UT30 some files stop playing after ~10 seconds
Tarrasque
Post Sat Jan 21, 2012 8:26 am
I have a Panasonic UT30 (same device sink fields as E30 / GT30).
There are some files which seem to 'crash' after ~10 seconds of play. This is not a fault of serviio as far as I can tell as they also crash if playing off a USB stick.
A quick and nasty way to get these files to work is just run them through mkvmerge.
Any how here are the ffmpeg / mediainfo files of some of the programs which dont work
C:\Program Files (x86)\Serviio\lib>ffmpeg -i "d:\Completed\Hustle.8x02.HDTV_XviD-FoV.[VTV].avi"
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Input #0, avi, from 'd:\Completed\Hustle.8x02.HDTV_XviD-FoV.[VTV].avi':
    encoder         : transcode-1.1.5
  Duration: 00:58:50.92, start: 0.000000, bitrate: 1308 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x352 [SAR 1:1 DAR 39:22], 25 tbr, 25 tbn, 25 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 192 kb/s
CompleteName                     : D:\Completed\Hustle.8x02.HDTV_XviD-FoV.[VTV].avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
FileSize/String                  : 551 MiB
Duration/String                  : 58mn 50s
OverallBitRate_Mode/String       : Variable
OverallBitRate/String            : 1 309 Kbps
Encoded_Application              : transcode-1.1.5
ID/String                        : 0
Format                           : MPEG-4 Visual
Format_Profile                   : Advanced Simple@L5
Format_Settings_BVOP/String      : 2
Format_Settings_QPel/String      : No
Format_Settings_GMC/String       : No warppoints
Format_Settings_Matrix/String    : Default (H.263)
CodecID                          : XVID
CodecID/Hint                     : XviD
BitRate/String                   : 1 165 Kbps
Width/String                     : 624 pixels
Height/String                    : 352 pixels
DisplayAspectRatio/String        : 16:9
FrameRate/String                 : 25.000 fps
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
ScanType/String                  : Progressive
Compression_Mode/String          : Lossy
Bits-(Pixel*Frame)               : 0.212
StreamSize/String                : 490 MiB (89%)
Encoded_Library/String           : XviD 1.2.1 (UTC 2008-12-04)
ID/String                        : 1
Format                           : MPEG Audio
Format_Version                   : Version 1
Format_Profile                   : Layer 3
Format_Settings_Mode             : Joint stereo
Format_Settings_ModeExtension    : MS Stereo
CodecID                          : 55
CodecID/Hint                     : MP3
BitRate/String                   : 192 Kbps
Channel(s)/String                : 2 channels
SamplingRate/String              : 48.0 KHz
StreamSize/String                : 54.9 MiB (10%)
Alignment/String                 : Aligned on interleaves
Interleave_Duration/String       : 24 ms (0.60 video frame)
C:\Program Files (x86)\Serviio\lib>ffmpeg -i "D:\Completed\The.Daily.Show.2012.01.05.Craig.Shirley.HDTV.XviD-FQM.[VTV].avi"
Input #0, avi, from 'D:\Completed\The.Daily.Show.2012.01.05.Craig.Shirley.HDTV.XviD-FQM.[VTV].avi':
    encoder         : transcode-1.0.4
  Duration: 00:21:03.09, start: 0.000000, bitrate: 1163 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x352 [SAR 1:1 DAR 39:22], 29.97 tbr, 29.97 tbn, 29.97 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 128 kb/s
CompleteName                     : D:\Completed\The.Daily.Show.2012.01.05.Craig.Shirley.HDTV.XviD-FQM.[VTV].avi
Format                           : AVI
FileSize/String                  : 175 MiB
Duration/String                  : 21mn 3s
OverallBitRate/String            : 1 164 Kbps
Encoded_Application              : transcode-1.0.4
ID/String                        : 0
CodecID                          : XVID
CodecID/Hint                     : XviD
BitRate/String                   : 1 025 Kbps
FrameRate/String                 : 29.970 fps
ColorSpace                       : YUV
Bits-(Pixel*Frame)               : 0.156
StreamSize/String                : 154 MiB (88%)
ID/String                        : 1
Format                           : MPEG Audio
CodecID                          : 55
CodecID/Hint                     : MP3
BitRate/String                   : 128 Kbps
StreamSize/String                : 18.8 MiB (11%)
Interleave_Duration/String       : 24 ms (0.72 video frame)
Tarrasque
Post Sat Jan 21, 2012 8:29 am
Re: UT30 some files spot playing after ~10 seconds
ok Theory here. Looking at same files that don't play, I noticed the both use the following encoder
Encoded_Application : transcode-1.0.4 or 1.1.5
I testing other shows which used transcode-1.0.4 and they all crashed in similar fashion.
Movies I had which was transcode-1.0.6 did not crash.
Also noticed ones which used
Encoded_Application : Nandub v1.0rc2
Encoded_Library/String : Nandub build 1853/release
did not play at all, but those are some very old files.
All other files I have which work didn't use the transcode encoder.
So I am going to assume that the encoded application is the culprit here for this specific TV model.
If that is the case, Is there any way Serviio could transcode those specific files?
Or is there a program similar to mkvmerge I could use to recode the files (I find using that progam reduces the resolutions / throws out the aspect ratio).
Return to Panasonic
