samsung c6730 not seeing shared folders on serviio
stragf
Post Sat Jan 28, 2012 8:15 pm
I am lost and baffled. Samsung allshare kept crashing, so I installed Serviio.
On my Samsung system, my PC shows up but I cannot access any of the folders I have shared which I entered in the library C/users/me/downloads/movies;music;pictures, etc.
Status is set on Samsung tv/player( c/d series). I have also tried generic DNLA
I went into network settings on Samsung and bound the IP address which is showing on the wireless network.
Presentation is set to display category.
What am I missing????
Post Sat Jan 28, 2012 8:45 pm
Re: samsung c6730 not seeing shared folders on serviio
can you do a screen shot of teh library tab of serviio consoel please and paste it here.
stragf
Post Sat Jan 28, 2012 9:05 pm
http://www.grabilla.com/0211c-ab6dc0ed- ... a7586f.png
Any help is GREATLY appreciated. Thank you!
Grant
Post Sat Jan 28, 2012 9:21 pm
Re: Re: samsung c6730 not seeing shared folders on serviio
stragf wrote:I went into network settings on Samsung and bound the IP address which is showing on the wireless network.
What do you mean by this. The bound ip in the console should be the the ip of your computer. Or does your Samsung device have a bound ip setting?
stragf
Post Sat Jan 28, 2012 9:32 pm
http://www.grabilla.com/0211c-f0868f8e- ... 1bea31.png
This shows the IP address default when I installed Serviio, and the IP address in the network settings is from the network settings I am picking up on the Samsung. I input the IP address after reading through some of the forums where it said to bind it. I did this only after attempting to use the defalults
Post Sat Jan 28, 2012 10:52 pm
ok cant look at pic here at work, so will look into this once i get home, you should not manually set any information on the TV let it be autodetected, only place you should be putting an IP is in the serviio console under bound IP and this has to be IP of the PC running serviio .
