Unsupported Format Bluray Content
drunkwithpower
Post Sat Jan 21, 2012 10:24 pm
I have a Samsung UN46D6000 TV and am having issues with specific bluray rips. The rips are movie-only created using MakeMKV. The error is "unsupported format".
Here is the mediainfo:
Terminator Salvation
UniqueID/String : 334312965831851781645768130016314170008 (0xFB8255CDA6DA9168FF75383193CC9A98)
CompleteName : D:\BlurayMovies\Terminator Salvation (2009)\Terminator Salvation (2009).mkv
Format : Matroska
Format_Version : Version 2
FileSize/String : 23.5 GiB
Duration/String : 1h 54mn
OverallBitRate_Mode/String : Variable
OverallBitRate/String : 29.4 Mbps
Encoded_Date : UTC 2011-10-03 20:53:33
Encoded_Application : MakeMKV v1.6.15 win(x86-release)
Encoded_Library/String : libmakemkv v1.6.15 (1.2.0/1.1.0) win(x86-release)
ID/String : 1
Format : VC-1
Format_Profile : AP@L3
CodecID : WVC1
CodecID/Hint : Microsoft
BitRate/String : 24.6 Mbps
Width/String : 1 920 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16:9
FrameRate/String : 23.976 fps
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Compression_Mode/String : Lossy
Bits-(Pixel*Frame) : 0.495
StreamSize/String : 19.7 GiB (84%)
Language/String : English
Default/String : Yes
Forced/String : No
Audio #1
ID/String : 2
Format : DTS
Format_Profile : MA / Core
CodecID : A_DTS
BitRate/String : 2 689 Kbps / 1 510 Kbps
Channel(s)/String : 6 channels
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 24 bits
Compression_Mode/String : Lossless / Lossy
Title : Lossless
Forced/String : No
Audio #2
ID/String : 3
Format : DTS
CodecID : A_DTS
BitRate_Mode/String : Constant
BitRate/String : 1 510 Kbps
StreamSize/String : 1.21 GiB (5%)
Title : 3/2+1
Default/String : No
Forced/String : No
Troy:
UniqueID/String : 55360489630222193671671372846201801038 (0x29A60ADF692ABB10494F08054D6F894E)
CompleteName : D:\BlurayMovies\Troy (2004)\Troy (2004).mkv
Format : Matroska
FileSize/String : 16.7 GiB
Duration/String : 3h 16mn
OverallBitRate/String : 12.2 Mbps
Encoded_Date : UTC 2011-10-02 22:42:32
ID/String : 1
Format : VC-1
CodecID : WVC1
BitRate/String : 11.5 Mbps
Bits-(Pixel*Frame) : 0.232
StreamSize/String : 15.8 GiB (94%)
Forced/String : No
ID/String : 2
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
CodecID : A_AC3
BitRate/String : 448 Kbps
BitDepth/String : 16 bits
StreamSize/String : 628 MiB (4%)
Title : 3/2+1
Forced/String : No
Anyone have any ideas?
drunkwithpower
Post Mon Feb 27, 2012 4:51 pm
Re: Unsupported Format Bluray Content
This issue was fixed by downloading the bewest version of ffmpeg and replacing the current version located in the Serviio application directory structure (in the Lib directory).
File version: ffmpeg-git-b6ff81d-win32-static
Directory: Program Files\Serviio\Lib\
