PVR stops when using serviio
being
Post Tue Jan 31, 2012 12:44 pm
why stops PVR when using serviio?
All external sources are possible - but not serviio?
Post Tue Jan 31, 2012 8:18 pm
Re: PVR stops when using serviio
huh? that doesnt make sense. :S
Post Tue Jan 31, 2012 8:38 pm
Can you post your serviio.log file.
being
Post Wed Feb 01, 2012 10:20 am
Here it is.
serviio.zip
(246.7 KiB) Downloaded 454 times
being
Post Thu Feb 02, 2012 10:42 am
What tells you the logfile?
When PVR is running or programmed and I want to change source to serviio I have to give ok to cancel PVR.
This naturally happens when I change channel or change from sattelite to terrestric.
But I can change to external sources - why not to serviio?
Post Thu Feb 02, 2012 12:38 pm
that looks like a feature of the PVR, you should ask their support.
being
Post Fri Feb 03, 2012 8:37 am
Samsung support?
Not possible...PVR was enabled by myself...
