WDTV Live (2011) and TrueHD transcode
pinsight
Post Mon Jan 30, 2012 10:27 pm
Currently using Serviio v0.6.1 with WDTV Live 2011 edition.
My problem is that my receiver doesn't support TrueHD decoding, so I'd like Serviio to transcode TrueHD to ex. Dolby Digital (AC3?).
Is it possible to manually edit the profiles to make Serviio do this? Perhaps it can be provided in the next update?
Thanks for a great software!
Post Mon Jan 30, 2012 10:38 pm
Re: WDTV Live (2011) and TrueHD transcode
pinsight wrote:Currently using Serviio v0.6.1 with WDTV Live 2011 edition.
attach your profiles.xml file and will edit it for you, im at work so dotn have a copy to hand.
pinsight
Post Mon Jan 30, 2012 10:44 pm
Sounds terrific! I have attached it.
I don't know what the best target transcoding from TrueHD is - DTS maybe? AC3? I don't know much about this stuff so I'm just happy if it can be done. Thanks!
profiles.xml
(56.68 KiB) Downloaded 752 times
Post Mon Jan 30, 2012 11:21 pm
what file is the trueHD audio in MKV, MP4 AVI?????
EDIT: never mind i see from current profiel it would only be MKv or AVI so i added both for you.
profiles.xml
(56.84 KiB) Downloaded 727 times
pinsight
Post Tue Jan 31, 2012 9:14 am
Cerberus wrote:what file is the trueHD audio in MKV, MP4 AVI?????
profiles.xml
Thanks! But it doesn't work:(
When starting serviio after replacing profiles.xml it says:
Cannot connect to Serviio server, it does not seem to be running. Exiting...
I tried changing "turehd" to "truehd" in your edit (I think that was a mistake no?) and also "mkv" to "matroska" (same) but it still gives me the error.
Post Tue Jan 31, 2012 5:11 pm
opps yer typo sorry about that, and you are running serviio 0.6.1 yes?
pinsight
Post Tue Jan 31, 2012 5:14 pm
Cerberus wrote:opps yer typo sorry about that, and you are running serviio 0.6.1 yes?
Yes. I downloaded the profiles.xml, changed the typos, saved it, replaced the original one and restarted my computer. Error message then shows up. If I replace the new profiles.xml with the old one and restart again it works perfectly fine so it must be something with your changes - I just don't know what because it looks ok to me:S
Post Tue Jan 31, 2012 5:28 pm
what does the log say? there should be an error message regarding to xsd validation
Post Tue Jan 31, 2012 6:11 pm
oodd ok well tested this and it runs for me here, althoguh im late for work now oppps lolol
profiles.xml
(58.06 KiB) Downloaded 782 times
