Application
   at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
   at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
Serviio.log output:
2012-01-22 19:14:19,275 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
java.net.BindException: Address already in use
   at java.net.PlainDatagramSocketImpl.bind0(Native Method)
   at java.net.PlainDatagramSocketImpl.bind(PlainDatagramSocketImpl.java:91)
   at java.net.DatagramSocket.bind(DatagramSocket.java:372)
   at java.net.MulticastSocket.bind(MulticastSocket.java:162)
   at java.net.MulticastSocket.<init>(MulticastSocket.java:147)
   at java.net.MulticastSocket.<init>(MulticastSocket.java:112)
   at org.serviio.util.MultiCastUtils.startMultiCastSocketForListening(MultiCastUtils.java:44)
   at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:79)
   at java.lang.Thread.run(Thread.java:680)
Im assuming 'SERVIIO_HOME' on OS X is /Applications/Serviio.app/Contents/Resources/Java ?
http://192.168.0.21:23423/rest/application returns ...<version>0.6.1</versi... but 127.0.0.1:8123/serviio/console is dead.
Running OS X 10.7.2 Serviio 0.6.1 and serviio-webclient-0.6.2-a
Where should I start? Help and ideas are appreciated!
/B
kairoh
Post Mon Jan 23, 2012 10:38 am
I see 2 pb here :
1) Serviio does not start properly on some Mac because of eyeconnect (?).
=> See this post.
2) Serviio webui is not properly installed
Try to :
- untar "serviio-webclient-0.6.2-a.tar.gz" to "/Applications/Serviio.app/Contents/Resources/Java", you should have some jar under the "plugins" dir and some sh under the "bin" dir.
- set execution right to all sh.
- launch "sh serviio-webui.sh" (in "/Applications/Serviio.app/Contents/Resources/Java/bin")
patters
Post Tue Jan 24, 2012 2:29 pm
kairoh wrote:Patters, i've added your enhancements on bitbucket:
That's great, thanks. I see you've fixed most of them already.
reboot81
Post Wed Jan 25, 2012 2:30 pm
First problem was due to other DLNA software running in background. Fixed now.
But number two is still not working. Downloaded new and reinstalled.
Files are in the following locations:
/Applications/Media/Serviio.app/Contents/Resources/Java/bin/serviio-webui.sh (and the other files)
/Applications/Media/Serviio.app/Contents/Resources/Java/plugins/serviio-webclient.jar
/Applications/Media/Serviio.app/Contents/Resources/Java/plugins/serviio-wrapper.jar
chmodded sh files to -rwxr-xr-x@
Tried to launch it with Serviio unloaded but it still returns:
user$ sh serviio-webui.sh
and
user$ sh serviio-wrapper.sh
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/serviio/restui/ServiioWrapper : Unsupported major.minor version 51.0
   at java.lang.ClassLoader.defineClass1(Native Method)
   at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
I'm running java version "1.6.0_29".
It there any editing needed inside the serviio-webui.sh file?
kairoh
Post Wed Jan 25, 2012 4:48 pm
About number two problem, here is a new split : ;)
2a) classpath problem (java.lang.NoClassDefFoundError: org/restlet/Application)
=> This is because Zip is not consistent between all OS :?
On linux, the jars are in
${SERVIIO_HOME}/lib
${SERVIIO_HOME}/plugins
On Mac, the jars are in
${SERVIIO_HOME}/
${SERVIIO_HOME}/plugins2 (in your case), but I recommend to use ${SERVIIO_HOME}/plugins
You may temporary try to update these lines of serviio-webui.sh :
WEBUI_CLASSPATH="$SERVIIO_WEBUI_HOME/config"
LIB=${SERVIIO_WEBUI_HOME}/plugins2 # LIB=${SERVIIO_WEBUI_HOME}/plugins
for jar in `ls -1 ${LIB}/*.jar`; do WEBUI_CLASSPATH="${WEBUI_CLASSPATH}:${jar}"; done
LIB=${SERVIIO_WEBUI_HOME}/ #LIB=${SERVIIO_WEBUI_HOME}/lib
2b) wrapper problem (java.lang.UnsupportedClassVersionError: org/serviio/restui/ServiioWrapper : Unsupported major.minor version 51.0)
=> this should be fixed by re-downloading the last 0.6.2-a (I first uploaded a wrong version...).
BUT then you'll encounter the 2a) problem with serviio-wrapper.sh.
Either Zip change the MacOS package, or I should find a way to detect the current OS...
Post Wed Jan 25, 2012 5:10 pm
oh, didn't realize that. create a bitbucket ticket please
kairoh
Post Wed Jan 25, 2012 10:11 pm
You should thanks reboot81 for this new issue!
maybe
Post Sat Jan 28, 2012 3:13 pm
thanks for this cool gui...unfortunately I got a prob
using the scripts (from irlaird & jtl) to start on my headles squeeze
echo "#########################################################
#- Daemon Script Configuration for Serviio Media Server
#- By Ian Laird
#- /etc/conf.d/serviiod
NAME="Serviio Media Server"
DAEMON="/bin/serviio"    ## Update this to point at pc5dczc_root/bin/serviio.sh
SERVICE_ACCOUNT="root" ## DON'T RUN UNDER ROOT!";
echo "#!/bin/sh
#- Daemon script for Serviio media server
#- By Ian Laird; converted for Debian by Jacob Lundberg
#- /etc/init.d/serviio
### BEGIN INIT INFO
# Provides:          serviio
# Required-Start:    $local_fs $remote_fs $network $syslog
# Required-Stop:     $local_fs $remote_fs $network $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# X-Interactive:     true
# Short-Description: Start/stop serviio media server
# Description:       The Serviio media server makes your media available to
#                    all kinds of networked devices.
### END INIT INFO
. /lib/lsb/init-functions
if [ -f /etc/default/rcS ]; then
        . /etc/default/rcS
fi
DAEMON_STOP=" -stop"
NAME="$(basename $0)"
PIDFILE="/var/run/serviiod.pid"
TIMEOUT=10
if [ -f /etc/default/serviio ]; then
        . /etc/default/serviio
fi
[ -x "$DAEMON" ] || exit 0
running() {
        if [ "x$1" == "x" ]; then
                echo 0
                return 1
        fi
        PS=$(ps h -p $(echo $1 | sed -r 's/[\t \n]+/ -p /') | wc -l)
        echo $PS
        if [ $PS -gt 0 ]; then
                return 0
        else
                return 1
        fi
start() {
        log_daemon_msg "Starting Serviio media server daemon" "$NAME"
        start-stop-daemon --start -q -b -p "$PIDFILE" -m -c "${SERVICE_ACCOUNT}" -x "${DAEMON}"
        log_end_msg $?
stop() {
        log_daemon_msg "Stopping Serviio media server daemon" "$NAME"
        if [ -r "$PIDFILE" ]; then
                PIDS=$(pstree -p $(<"$PIDFILE") | awk -F'[\(\)]' '/^[A-Za-z0-9]/ { print $2" "$4; }')
                if running "$PIDS" > /dev/null; then
                        "${DAEMON}" "${DAEMON_STOP}"
                        for PID in $PIDS; do
                                if running $PID > /dev/null; then
                                        kill -TERM $PID
                                fi
                        done
                fi
                COUNTDOWN=$TIMEOUT
                while let COUNTDOWN--; do
                        if ! running "$PIDS" > /dev/null; then
                                break
                        fi
                        if [ $COUNTDOWN -eq 0 ]; then
                                                kill -KILL $PID
                                        fi
                                done
                        else
                                echo -n .
                                sleep 1
                        fi
                done
        fi
                log_end_msg 1
        else
                rm -f "$PIDFILE"
                log_end_msg $?
        fi
status() {
        echo -n "$NAME should be"
                echo -n " up with primary PID $(<"$PIDFILE")"
                RUNNING=$(running "$PIDS")
                if [[ $RUNNING && $RUNNING -gt 0 ]]; then
                        echo -n " and $RUNNING processes are running."
                else
                        echo -n " but it is not running."
                fi
        else
                echo -n " stopped."
        fi
        echo
case "${1:-}" in
        start)
                start
        stop)
                stop
        restart)
                stop
                start
        status)
                status
                log_success_msg "Usage: /etc/init.d/$NAME {start|stop|restart|status}"
                exit 1
esac
exit 0";
Everythings works fine
this gui works also fine (in remote modus) when I start manually
BUT...how can I configure this script to start serviio.sh including -Dserviio.remoteHost=SERVER-IP for the remote mode :?:
AND...how can I start serviio-webui.sh -Dserviio.remoteHost=SERVER-IP automatically :?:
kairoh
Post Mon Jan 30, 2012 1:55 pm
I'm not sure I understand your question... Do you wish :
a) to update Serviio and Webui shells options ?
b) to update Debian "daemonising scripts" ?
kairoh
Post Tue Jan 31, 2012 6:43 pm
New version (0.6.2-b) is here!
It is compatible with Serviio 0.6.1 and 0.6.2.
0.6.2-b
- New theme (inspired form Patters Synology).
- Update wrapper : starts WebUI before Serviio.
- Update 0.6.2 translations (de, el, fr, sl, zh_CN and zh_HK), thanks to all forum members.
- Auto-generate uuid for new renderer addition.
- New attempts to auto-resize inline popup/iframe.
- Enhance inline popup (Html5 compliance).
- Repair alignment issues (in tables).
- fixed issue #10 : Allow to add feed after feed edition.
- fixed issue #9: Update CSS for selectable rows.
- fixed issue #8: New CSS class for description texts.
- fixed issue #7: Enhance tables in presentation tab.
- fixed issue #5: Reorganize repository tabs.
- fixed issue #4: Remove superfluous <br> tags.
- fixed issue #3: Fix languages changing (lower case bug).
- fixed issue #2: Enhance busy spinner animation.
Have fun!
maybe
Post Wed Feb 01, 2012 1:15 pm
servio.sh starts automatically as daemon but I want start like
servio.sh -Dserviio.remoteHost=SERVER-IP
also I like to start the webui as service including the remote options -Dserviio.remoteHost=SERVER-IP
without "-Dserviio.remoteHost=SERVER-IP" on servio an webui it won't work
kairoh
Post Thu Feb 02, 2012 10:20 am
If Serviio and the WebUI are installed on the same machine you don't need to set this parameter (they talk together locally).
If Serviio is on machine A and WebUI is on machine B, you'll need to set this parameter on both to machine A's IP.
For this, you have to directly change every sh.
Post Thu Feb 02, 2012 11:51 am
kairoh wrote:If Serviio is on machine A and WebUI is on machine B, you'll need to set this parameter on both to machine A's IP.
Since 0.6 the server part should not be necessary, but it's still there if is doesn't work out of the box.
kairoh
Post Tue Feb 07, 2012 8:47 pm
Here is a small new version (0.6.2-c).
It is still compatible with Serviio 0.6.1 and 0.6.2.
0.6.2-c
- Fixed wrapper : manage only one instance and proper 'stop' argument.
- Auto enable new online content sources.
- Separate spinner and title in header.
Have fun!
Swehawk
Post Wed Feb 29, 2012 8:31 pm
The new 0.6.2 webui is really cool and works great :) Thanks kairoh!
A small :?: though: Is there a command to kill the webui process without having to kill javaw in taskmanager (win7)?
Users browsing this forum: No registered users and 120 guests
