Avi's not playing on BD-D6900
Silka
Post Sat Jan 21, 2012 1:23 pm
I have a lot of avi-files not playing, not on my LE40C750 and also not on my BD-D6900.. they both state 'videocodec not supported'.. i checked devices and they both won't play them from usb either.. i never had an avi not playing before, i never used transcoding so i left that off until now, but even with transcoding on, it stil won't play those files.. the play fine on my PC using i.e. VLC.. i have some ffmpeg info, looks like a framerate-problem but i have no clue on how to fix this.. maybe you can take a look at it and solve this?? would be great! ;)
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[avi @ 00348260] non-interleaved AVI
[mpeg4 @ 00348b40] Invalid and inefficient vfw-avi packed B frames detected
Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (300
00/1) -> 25.00 (25/1)
Input #0, avi, from 'E:\Media SD\Series SD\Stargate\Stargate SG-1\Season 06\Star
gate SG-1 [6x01] Redemption.avi':
  Duration: 00:42:12.64, start: 0.000000, bitrate: 1137 kb/s
    Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 640x352 [SAR 1:1 DAR
 20:11], 25 fps, 25 tbr, 25 tbn, 30k tbc
    Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), s16, 224 kb/s
grtzz Silka
Post Sat Jan 21, 2012 1:31 pm
Re: Avi's not playing on BD-D6900
c750 will play AVi fine and fact they wont play on usb either would lead me to think of bad or strange encoding on the file.
Silka
Post Sat Jan 21, 2012 2:03 pm
as i said, i never before had an avi not playing nativly.. i checked several files, dlna and usb also, non of them playing.. i have complete Stargate SG1 series, first 5 seasons play fine, transcoding turned off, but as from season 6, non of the files play.. not even with transcoding turned on (did a restart to make sure the change is effective).
Butttttt.. i solved this by adding 1 line to the B/D series profile (profile 7), added <Matches container="avi" vCodec="mpeg4" /> to the <!-- transcode AVI with AVC video --> and now all files play like they should.
As i understand from ffmpeg (Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (30000/1) -> 25.00 (25/1)), framerate of container and framerate of stream 0 codec differ, resulting in error.. so i don't know if converting like i did is the no.1 answer, at least it works.. maybe there is a way to correct framerate of the container without converting??
Grtz Silka
Post Sat Jan 21, 2012 2:08 pm
is actualy what the issue is. :) as i said above bad encodingm, and all you did by adding that line to the profile is transcode to mpeg2video for alot of files that dotn really need it.
http://wiki.serviio.org/doku.php?id=avirepair <-- use this program to fix the AVI files instead.
Silka
Post Sat Jan 21, 2012 3:22 pm
.. and so i removed that line instantly. Took me a while to find your avirepair @ http://sourceforge.net/projects/divfixp ... t/download but thnx a lot Cerberus, better fix than convert :lol:
EDIT: though it did fix something with 'DX50', both players still state 'videocodec not supported'.. :?
Post Sat Jan 21, 2012 3:36 pm
Silka wrote:.. and so i removed that line instantly. Took me a while to find your avirepair @ http://sourceforge.net/projects/divfixp ... t/download but thnx a lot Cerberus, better fix than convert :lol:
yep im useful when people are polite like you :)
