is client connected
mattbrowne
Post Thu Jan 19, 2012 7:08 pm
is client connected
I've tried searching around the forum but couldn't see anything - but I was wondering if there is a way of an external script to query serviio to see if any clients are connected/active.
I can see in the gui that it knows when a client is active with serviio - but I'd like to be able to find this out from a script (bash/csh/tcl etc) so I can control whether to send the server to sleep, also based on whether other clients are connected to other services my server runs (e.g. squeezebox server).
Matt
Post Thu Jan 19, 2012 7:16 pm
Re: is client connected
Check Serviio REST API guide in the dev forum, you'll be able to get list of clients in the same way the console does.
mattbrowne
Post Thu Jan 19, 2012 9:50 pm
Thanks! Server now stays awake and sleeps when it should - saved a few pennies on the power bill :)
spelarn
Post Wed May 09, 2012 8:58 pm
RE: is client connected
Hi matt. I would apprechiate i you could share what you did to succeeded. Need thoose pennies :D
Return to General discussion
