4OD (UK only) - Web Resource
Post Sun Jan 22, 2012 4:13 pm
Re: 4OD (UK only) - Web Resource
eekfonky wrote:Sorry I don't know how to do that?
Which bit?
And where are you getting rtmpe://ll.securestream.channel4.com:19 ... 74ec6c91f7 playpath=mp4:xcuassets/CH4_08_02_16_44002001001002_005.mp4?e=1326134474&ip=82.32.84.83&h=ee8a16921686759564c30374ec6c91f7 swfurl=http://www.channel4.com/static/programmes/asset/flash/swf/4odplayer-11.8.5.swf swfVfy=1 from?
eekfonky
Post Sun Jan 22, 2012 4:16 pm
how to post the log, where do I find it? Do I have to run it? If so, how?
The next question is I found that earlier in the thread to test if it all works
Post Sun Jan 22, 2012 4:23 pm
eekfonky wrote:how to post the log, where do I find it? Do I have to run it? If so, how?
Sorry, that was a typo. I wanted you to run the ./configure part of the instuctions for building ffmpeg again as if you were re-doing it.
Right well as I said earlier, those links expire pretty quickly. Try adding an actual url into the serviio online source tab again, and then see if it works. If not you will then find a new active link in the serviio.log file
http://www.channel4.com/programmes/fresh-meat/4od
eekfonky
Post Sun Jan 22, 2012 5:09 pm
When I do the
./configure --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb \
    --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 \
    --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx \
    --enable-librtmp --enable-libxvid
It says that
librtmp enabled yes
ffmpeg -formats
ffmpeg version git-2012-01-22-72b33ea Copyright (c) 2000-2012 the FFmpeg developers
  built on Jan 22 2012 16:50:45 with gcc 4.6.1
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
  libavutil      51. 34.101 / 51. 34.101
  libavcodec     53. 57.105 / 53. 57.105
  libavformat    53. 30.100 / 53. 30.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 59.101 /  2. 59.101
  libswresample   0.  6.100 /  0.  6.100
File formats:
 D. = Demuxing supported
 .E = Muxing supported
  E 3g2             3GP2 format
  E 3gp             3GP format
 D  4xm             4X Technologies format
 D  IFF             IFF format
 D  ISS             Funcom ISS format
 D  MTV             MTV format
 DE RoQ             raw id RoQ format
  E a64             a64 - video for Commodore 64
 D  aac             raw ADTS AAC
 DE ac3             raw AC-3
 D  act             ACT Voice file format
 D  adf             Artworx Data Format
  E adts            ADTS AAC
 DE adx             CRI ADX
 D  aea             MD STUDIO audio
 DE aiff            Audio IFF
 DE alaw            PCM A-law format
 DE alsa            ALSA audio output
 DE amr             3GPP AMR file format
 D  anm             Deluxe Paint Animation
 D  apc             CRYO APC format
 D  ape             Monkey's Audio
 D  applehttp       Apple HTTP Live Streaming format
 DE asf             ASF format
  E asf_stream      ASF format
 DE ass             Advanced SubStation Alpha subtitle format
 DE au              SUN AU format
 DE avi             AVI format
  E avm2            Flash 9 (AVM2) format
 D  avs             AVS format
 D  bethsoftvid     Bethesda Softworks VID format
 D  bfi             Brute Force & Ignorance
 D  bin             Binary text
 D  bink            Bink
 DE bit             G.729 BIT file format
 D  bmv             Discworld II BMV
 D  c93             Interplay C93
 DE caf             Apple Core Audio Format
 DE cavsvideo       raw Chinese AVS video
 D  cdg             CD Graphics Format
  E crc             CRC testing format
 DE daud            D-Cinema audio format
 D  dfa             Chronomaster DFA
 DE dirac           raw Dirac
 DE dnxhd           raw DNxHD (SMPTE VC-3)
 D  dsicin          Delphine Software International CIN format
 DE dts             raw DTS
 DE dv              DV video format
 D  dv1394          DV1394 A/V grab
  E dvd             MPEG-2 PS format (DVD VOB)
 D  dxa             DXA
 D  ea              Electronic Arts Multimedia Format
 D  ea_cdata        Electronic Arts cdata
 DE eac3            raw E-AC-3
 DE f32be           PCM 32 bit floating-point big-endian format
 DE f32le           PCM 32 bit floating-point little-endian format
 DE f64be           PCM 64 bit floating-point big-endian format
 DE f64le           PCM 64 bit floating-point little-endian format
 D  fbdev           Linux framebuffer
 DE ffm             FFM (FFserver live feed) format
 DE ffmetadata      FFmpeg metadata in text format
 D  film_cpk        Sega FILM/CPK format
 DE filmstrip       Adobe Filmstrip
 DE flac            raw FLAC
 D  flic            FLI/FLC/FLX animation format
 DE flv             FLV format
  E framecrc        framecrc testing format
  E framemd5        Per-frame MD5 testing format
 DE g722            raw G.722
 DE g723_1          raw G.723.1
 D  g729            G.729 raw format demuxer
  E gif             GIF Animation
 D  gsm             raw GSM
 DE gxf             GXF format
 DE h261            raw H.261
 DE h263            raw H.263
 DE h264            raw H.264 video format
 D  ico             Microsoft Windows ICO
 D  idcin           id Cinematic format
 D  idf             iCE Draw File
 DE image2          image2 sequence
 DE image2pipe      piped image2 sequence
 D  ingenient       raw Ingenient MJPEG
 D  ipmovie         Interplay MVE format
  E ipod            iPod H.264 MP4 format
 D  iv8             A format generated by IndigoVision 8000 video server
 DE ivf             On2 IVF
 D  jack            JACK Audio Connection Kit
 D  jv              Bitmap Brothers JV
 DE latm            LOAS/LATM
 D  lavfi           Libavfilter virtual input device
 D  lmlm4           lmlm4 raw format
 D  loas            LOAS AudioSyncStream
 D  lxf             VR native stream format (LXF)
 DE m4v             raw MPEG-4 video format
  E matroska        Matroska file format
 D  matroska,webm   Matroska/WebM file format
  E md5             MD5 testing format
 DE microdvd        MicroDVD subtitle format
 DE mjpeg           raw MJPEG video
  E mkvtimestamp_v2 extract pts as timecode v2 format, as defined by mkvtoolnix
 DE mlp             raw MLP
 D  mm              American Laser Games MM format
 DE mmf             Yamaha SMAF
  E mov             MOV format
 D  mov,mp4,m4a,3gp,3g2,mj2 QuickTime/MPEG-4/Motion JPEG 2000 format
  E mp2             MPEG audio layer 2
 DE mp3             MPEG audio layer 3
  E mp4             MP4 format
 D  mpc             Musepack
 D  mpc8            Musepack SV8
 DE mpeg            MPEG-1 System format
  E mpeg1video      raw MPEG-1 video
  E mpeg2video      raw MPEG-2 video
 DE mpegts          MPEG-2 transport stream format
 D  mpegtsraw       MPEG-2 raw transport stream format
 D  mpegvideo       raw MPEG video
  E mpjpeg          MIME multipart JPEG format
 D  msnwctcp        MSN TCP Webcam stream
 DE mulaw           PCM mu-law format
 D  mvi             Motion Pixels MVI format
 DE mxf             Material eXchange Format
  E mxf_d10         Material eXchange Format, D-10 Mapping
 D  mxg             MxPEG clip file format
 D  nc              NC camera feed format
 D  nsv             Nullsoft Streaming Video
  E null            raw null video format
 DE nut             NUT format
 D  nuv             NuppelVideo format
 DE ogg             Ogg
 DE oma             Sony OpenMG audio
 DE oss             Open Sound System playback
 D  pmp             Playstation Portable PMP format
  E psp             PSP MP4 format
 D  psxstr          Sony Playstation STR format
 D  pva             TechnoTrend PVA file and stream format
 D  qcp             QCP format
 D  r3d             REDCODE R3D format
 DE rawvideo        raw video format
  E rcv             VC-1 test bitstream
 D  rl2             RL2 format
 DE rm              RealMedia format
 D  rpl             RPL/ARMovie format
 DE rso             Lego Mindstorms RSO format
 DE rtp             RTP output format
 DE rtsp            RTSP output format
 DE s16be           PCM signed 16 bit big-endian format
 DE s16le           PCM signed 16 bit little-endian format
 DE s24be           PCM signed 24 bit big-endian format
 DE s24le           PCM signed 24 bit little-endian format
 DE s32be           PCM signed 32 bit big-endian format
 DE s32le           PCM signed 32 bit little-endian format
 DE s8              PCM signed 8 bit format
 DE sap             SAP output format
 D  sbg             SBaGen binaural beats script
  E sdl             SDL output device
 D  sdp             SDP
  E segment         segment muxer
 D  shn             raw Shorten
 D  siff            Beam Software SIFF
 DE smjpeg          Loki SDL MJPEG
 D  smk             Smacker video
 D  sol             Sierra SOL format
 DE sox             SoX native format
 DE spdif           IEC 61937 (used on S/PDIF - IEC958)
 DE srt             SubRip subtitle format
  E svcd            MPEG-2 PS format (VOB)
 DE swf             Flash format
 D  thp             THP
 D  tiertexseq      Tiertex Limited SEQ format
 D  tmv             8088flex TMV
 DE truehd          raw TrueHD
 D  tta             True Audio
 D  tty             Tele-typewriter
 D  txd             Renderware TeXture Dictionary
 DE u16be           PCM unsigned 16 bit big-endian format
 DE u16le           PCM unsigned 16 bit little-endian format
 DE u24be           PCM unsigned 24 bit big-endian format
 DE u24le           PCM unsigned 24 bit little-endian format
 DE u32be           PCM unsigned 32 bit big-endian format
 DE u32le           PCM unsigned 32 bit little-endian format
 DE u8              PCM unsigned 8 bit format
 D  vc1             raw VC-1
 D  vc1test         VC-1 test bitstream format
  E vcd             MPEG-1 System format (VCD)
 D  video4linux2,v4l2 Video4Linux2 device grab
 D  vmd             Sierra VMD format
  E vob             MPEG-2 PS format (VOB)
 DE voc             Creative Voice file format
 D  vqf             Nippon Telegraph and Telephone Corporation (NTT) TwinVQ
 D  w64             Sony Wave64 format
 DE wav             WAV format
 D  wc3movie        Wing Commander III movie format
  E webm            WebM file format
 D  wsaud           Westwood Studios audio format
 D  wsvqa           Westwood Studios VQA format
 DE wtv             Windows Television (WTV)
 D  wv              WavPack
 D  x11grab         X11grab
 D  xa              Maxis XA File Format
 D  xbin            eXtended BINary text (XBIN)
 D  xmv             Microsoft XMV
 D  xwma            Microsoft xWMA
 D  yop             Psygnosis YOP Format
 DE yuv4mpegpipe    YUV4MPEG pipe format
Post Sun Jan 22, 2012 5:12 pm
OK. That looks all OK then.
Now re-adding or refreshing a 4oD url in the online sources tab and see what happens.
eekfonky
Post Sun Jan 22, 2012 5:19 pm
OK for example I added:
http://www.channel4.com/programmes/shameless/4od
as a 'Web Resource'
and clicked the 'video' radio button
save
The folder appears but inside it says: There are no items to display
Post Sun Jan 22, 2012 5:22 pm
Look in the serviio log and find the most recent ffmpeg command and then use that to run ffmpeg -i like you were before and post the output.
eekfonky
Post Sun Jan 22, 2012 5:29 pm
here it is:
2012-01-22 02:23:33,892 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.channel4.com/programmes/shameless/4od. Message: Error during feed parsing : Invalid XML: Error on line 368: The value of attribute "data-episodeSynopsis" associated with an element type "null" must not contain the '<' character.
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:177)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
   at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
Post Sun Jan 22, 2012 5:33 pm
You need to also find an ffmpeg command that you can run to get a bit more info.
Are you 100% you have it saved as 'Web resource' as that was the problem that the last user had.
eekfonky
Post Sun Jan 22, 2012 5:53 pm
Sorry how do i find an ffmpeg command to run?
And I'm 100% sure I have it as web resource
Thanks again for all your help :D
Post Sun Jan 22, 2012 6:08 pm
It will be in the serviio.log file, you might need to turn on detailed loggin (see my sig for details) and then restart serviio.
Should appear near the "WARN [FeedUpdaterThread] An error occured while scanning for online item information" lines and will be the similar to the ffmpeg -i commands you were running earlier to test things out.
eekfonky
Post Sun Jan 22, 2012 6:27 pm
 [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://ll.securestream.channel4.com:1935/a4174/e1/?ovpfv=1.1&e=1327248395&ip=86.168.39.192&h=bde615553f2773f7f4c7b7ed3e38e0fd playpath=mp4:xcuassets/CH4_08_02_16_49064006001003_005.mp4?e=1327248395&ip=86.168.39.192&h=bde615553f2773f7f4c7b7ed3e38e0fd swfurl=http://www.channel4.com/static/programmes/asset/flash/swf/4odplayer-11.8.5.swf swfVfy=1. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:272)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:254)
   ... 2 more
Post Sun Jan 22, 2012 6:31 pm
What do you get when you run
ffmpeg -i "rtmpe://ll.securestream.channel4.com:1935/a4174/e1/?ovpfv=1.1&e=1327248395&ip=86.168.39.192&h=bde615553f2773f7f4c7b7ed3e38e0fd playpath=mp4:xcuassets/CH4_08_02_16_49064006001003_005.mp4?e=1327248395&ip=86.168.39.192&h=bde615553f2773f7f4c7b7ed3e38e0fd swfurl=http://www.channel4.com/static/programmes/asset/flash/swf/4odplayer-11.8.5.swf swfVfy=1"
eekfonky
Post Sun Jan 22, 2012 6:33 pm
HandShake: Type mismatch: client sent 6, server answered 9
HandShake: Server not genuine Adobe!
RTMP_Connect1, handshake failed.
rtmpe://ll.securestream.channel4.com:1935/a4174/e1/?ovpfv=1.1&e=1327248395&ip=86.168.39.192&h=bde615553f2773f7f4c7b7ed3e38e0fd playpath=mp4:xcuassets/CH4_08_02_16_49064006001003_005.mp4?e=1327248395&ip=86.168.39.192&h=bde615553f2773f7f4c7b7ed3e38e0fd swfurl=http://www.channel4.com/static/programmes/asset/flash/swf/4odplayer-11.8.5.swf swfVfy=1: Operation not permitted
Post Sun Jan 22, 2012 7:08 pm
Hmm, did you get any errors when building and installing ffmpeg and librtmp?
eekfonky
Post Sun Jan 22, 2012 7:10 pm
Well thanks for trying :D
KeifOS
Post Thu Feb 02, 2012 9:27 pm
I've been running version 0.6.1 on my qnap for a while and got 4OD working ok.
A tried 0.6.2 with the same ffmpeg and librtmp, but for some reason now ffmpeg bombs out after transcoding a couple of minutes. Went back to 0.6.1 and it working again.
Just wondered if anyone else has been getting the same?
K.
Maxwell
Post Sun Feb 05, 2012 8:07 pm
Hi
I am seeing something similar to KeifOS. I have Serviio 0.6.1 though. I can play from 4OD but after about 2 minutes it freezes and immediately plays the next episode. Could this be the same thing?
Sony Blu-Ray BDP-S480, Serviio on windows XP, XBOX 360, Windows, Linux and Android PCs, iPhone
Xmantium
Post Mon Feb 06, 2012 7:08 pm
I've unfortunate noticed too but it doesn't happen all the time
mine usually happens in the middle, it pauses and then plays the next file
I've checked the logs file but can't find anything but haven't got detailed logging enabled yet
Post Mon Feb 06, 2012 7:25 pm
Had the same problem last night - was going to have another go to try and get some useful information.
Return to Available plugins
Users browsing this forum: Google [Bot] and 9 guests
