YouTube
xtrapeque
Post Sat Jan 28, 2012 12:14 am
Re: YouTube
Do I still channel the problem is?, Because in my samsung tv with the YouTube application, loading the channel is only 4 seconds and moves to the next video
Post Sat Jan 28, 2012 2:02 am
Re: YouTube
sam_1421 wrote:Is there a way to play HD videos via Serviio? Because the default quality is really bad :(
Please read the Serviio documentation and this thread for the information on how to setup quality.
Post Sat Jan 28, 2012 4:42 pm
Re: YouTube
xtrapeque wrote:Do I still channel the problem is?, Because in my samsung tv with the YouTube application, loading the channel is only 4 seconds and moves to the next video
I do not understand your question..explain what you have done and what does not work that you expected.
Apo14
Post Sat Jan 28, 2012 11:56 pm
Re: YouTube
Hey guys,
i have just integrated some youtube channels into serviio.
When testing the videos, i noticed that the sound is very wierd...
sounds like the frequencys or the sample rates are wrong.
can someone agree to this problem? does anyone experience the same?
how can i resolve this?
already played with quality settings but nothing helped.
Post Sun Jan 29, 2012 12:32 am
Re: YouTube
Never had any YT problems. How did you "integrate" them? Did you use the links as described in the Wiki entry "How to Get YouTube Videos to Play in Serviio" ? http://wiki.serviio.org/doku.php?id=you_tube_videos
Apo14
Post Sun Jan 29, 2012 12:38 am
Re: YouTube
Ok sry...
found out this problem occured with the new ffmpeg.exe which i updated before.
i wanted to upgrade to 8.0 but seems to cause this problem.
now im back to the original serviio version.
xtrapeque
Post Sun Jan 29, 2012 11:52 am
Re: YouTube
the problem is described in the previous page.
can not watch one channel live on youtube
Post Mon Jan 30, 2012 1:20 am
Re: YouTube
Post the "one channel live " that you are trying to "watch on Serviio" and I will test it.
xtrapeque
Post Mon Jan 30, 2012 12:20 pm
Re: YouTube
jhb50 wrote:Post the "one channel live " that you are trying to "watch on Serviio" and I will test it.
http://www.youtube.com/watch?feature=player_embedded&v=One2Jbph-Po
This is the channel, thanks for test it.
Post Mon Jan 30, 2012 3:57 pm
Re: YouTube
First, you have not read the documentation on how to get yt videos in Serviio.
Secondly, you have not read this thread to see that another user made the same error, and see the solution. When you do, you will also see that there is a problem with Serviio playing that yt stream.
see http://forum.serviio.org/viewtopic.php?f=20&t=3276&start=110#p35504
xtrapeque
Post Mon Jan 30, 2012 5:42 pm
Re: YouTube
jhb50 wrote:First, you have not read the documentation on how to get yt videos in Serviio.
First, if I read the documentation as I said before, because, secondly, I am the user with that problem, not someone else, am I the same, and the last message I just wanted to put that might please indicate the problem is not serviio if not the channel, as with the application of my tv samsung YT, not me playing.
Thanks for the help.
I guess the problem was due to language
Post Mon Jan 30, 2012 5:55 pm
Re: YouTube
OK, I think I understand...you are confirming that it also does not work for you when you use the correct "gdata" link.
TheOne.PC
Post Mon Feb 06, 2012 5:58 pm
Re: YouTube
I've added this RSS feed
http://gdata.youtube.com/feeds/api/user ... ll/uploads
But why can I play this video (highest quality 720p)
http://www.youtube.com/watch?v=JqbgOK52 ... uKJz_2ud68
and I can't play this video (highest quality 1080p)
http://www.youtube.com/watch?v=rMmRBNDA ... rQeYgTsV2A
In the log file I've found this
2012-02-06 18:51:32,400 WARN  [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error.
2012-02-06 18:52:16,936 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-02-06 18:52:37,721 WARN  [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error.
Thanks in advice
Post Mon Feb 06, 2012 8:55 pm
Re: YouTube
Nice catch. I've analysed this and the problem seems to be that video has a format 46 available which the groovy does not recognize. I'm testing the fix now and I will report it to zip to post a working groovy.
TheOne.PC
Post Tue Feb 07, 2012 12:27 am
YouTube
The same problem if i try to play 1080p videos from TopGear youtube channel rss ;)
Post Tue Feb 07, 2012 1:01 pm
Re: YouTube
Groovy is fixed and updated version is posted in post 1.
TheOne.PC
Post Tue Feb 07, 2012 5:24 pm
Re: YouTube
jhb50 wrote:Groovy is fixed and updated version is posted in post 1.
I still get "Video codec not supported" also after updating the plugin and restarting Serviio
2012-02-07 18:22:11,804 WARN  [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error.
2012-02-07 18:22:29,899 WARN  [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error.
Post Tue Feb 07, 2012 5:58 pm
Re: YouTube
are you on 0.6.2 ?
TheOne.PC
Post Tue Feb 07, 2012 7:49 pm
YouTube
Yes i'm on 0.6.2, serviio on linux, samsung c5100, ffmpeg and everything up to date
Post Tue Feb 07, 2012 9:16 pm
Re: YouTube
Beats me, with my revised groovy I get all 25 clips in the folder with icons and they all play fine.
Return to Available plugins
Users browsing this forum: Baidu [Spider] and 32 guests
