Not supported file format?
Any ideas?
I am using the c/d profile.
selector007 wrote:I can stream video fine but I get the above error when i access my photos folder. When i play the folder as a slideshow it will show some pictures then show the above message? The images are standard jpgs taken from my camera.
Any ideas?
selector007 wrote:I doubt its a corrupt jpeg as i have several folders with jpgs and it has the same problem. It doesn't like some jpgs its strange.
selector007 wrote:I've been trying to see if there is a pattern and i've noticed Serviio will not play images which have been taken on my camera in a vertical position. My camera is a compact digital canon and i think this is the problem when a picture is taken holding the camera in a vertical position Serviio has trouble with it. This seems like a bug to me. All pictures which have been taken in a the normal horizontal position are fine.
selector007 wrote:Thanks for the info great help.
I think my problem is i just copy my photos from my memory card to my server. I think yhe best option is to do this via some software as this will retain the correct metadata.
Ashkarion wrote:I had the same problem on my Samsung D6500 - also with pictures from a Canon camera, interestingly. Pics with vertical orientation, i.e. +/-90° rotation in the EXIF data, did not display, instead I got an error message. I don't think I have corrupt EXIF data, I use the Canon software for transfer; besides, using AllShare the photos worked on the TV - but I don't want to use AllShare.
Well, after messing around a bit it seems I found a fix for this in Serviio, although I have not tested thoroughly if it affects other functions.
I changed the <AutomaticImageRotation> option in profiles.xml from true to false. After a restart of the Serviio server the pictures worked just fine. Rotation by 90° still worked, the images displayed in correct orientation, so I have no idea what that option actually did...
If anybody knows some functionality this could break, please tell me. I will test that a bit myself. Hope that helps other users with the same problem!
Any ideas?
