No subs when transcoding file with LG42LW5500
frikzy
Post Thu Jan 19, 2012 8:16 pm
I mannaged to have srt subtitles with avi or mkv file on my 42LW5500 TV. Problem is when I transcode mkv file because of DTS audio. Transcoding went well, audio is OK, but then I do not have subtitles. Is it possible to have subtitles with transcoded file? Maybe the problem is that transcoded file is not in it's original folder, but in C:\\Windows\temp\transcoding-temp-21224-MPEG2TS.stf and with different name than original file.
Anyway, Serviio is really great software. :)
Thanks!
My LG profile is:
<Profile id="22" name="LG TV 2011" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>.*LW550.*</FriendlyName>
            <Manufacturer>LG Electronics</Manufacturer>
         </UPnPSearch>
      </Detection>
            <Matches container="asf" />
            <Matches container="flv" />
            <Matches container="ogg" />
            <!-- digital camera video formats -->
         <Matches container="3gp" aCodec="amrnb" />
            <Matches container="mp4" />
            <Matches container="flac" />
      </Audio>
Post Thu Jan 19, 2012 9:17 pm
Re: No subs when transcoding file with LG42LW5500
It should work. Post detailed log of playing the file.
frikzy
Post Thu Jan 19, 2012 10:01 pm
Thank you for fast response.
Here is detailedlog:
2012-01-19 22:49:35,421 DEBUG [WebServer] Incoming connection from /192.168.1.11:49952
2012-01-19 22:49:35,421 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:35,421 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:35,421 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 1, sortCriteria =
2012-01-19 22:49:35,421 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 16
2012-01-19 22:49:35,437 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder 16 (from=0, count=1)
2012-01-19 22:49:35,453 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 17
2012-01-19 22:49:35,453 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 16
2012-01-19 22:49:35,453 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-01-19 22:49:35,453 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:35,468 DEBUG [WebServer] Incoming connection from /192.168.1.11:49953
2012-01-19 22:49:35,468 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:35,484 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:35,484 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2012-01-19 22:49:35,484 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-01-19 22:49:35,500 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:37,359 DEBUG [WebServer] Incoming connection from /192.168.1.11:49955
2012-01-19 22:49:41,187 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (ULi PCI Fast Ethernet Controller - Packet Scheduler Miniport) and address 192.168.1.5, timeout = 0
2012-01-19 22:49:41,187 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0
2012-01-19 22:49:42,218 DEBUG [WebServer] Incoming connection from /192.168.1.11:49957
2012-01-19 22:49:42,218 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:42,218 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:42,218 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2012-01-19 22:49:42,218 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-01-19 22:49:42,234 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:42,328 DEBUG [WebServer] Incoming connection from /192.168.1.11:49958
2012-01-19 22:49:42,328 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:42,328 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:42,328 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675, browseFlag = BrowseMetadata, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 0, sortCriteria =
2012-01-19 22:49:42,328 DEBUG [FolderDAOImpl] Reading a Folder (id = 675)
2012-01-19 22:49:42,328 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 675
2012-01-19 22:49:42,328 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-01-19 22:49:42,593 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:42,609 DEBUG [WebServer] Incoming connection from /192.168.1.11:49959
2012-01-19 22:49:42,609 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:42,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:42,609 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2012-01-19 22:49:42,609 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 675
2012-01-19 22:49:42,625 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 675 (from=0, count=16)
2012-01-19 22:49:42,640 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2012-01-19 22:49:42,656 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:42,671 DEBUG [MediaItemDAOImpl] Getting file of media item 21225
2012-01-19 22:49:42,687 DEBUG [SubtitlesService] Found subtitle file: E:\PC_NFS\My_Movies\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.srt
2012-01-19 22:49:42,687 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:42,703 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 21225 and profile LG TV 2011
2012-01-19 22:49:42,703 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:42,718 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15901)
2012-01-19 22:49:42,750 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:42,750 DEBUG [MediaItemDAOImpl] Getting file of media item 21225
2012-01-19 22:49:42,765 DEBUG [SubtitlesService] Found subtitle file: E:\PC_NFS\My_Movies\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.srt
2012-01-19 22:49:42,765 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2012-01-19 22:49:42,765 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21224)
2012-01-19 22:49:42,765 DEBUG [MediaItemDAOImpl] Getting file of media item 21224
2012-01-19 22:49:42,765 DEBUG [VideoDAOImpl] Reading a Video (id = 21224)
2012-01-19 22:49:42,765 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 21224 and profile LG TV 2011
2012-01-19 22:49:42,765 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file transcoding-temp-19446-MPEG2TS.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:42,765 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15900)
2012-01-19 22:49:42,781 DEBUG [MediaItemDAOImpl] Getting file of media item 21224
2012-01-19 22:49:42,781 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 675
2012-01-19 22:49:42,781 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-01-19 22:49:42,781 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:42,812 DEBUG [WebServer] Incoming connection from /192.168.1.11:49961
2012-01-19 22:49:42,812 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:42,812 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:42,812 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 1, sortCriteria =
2012-01-19 22:49:42,812 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 675
2012-01-19 22:49:42,812 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 675 (from=0, count=1)
2012-01-19 22:49:42,843 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2012-01-19 22:49:42,843 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:42,843 DEBUG [MediaItemDAOImpl] Getting file of media item 21225
2012-01-19 22:49:42,843 DEBUG [SubtitlesService] Found subtitle file: E:\PC_NFS\My_Movies\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.srt
2012-01-19 22:49:42,843 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:42,843 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 21225 and profile LG TV 2011
2012-01-19 22:49:42,843 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:42,843 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15901)
2012-01-19 22:49:42,843 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 675
2012-01-19 22:49:42,843 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-01-19 22:49:42,859 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:42,875 DEBUG [WebServer] Incoming connection from /192.168.1.11:49962
2012-01-19 22:49:42,875 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:42,875 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:42,890 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2012-01-19 22:49:42,890 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-01-19 22:49:42,890 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:42,921 DEBUG [WebServer] Incoming connection from /192.168.1.11:49963
2012-01-19 22:49:42,921 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:42,921 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:42,921 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 2, count = 14, sortCriteria =
2012-01-19 22:49:42,921 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 675
2012-01-19 22:49:42,921 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 675 (from=2, count=14)
2012-01-19 22:49:42,953 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 675
2012-01-19 22:49:42,953 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-01-19 22:49:42,953 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:42,968 DEBUG [WebServer] Incoming connection from /192.168.1.11:49964
2012-01-19 22:49:42,968 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:42,968 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:42,984 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 2, count = 14, sortCriteria =
2012-01-19 22:49:42,984 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-01-19 22:49:43,000 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:43,125 WARN  [PluginCompilerThread] Plugin NHLGameCenterPlugin.groovy failed to compile: startup failed:
C:\Program Files\Serviio\plugins\NHLGameCenterPlugin.groovy: 9: unable to resolve class groovyx.net.http.ContentType
 @ line 9, column 1.
   import static groovyx.net.http.ContentType.*
 @ line 9, column 1.
C:\Program Files\Serviio\plugins\NHLGameCenterPlugin.groovy: 52: unable to resolve class HTTPBuilder
 @ line 52, column 16.
         def tvHttp = new HTTPBuilder(tvAuthUrl);
C:\Program Files\Serviio\plugins\NHLGameCenterPlugin.groovy: 104: unable to resolve class HTTPBuilder
 @ line 104, column 16.
         def tvHttp = new HTTPBuilder(tvReqUrl);
C:\Program Files\Serviio\plugins\NHLGameCenterPlugin.groovy: 137: unable to resolve class HTTPBuilder
 @ line 137, column 22.
               def tvGameHttp = new HTTPBuilder('http://gamecenter.nhl.com');
C:\Program Files\Serviio\plugins\NHLGameCenterPlugin.groovy: 213: unable to resolve class HTTPBuilder
 @ line 213, column 16.
6 errors
2012-01-19 22:49:43,187 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (TechniSat DVB-PC TV Star PCI - Packet Scheduler Miniport) and address 192.168.238.238, timeout = 0
2012-01-19 22:49:43,187 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0
2012-01-19 22:49:43,187 DEBUG [DiscoveryAdvertisementNotifier] Problem during DiscoveryAdvertisementNotifier for name:eth1 (TechniSat DVB-PC TV Star PCI - Packet Scheduler Miniport), will try again
java.net.SocketException: Interrupted function call: Datagram send failed
   at java.net.PlainDatagramSocketImpl.send(Native Method)
   at java.net.DatagramSocket.send(Unknown Source)
   at org.serviio.util.MultiCastUtils.send(MultiCastUtils.java:85)
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAliveToSingleInterface(DiscoveryAdvertisementNotifier.java:188)
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAlive(DiscoveryAdvertisementNotifier.java:135)
   at org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.run(DiscoveryAdvertisementNotifier.java:97)
   at java.lang.Thread.run(Unknown Source)
2012-01-19 22:49:43,187 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:19
2012-01-19 22:49:43,390 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-01-19 22:49:43,390 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-01-19 22:49:43,390 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-01-19 22:49:43,671 DEBUG [WebServer] Incoming connection from /192.168.1.11:49965
2012-01-19 22:49:43,671 DEBUG [ResourceTransportRequestHandler] GET /resource/15901/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,transferMode.dlna.org: Interactive,Connection: Close,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:49:43,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:43,671 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:43,671 DEBUG [ResourceTransportRequestHandler] Request for resource 15901 and type 'COVER_IMAGE' received
2012-01-19 22:49:43,671 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15901)
2012-01-19 22:49:43,687 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 15901
2012-01-19 22:49:43,687 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6262
2012-01-19 22:49:43,687 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:49:43,687 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6262,Date: Thu, 19 Jan 2012 21:49:43 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-01-19 22:49:43,765 DEBUG [WebServer] Incoming connection from /192.168.1.11:49966
2012-01-19 22:49:43,765 DEBUG [ResourceTransportRequestHandler] GET /resource/15900/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,transferMode.dlna.org: Interactive,Connection: Close,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:49:43,765 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:43,765 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:43,765 DEBUG [ResourceTransportRequestHandler] Request for resource 15900 and type 'COVER_IMAGE' received
2012-01-19 22:49:43,765 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15900)
2012-01-19 22:49:43,765 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 15900
2012-01-19 22:49:43,765 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6262
2012-01-19 22:49:43,765 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:49:43,765 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6262,Date: Thu, 19 Jan 2012 21:49:43 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-01-19 22:49:44,718 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.12:59000
2012-01-19 22:49:44,734 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.12:59000
2012-01-19 22:49:47,359 DEBUG [WebServer] Incoming connection from /192.168.1.11:49968
2012-01-19 22:49:52,171 DEBUG [WebServer] Incoming connection from /192.168.1.11:49971
2012-01-19 22:49:52,171 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:52,171 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:52,187 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 16, sortCriteria =
2012-01-19 22:49:52,187 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-01-19 22:49:52,203 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:52,234 DEBUG [WebServer] Incoming connection from /192.168.1.11:49972
2012-01-19 22:49:52,234 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:52,234 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:52,234 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 2, count = 14, sortCriteria =
2012-01-19 22:49:52,234 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-01-19 22:49:52,234 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:52,250 DEBUG [WebServer] Incoming connection from /192.168.1.11:49973
2012-01-19 22:49:52,250 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:52,250 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:52,250 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,@childCount,dc:title,dc:creator, upnp:artist,upnp:class,dc:date,upnp:album,upnp:genre,res,res@size,res@duration,res@protection,res@bitrate,res@resolution,res@protocolInfo,res@nrAudioChannels,res@sampleFrequency,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID, startIndex = 2, count = 14, sortCriteria =
2012-01-19 22:49:52,250 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-01-19 22:49:52,250 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:52,265 DEBUG [WebServer] Incoming connection from /192.168.1.11:49974
2012-01-19 22:49:52,265 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.11:
2012-01-19 22:49:52,265 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:52,265 DEBUG [ContentDirectory] Browse() called for renderer MediaRenderer (profile 22) with parameters: objectID = V_F^FOL_R1$F16$F675$MI21225, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 0, sortCriteria =
2012-01-19 22:49:52,265 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:52,281 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2012-01-19 22:49:52,281 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:52,281 DEBUG [MediaItemDAOImpl] Getting file of media item 21225
2012-01-19 22:49:52,281 DEBUG [SubtitlesService] Found subtitle file: E:\PC_NFS\My_Movies\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.srt
2012-01-19 22:49:52,281 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:52,281 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 21225 and profile LG TV 2011
2012-01-19 22:49:52,281 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:52,281 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15901)
2012-01-19 22:49:52,281 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-01-19 22:49:52,296 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-19 22:49:52,343 DEBUG [WebServer] Incoming connection from /192.168.1.11:49975
2012-01-19 22:49:52,343 DEBUG [ResourceTransportRequestHandler] GET /resource/21225/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:49:52,343 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:52,343 DEBUG [WebServer] Incoming connection from /192.168.1.11:49976
2012-01-19 22:49:52,343 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:52,343 DEBUG [ResourceTransportRequestHandler] Request for resource 21225 and type 'MEDIA_ITEM' received
2012-01-19 22:49:52,343 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 21225 (local)
2012-01-19 22:49:52,343 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:52,343 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:52,343 DEBUG [VideoDeliveryEngine] Delivering item '21225' for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:52,343 DEBUG [VideoDeliveryEngine] Delivering file '3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv' using transcoding
2012-01-19 22:49:52,343 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:52,343 DEBUG [MediaItemDAOImpl] Getting file of media item 21225
2012-01-19 22:49:52,359 DEBUG [VideoDeliveryEngine] Delivering file '3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv' using transcoding
2012-01-19 22:49:52,359 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\PC_NFS\My_Movies\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv
2012-01-19 22:49:52,359 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i E:\PC_NFS\My_Movies\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL\3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv -y -async 1 -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\Temp\Serviio\transcoding-temp-21225-MPEG2TS.stf
2012-01-19 22:49:52,859 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-01-19 22:49:52,859 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:52,859 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:52,859 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 21225) as read
2012-01-19 22:49:52,875 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:52,875 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 21225) as read
2012-01-19 22:49:53,171 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-01-19 22:49:53,171 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-01-19 22:49:53,171 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-01-19 22:49:53,171 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:49:53,187 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 19 Jan 2012 21:49:53 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-01-19 22:49:53,203 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-01-19 22:49:53,203 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-01-19 22:49:53,203 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-01-19 22:49:53,203 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-01-19 22:49:53,203 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:49:53,203 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Thu, 19 Jan 2012 21:49:53 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-01-19 22:49:53,265 DEBUG [WebServer] Incoming connection from /192.168.1.11:49977
2012-01-19 22:49:53,265 DEBUG [ResourceTransportRequestHandler] GET /resource/21225/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,Range: bytes=4611686018427371520-,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:49:53,265 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:53,265 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:53,296 DEBUG [ResourceTransportRequestHandler] Request for resource 21225 and type 'MEDIA_ITEM' received
2012-01-19 22:49:53,296 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 21225 (local)
2012-01-19 22:49:53,296 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:53,312 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:53,312 DEBUG [VideoDeliveryEngine] Delivering item '21225' for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:53,312 DEBUG [VideoDeliveryEngine] Delivering file '3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv' using transcoding
2012-01-19 22:49:53,343 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:53,343 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-01-19 22:49:53,421 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:53,421 DEBUG [ResourceTransportRequestHandler] Unsupported range request, sending back 416
2012-01-19 22:49:53,437 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 416 Requested Range Not Satisfiable, headers = [[Content-Type: video/mpeg]]
2012-01-19 22:49:53,484 DEBUG [WebServer] Incoming connection from /192.168.1.11:49978
2012-01-19 22:49:53,484 DEBUG [ResourceTransportRequestHandler] GET /resource/21225/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,Range: bytes=16384-,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:49:53,484 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:53,500 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:53,500 DEBUG [ResourceTransportRequestHandler] Request for resource 21225 and type 'MEDIA_ITEM' received
2012-01-19 22:49:53,500 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 21225 (local)
2012-01-19 22:49:53,500 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:53,500 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:53,531 DEBUG [VideoDeliveryEngine] Delivering item '21225' for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:53,531 DEBUG [VideoDeliveryEngine] Delivering file '3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv' using transcoding
2012-01-19 22:49:53,531 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:53,531 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-01-19 22:49:53,546 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:53,546 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 49999983616
2012-01-19 22:49:53,546 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-01-19 22:49:53,546 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:49:53,546 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 16384-49999999999/50000000000,Date: Thu, 19 Jan 2012 21:49:53 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-01-19 22:49:54,125 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-01-19 22:49:54,250 DEBUG [WebServer] Incoming connection from /192.168.1.11:49979
2012-01-19 22:49:54,250 DEBUG [ResourceTransportRequestHandler] GET /resource/21225/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,Range: bytes=2113536-,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:49:54,250 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:54,250 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:54,265 DEBUG [ResourceTransportRequestHandler] Request for resource 21225 and type 'MEDIA_ITEM' received
2012-01-19 22:49:54,265 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 21225 (local)
2012-01-19 22:49:54,265 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:54,265 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:54,281 DEBUG [VideoDeliveryEngine] Delivering item '21225' for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:54,281 DEBUG [VideoDeliveryEngine] Delivering file '3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv' using transcoding
2012-01-19 22:49:54,281 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:54,281 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-01-19 22:49:54,296 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:54,296 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 49997886464
2012-01-19 22:49:54,296 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-01-19 22:49:54,296 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:49:54,296 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 2113536-49999999999/50000000000,Date: Thu, 19 Jan 2012 21:49:54 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-01-19 22:49:54,656 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-01-19 22:49:54,984 DEBUG [WebServer] Incoming connection from /192.168.1.11:49981
2012-01-19 22:49:54,984 DEBUG [ResourceTransportRequestHandler] GET /resource/21225/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,Range: bytes=3457024-,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:49:54,984 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:54,984 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:54,984 DEBUG [ResourceTransportRequestHandler] Request for resource 21225 and type 'MEDIA_ITEM' received
2012-01-19 22:49:54,984 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 21225 (local)
2012-01-19 22:49:54,984 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:55,000 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:55,000 DEBUG [VideoDeliveryEngine] Delivering item '21225' for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:55,000 DEBUG [VideoDeliveryEngine] Delivering file '3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv' using transcoding
2012-01-19 22:49:55,000 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:55,000 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-01-19 22:49:55,015 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:55,015 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 49996542976
2012-01-19 22:49:55,015 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-01-19 22:49:55,015 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:49:55,015 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 3457024-49999999999/50000000000,Date: Thu, 19 Jan 2012 21:49:55 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-01-19 22:49:55,375 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-01-19 22:49:57,375 DEBUG [WebServer] Incoming connection from /192.168.1.11:49982
2012-01-19 22:49:58,265 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-01-19 22:49:58,359 WARN  [PluginCompilerThread] Plugin NHLGameCenterPlugin.groovy failed to compile: startup failed:
 @ line 9, column 1.
 @ line 9, column 1.
6 errors
2012-01-19 22:49:59,359 DEBUG [WebServer] Incoming connection from /192.168.1.11:49984
2012-01-19 22:49:59,359 DEBUG [ResourceTransportRequestHandler] GET /resource/21225/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,Range: bytes=24762368-,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:49:59,359 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:49:59,359 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:59,359 DEBUG [ResourceTransportRequestHandler] Request for resource 21225 and type 'MEDIA_ITEM' received
2012-01-19 22:49:59,359 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 21225 (local)
2012-01-19 22:49:59,359 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:49:59,359 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:49:59,359 DEBUG [VideoDeliveryEngine] Delivering item '21225' for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:59,359 DEBUG [VideoDeliveryEngine] Delivering file '3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv' using transcoding
2012-01-19 22:49:59,359 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:49:59,359 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-01-19 22:49:59,546 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:49:59,546 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 49975237632
2012-01-19 22:49:59,546 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-01-19 22:49:59,546 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:49:59,546 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 24762368-49999999999/50000000000,Date: Thu, 19 Jan 2012 21:49:59 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-01-19 22:50:00,484 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-01-19 22:50:03,375 DEBUG [WebServer] Incoming connection from /192.168.1.11:49986
2012-01-19 22:50:03,375 DEBUG [ResourceTransportRequestHandler] GET /resource/21225/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,Range: bytes=30169088-,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:50:03,375 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:50:03,390 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:50:03,390 DEBUG [ResourceTransportRequestHandler] Request for resource 21225 and type 'MEDIA_ITEM' received
2012-01-19 22:50:03,390 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 21225 (local)
2012-01-19 22:50:03,390 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:50:03,390 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:50:03,390 DEBUG [VideoDeliveryEngine] Delivering item '21225' for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:50:03,390 DEBUG [VideoDeliveryEngine] Delivering file '3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv' using transcoding
2012-01-19 22:50:03,390 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:50:03,390 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-01-19 22:50:03,734 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:50:03,734 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 49969830912
2012-01-19 22:50:03,734 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-01-19 22:50:03,734 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:50:03,734 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 30169088-49999999999/50000000000,Date: Thu, 19 Jan 2012 21:50:03 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-01-19 22:50:04,718 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-01-19 22:50:07,296 DEBUG [WebServer] Incoming connection from /192.168.1.11:49989
2012-01-19 22:50:07,296 DEBUG [ResourceTransportRequestHandler] GET /resource/21225/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.5:8895,Pragma: no-cache,Cache-Control: no-cache,Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, image/png, text/html, text/xml, text/plain, application/json, application/atom+xml, application/xml, */*,Accept-Language: ko-kr, ko;q=0.8, en-us;q=0.5, en;q=0.3,Connection: Close,Range: bytes=35207168-,User-Agent: Mozilla/5.0 (compatible; LG-HttpClient-v1.0.3 UPnP/1.1; MSIE 8.0; Windows NT 5.1; LG_UA; AD_LOGON=LGE.NET; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; LG_UA; AD_LOGON=LGE.NET; LG NetCast.TV-2011)]]
2012-01-19 22:50:07,296 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.11
2012-01-19 22:50:07,296 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:50:07,296 DEBUG [ResourceTransportRequestHandler] Request for resource 21225 and type 'MEDIA_ITEM' received
2012-01-19 22:50:07,296 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 21225 (local)
2012-01-19 22:50:07,296 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 21225)
2012-01-19 22:50:07,296 DEBUG [VideoDAOImpl] Reading a Video (id = 21225)
2012-01-19 22:50:07,296 DEBUG [VideoDeliveryEngine] Delivering item '21225' for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:50:07,296 DEBUG [VideoDeliveryEngine] Delivering file '3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv' using transcoding
2012-01-19 22:50:07,312 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.11, Profile=LG TV 2011'
2012-01-19 22:50:07,312 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-01-19 22:50:07,312 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file 3D Avatar 3D 2009 1080p Half-SBS BluRay DTS x264-3D4ALL.mkv: AVC_TS_MP_HD_AC3_ISO
2012-01-19 22:50:07,312 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 49964792832
2012-01-19 22:50:07,328 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-01-19 22:50:07,328 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-01-19 22:50:07,328 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 35207168-49999999999/50000000000,Date: Thu, 19 Jan 2012 21:50:07 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-01-19 22:50:07,375 DEBUG [WebServer] Incoming connection from /192.168.1.11:49990
2012-01-19 22:50:08,046 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-01-19 22:50:09,109 WARN  [PluginCompilerThread] Plugin NHLGameCenterPlugin.groovy failed to compile: startup failed:
Few explanations:
192.168.1.5 is PC with Serviio
192.168.1.11 is LG TV 42LW5500-ZE
192.168.1.12 is LG Blu Ray player BD660. It is not seen with DeviceSpy, but it sees Servio. Only problem is that there is no subtitles when playing files.
Post Fri Jan 20, 2012 10:16 am
Serviio serves the srt file but the player never requests it. Not sure why.
peterr
Post Thu Jan 26, 2012 3:07 pm
I've the same problem with my LG 47LK950S (2011 model). If transcoding is enabled (DTS -> AC3 for MKV) then I don't get subtitles, if I disable the transcoding in serviio control panel then I get subtitles but no audio (since LG does not support DTS).
I've attached two log files, one with transcoding and one without, if it helps. In both cases I stopped serviio, deleted log, then run serviio, wait for start process to finish, connect via LG TV, browse to folder with movie, start play, pause, get log.
I use serviio 0.6.0.1-005 on Synology DS110j, with java jdk 1.7.0_02-005 and ffmpeg 0.8.2.git-05a2673-Serviio. TV is LG 47LK950S-ZA, fw 05.01.10 (latest), connected via wireless and dhcp.
Any ideas if this can be solved in serviio in the future or is this a limitation of this tv (with current fw)?
Edit: just for the info, I modified generic profile to support transcoding dts -> ac3 because serviio constantly reverted lg tv profile to generic profile. This is temporary solution until I install serviio 0.6.1 where this seems to be fixed. The following is added to generic profile:
         <Video targetContainer="mpegts" targetACodec="ac3" forceStereo="true" >
logs.zip
(38.03 KiB) Downloaded 766 times
Post Thu Jan 26, 2012 3:26 pm
nothing we can do about it at the current time, as LG dont support subtitles for transcoded files.
Return to LG
