Newb here quick two parter about streaming quality
streamnewb
Post Wed Jan 25, 2012 5:02 am
Would like to start off by saying hi to everyone and that I LOVE SERVIIO it the bees knees . Ok I ve tried to search to my hearts content on the in tor net but cant fnd anything close to answering my question.
How come when i stream a file from laptop to my samsung 3d tv the stream can be flawless 1080p but another 1080p file stutters , pauses and skips thru the whole file . I think it has to do with containers and stuff and how its encoded but how can files from the same source vary so greatly that one is flawless and another almost unplayable .
second question is there a way to remedy this ? maybe look at the codecs and stuff used to create the flawless file and change the unplayable files to match <rencode> ?????
streamnewb
Post Wed Jan 25, 2012 5:45 am
Re: Newb here quick two parter about streaming quality
Just saw i should have probably posted this in sammy help lol my bad ..... anyways heres the info for a file that stutters and stops the whole way thru
Unique ID : 179297328679425652609573630696424212919 (0x86E368D01798D91191892A601A0409B7)
Complete name : C:\Users\Malackie\Downloads\Battle LA\Battle.Los.Angeles.2011.1080p.BluRay.x264.DTS.WiKi.mkv
Format : Matroska
Format version : Version 1
File size : 12.0 GiB
Duration : 1h 56mn
Overall bit rate : 14.8 Mbps
Encoded date : UTC 2011-05-09 03:48:51
Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 13:20:25
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 56mn
Bit rate : 13.3 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.360
Stream size : 10.5 GiB (88%)
Writing library : x264 core 98 r1649 c54c47d
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.10:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-4 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=48 / rc=2pass / mbtree=1 / bitrate=13268 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.80
Language : English
Default : Yes
Forced : No
Format : DTS
Codec ID : A_DTS
Duration : 1h 56mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.23 GiB (10%)
Title : 英语
Language : English
Default : Yes
Forced : No
heres one that plays flawlessly
Unique ID : 225793567997887569606908682274013574608 (0xA9DE42671A3258B0A5C03D32EB9DF5D0)
Complete name : C:\Users\Malackie\Downloads\Legend of the Guardians 3D 2010 1080p Half-SBS BluRay DTS x264-SSIFsucka\Legend of the Guardians 3D 2010 1080p Half-SBS BluRay DTS x264-SSIFsucka.mkv
Format : Matroska
Format version : Version 2
File size : 7.64 GiB
Duration : 1h 36mn
Overall bit rate : 11.3 Mbps
Encoded date : UTC 2010-12-15 22:39:53
Writing application : mkvmerge v4.3.0 ('Escape from the Island') gemaakt op Sep 5 2010 10:30:51
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L4.0
Duration : 1h 36mn
Bit rate : 10 000 Kbps
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.201
Stream size : 6.46 GiB (85%)
Writing library : x264 core 107 r1745 4785e8e
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Default : Yes
Forced : No
Format : DTS
Codec ID : A_DTS
Duration : 1h 36mn
Bit depth : 24 bits
Stream size : 1.02 GiB (13%)
Default : Yes
Forced : No
Post Wed Jan 25, 2012 9:10 am
first one :
second one:
You can try to remux with mkvmerge tool the first file.
Post Wed Jan 25, 2012 10:40 am
Illico wrote:first one :
second one:
i second that i use 4.3 and havent come accross this issue :)
Return to General discussion
