[OLD] Android Console
Northguy
Post Tue Jan 24, 2012 10:30 pm
Re: Android Console
will wrote:
I saw, thanks. Any thoughts on the translation service?
No thanks.......
I think the translation service is great. Gives you good possibilities on localisation. I have some experience with translating on launchpad.net but your service works nicer!
Post Wed Jan 25, 2012 8:18 am
Re: Android Console
Thats good, it apeared to work well when I played around with it. It should make managing updates easier when I have to add extra strings for new features. Not sure what it does if I change a string, hopefully it will mark it as needing re-translating.
The fact that you can spend just 5 or 10 minuets and translate some of the strings will hopefully encorage people compared to having to download and translate the whole set in one go.
Zip if you moved to something like this, the initial setup time for you will be pretty minimal. In about 15 or so min and you could have an account setup and all the language files uploaded.
I also looked at crowdin, but that is a paid service unless your code is opensource, where as this is free, with extra pro features.
Post Wed Jan 25, 2012 10:16 am
Re: Android Console
@User who put their forum name as 'htc qba' with the HTC Wildfire S, I can't find you in the list of memebers so cannot PM you.
I'm not sure why, but the server data has got a bit out of sync. Clearing the data for the app should fix it. I'll add some extra protection into the next version to stop it happening again.
Post Wed Jan 25, 2012 2:07 pm
Re: Android Console
@Zip, just had a play with things like renaming the key or renaming the values. The procedure works well, when you upload a new master file, you confirm you want to replace the existing one and it will then highlight any changes it can't sort out, you can then either keep what it thinks they should be, or mark them to be re-translated in the case or changing the meaning signigicantly. Any new strings, or deleted strings are automatically sorted out.
It also sources translation suggestions from public projects. Meaning if you uploaded all of the main serviio files, it should use your existing translations as suggestions for people translating the android app. Then in the future if other people develop iOS/WP7 apps, if they used the same service, they would also get suggestions.
So far, it appers to be a pretty good service, and its free if you don't mind anyone being able to translate the files.
Post Wed Jan 25, 2012 2:10 pm
Re: Android Console
Thanks Will, will have a look at it for the next major release.
Post Thu Jan 26, 2012 1:49 pm
Re: Android Console
Copied from post-update hooks thread
moltra wrote:Seeing what has been files have been added / changed or maybe even a link to the serviio.log file.
Four options order by my likelihood of doing them
1) Show the last added file on the status view, thats easy and I don't know why I didn't in the first place. I'll add that to the next release.
2) Wait for ZIP to allow 'browsing' the repository over the REST API so that I can show the 'Last added' category in the app. My prefered method.
3) When connected over wifi perform a UPnP browse through the app as if it was a renderer and show the files available in the 'Last added' category. This should work but I don't know how much time it would take and I don't have time at the moment.
4) Do something with the serviio.log file - this requires either zip expose it, or that the user expose it. I guess something along the lines of how the restful webui works might work. Or a standalone server, ie the user tells the app that they have apache running with SERVERIP/serviio/serviio.log available for access.
Question:
Would there be interest for the app to (optionally) refresh the status view in the background and then pop up a notifiation saying
ServiiDroid: 5 files have been added to serviio. The last file was filename.avi
Post Thu Jan 26, 2012 2:03 pm
Re: Android Console
will wrote:Question:
Yes, this would be great addition. Maybe expand it if possible to online sources.
Post Thu Jan 26, 2012 2:14 pm
Re: Android Console
At the moment the only thing in the API about updates is
Checking for new files: yes/no
Checking updates: yes/no
Number of new files added: number
Last file added: filename
so thats what I can show for now.
I've created a ticket for the idea https://bitbucket.org/serviiodroid/serv ... he-user-if
Post Thu Jan 26, 2012 10:06 pm
Re: Android Console
I've uploaded a new test build. I am not pushing it out through the update checker as there are some incomplete bits in it. As well as the changes on the wiki, this applies the Holographic theme when running android 3.0 and above. Can a few people running 3.0 -> 4.0.3 try it out and give me some feedback on how it looks and what needs adjusting. I haven't implemented the action bar just yet, that will come later.
This will be installed as a seperate app and when I release it on the market you will have to remove it first.
Please also go into the preferences and enter your forum username incase the app crashes.
For those interested https://bitbucket.org/serviiodroid/serv ... test-1.apk
I've had a play with ICS, going to try Honeycomb now.
So far, the online source type needs re-styling as you cannot read it.
Post Thu Jan 26, 2012 10:41 pm
Re: Android Console
will throw it on the HTC tomorrow and give it a test, be nice if you could post the change log each time tho rather than having to find it on yet another site. :( come on im constantly looking at serviio forum and wiki dont need another :(
Post Thu Jan 26, 2012 10:44 pm
Re: Android Console
I specifically haven't posted the changelog and haven't pushed this through the update checker because it has quite a few issues and I just want a bit of feedback from a few users on the use of the theme, rather than the other fixes that it includes.
seus
Post Fri Jan 27, 2012 6:29 am
Re: Android Console
This looks really great...question, is it outside the capabilities of this app to actually restart the Serviio service vs. the restart server command from the console? I ask because doing the former seems to help when my TV can't see Serviio, but doing the latter does not.
Post Fri Jan 27, 2012 8:06 am
Re: Android Console
Is that the test release with the holographic theme or the normal one?
Using the API as it stands, you can stop or start the DLNA streaming server part of it.
You can actually also exit the main server process, however you cannot start it back up again, which is why I left it out of the app. Not much use from a mobile app if you can stop it but not start it.
Post Fri Jan 27, 2012 9:02 am
Re: Android Console
I've uploaded another test build (Test2). Can a few people running 3.0 -> 4.0.3 try it out and give me some feedback on how it looks and what needs adjusting.
For those interested https://bitbucket.org/serviiodroid/serv ... test-2.apk
Over the previous test, this makes online source tyle selection readable, and stops the menu items dissapearing on tablets, and adds a few ui fixes to honeycomb.
@voodooo you may be interested in trying this out as it has your translation in it.
I have also added one more string that will need to be translated :(
Northguy
Post Fri Jan 27, 2012 1:10 pm
Re: Android Console
100% translation for Dutch language. Hope everything is clear, because I learned that some translations are quite difficult without a proper context. Let's wait and see if the community starts correcting the translations :lol:
Any chance on having ServiiDroid on Android market soon? I love the pushed updates of the Market :D
Post Fri Jan 27, 2012 1:23 pm
Re: Android Console
Thank you, i've added it and will build a new test release tonight so you can test it.
I did try to name the keys for the strings to help e.g. view_status_server_address indiciates it is a string specific the the status view. There are actually quite a few comments in the raw xml file that aren't exposed through the translation service, however I like the fact that you can post comments on them and I can reply with some extra information.
As for the market, it is still looking like next weekend (4/5th of feb as launch day) as I'm away from this sunday to the 3rd so I will not available to fix any issues that may happen when I publish the app.
Post Fri Jan 27, 2012 7:05 pm
Re: Android Console
I am now preparing the promotional material for the launch of ServiiDroid on the Android Market. I will freeze development tomorrow night so this is your last chance to provide feedback.
ServiiDroid now has a new home Link
No more updates will be pushed through the update checker. When I release the app please delete the beta versions and if you also downloaded the extra test builds, also remove those first, otherwise you will get errors todo with the package signature not matching.
Post Fri Jan 27, 2012 7:18 pm
Re: Android Console
good luck will hope it all goes ok :)
Post Fri Jan 27, 2012 8:15 pm
Re: Android Console
Any thoughts?
ServiiDroid Market Banner
Post Fri Jan 27, 2012 8:17 pm
Re: Android Console
looks good to me still not strict on the logo though but ah well.
